Parametric design in MoI?
 1-14  …  635-654  655-674  675-694  695-714  715-734  …  895-912
7713.675 In reply to 7713.674
Perfect! Thanks.
I will create the very first icon and for the moment I will put it into your example code, just to see how things go.
Then I will show you the result and if all will be fine I will create all other icons, coded in Base64 and placed into a specific node file.
We'll catch up :)
Ciao!
7713.676
Stuck.
I'm trying to run 0.97 in Windows 10 latest version.
Node Editor comes up OK with all the normal buttons New, Load, Save, Apply Run, Step.
And all is well if I load the attached file strainer 01.nod
But, when I load either strainer 02.nod or strainer 03.nod all the buttons are blanked out except New, and Load.
I suspect that I've created this problem by trying to use the RMB copy and paste function with the Macro feature the wrong way.
Anyway out of this mess outside of starting again?
And is there a specific order order in which the RMB copy/paste/macro system should be used?
Mike.
EDIT.
Tried strianer 03.nod in 0.96 no good.
Tried in 0.95, buttons back so could run and save. Saved with new name but still no good when loaded into 0.97. No Run, no Save.
EDITED: 9 Oct 2017 by MGG942
7713.677 In reply to 7713.676
Hi Mike
Nodeeditor blocks Save/Load/Run function when you load nod-file with missed nodes.
02 and 03 contains PatternSelArray node. Install extension file with this node or remove it.
7713.678
Hello Max,
small bug in Logic/Compare a<>b should a!==b.
Thanks in advance!
Have a nice day
Karsten
7713.679 In reply to 7713.678
Hi Karsten,
<> is most common sign, so it's OK.
7713.680 In reply to 7713.679
Yep! You are right -my fault - while testing I've maybe forgot to press run:-)
Have a nice evening
Karsten
7713.681 In reply to 7713.677
Thanks, Max.
7713.683 In reply to 7713.682
Hi bemfarmer.
Unreal engine cheated Max!!
7713.684
Hi Max and other Noders,
It would be useful to have an additional widget: a simple 2 state Switch,
that would output either 0 or 1 by clicking on the body of the node.
(Dialling between 0&1 with Knob, now the best option, is an awkward interaction.)
Such a node could be used to good effect in, for example, Al's most recent experiment:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.625
Moreover, several nodes would benefit from accepting boolean input.
This has become even more pertinent since the arrival of Macros, because
unlike regular .nod files, they require a high degree of universality.
See attached illustration of its use
Additionally, switch node may just be deployed simply to change the numerical value of a variable.
eg to nullify by multiplying with a part of an equation within parentheses
Your thoughts?
EDITED: 13 Oct 2017 by JFH
7713.685 In reply to 7713.684
Hi James!
@You : "...It would be useful to have an additional widget: a simple 2 state Switch,..."
+1 For this idea!
I've also another idea, that I have developed some times ago in one of my old Utility nodes (actually I don'r remember which..)
The idea is having for every node, or at least for each node where this thing make sense,
a "on/off switch" that should act as a "pass-trought".
I mean.
When the switch in "ON" then the node will output the data based on its internal code. This is the normal mode.
When the switch in "OFF" then the node will simply output the input data, without making any elaboration.
This could be very useful for example when i simply want to "exclude" the elaboration made by a node,,
while maintaining the whole "node-chain".
I don't know if I made myself clear.
Now, I don't have time to explain better but ASAP I will post an example of what I'm talking about.
Have a nice day to everyone!
7713.686 In reply to 7713.685
Hello Marco,
Logic/split is the switch you are looking for - you only need the button.
Have a nice day
Karsten
7713.687 In reply to 7713.686
how to mirror the result. along the X axis?
Size: 147.6 KB, Downloaded: 177 times, Dimensions: 998x617px
7713.688 In reply to 7713.687
Hello vknw123,
difficult to say - do you use additions. I can't see the details of the picture. Is it possible to send the file?
Have a nice day
Karsten
p.s. It's maybe someting for a native speaker.
7713.689
Hello
About year ago I've made a nw.js version of the nodeeditor. I wrote it for my work. There was buttons, switches, valves, fans etc. I can easylly convert switch and button nodes for using with MoI
EDITED: 7 Mar 2022 by SMIRNOV
7713.690 In reply to 7713.688
Karsten (KMRQUS),
I need to reflect, because not always the object is the same along the Y axis
Size: 127.4 KB, Downloaded: 167 times, Dimensions: 773x570px
7713.692 In reply to 7713.690
Hello vknw123,
at first - an very intersting project!
It seem that you use no extensions. The Standard version of the nodeeditor hasn't a mirror node at the moment. So you have to use the extensions. But there isn't a russian language file. Maybe You are the one that translate it:-) or use it like it is.
Here is a link:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Extract the extensions and copy the folder to /ui/nodeeditor/nodes/
Restart MoI.
Have a nice day
Karsten
7713.693 In reply to 7713.692
Karsten (KMRQUS),
Thank you so much.
works great.
Size: 117 KB, Downloaded: 155 times, Dimensions: 745x517px
7713.694
M.I.A Node - Looking for a Node written a while back gone missing in action from my collection written by one of the Node Masters have tried searching the forum threads but not coming up if anyone can point it out would be great.
It was the 3d Scale Array over a path.
Many thanks
Alex.
Show messages:  1-14  …  615-634  635-654  655-674  675-694  695-714  715-734  735-754  …  895-912
