Parametric design in MoI?
 1-17  …  618-637  638-657  658-677  678-697  698-717  …  898-912
7713.658 In reply to 7713.657
Hi Marco
Here a example of ui extension
Find this line in index.html
loadScripts('core','init');
and change it to
loadScripts('core','init, *');
after this modification NE will load all additional .js files in /core directory
Copy atteched file to /core
EDITED: 7 Mar 2022 by SMIRNOV
7713.659 In reply to 7713.658
Hi Max.
Thank you very much!
ASAP I will study your code and starting to write my UI plugin.
Meanwhile, I want to inform you that I'm getting some strange errors with latest nodeeditor.v.0.97.2017.10.05,
but you already said that is unstable.
Also, as you can see, your UI example loads correctly only the very first time I open it in N.E.
Anyway, please check this video to see what's happening : http://take.ms/hOEL0
I don't know if this may help you but this is the shortcut definition in Moi's ini that I use to open N.E :
Alt+F2=script: moi.ui.createDialog( 'nodeeditor.v.0.97.2017.10.05/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
I stay tuned.
Thanks.
Marco (mkdm)
7713.660 In reply to 7713.659
Hi Marco,
I just forgot how my loadScript function works :)
rename mylib.js to ext.mylib.js and change the line in index.html to loadScripts('core','init, ext.*');
7713.661 In reply to 7713.660
Hi Max.
No problem. Thanks for the tip.
I hope in this weekend to start writing the UI plugin based on your example.
I still don't know what kind of style I want to use.
Anyway it will be minimalist and lightweight.
Obviously, before coding the entire plugin, I will try some prototype and I will ask you if it is good also for you, before I go any further.
Bye!
7713.662 In reply to 7713.661
Hello Max, hello Marco,
some questions about the Icons:
Resolution: 64x64?
Format: png?
Colordepth: 8bit?
Stored in static member e.g.
function Point(){
Point.icon="iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AA....
Will it be excluded from storing in the *.nod file?
Examples for the Icon design - coloured or Grey to get a consistent look?
Thanks in advance
and have a nice day
Karsten
Message 7713.663 deleted 6 Oct 2017 by MKDM
7713.664 In reply to 7713.662
Hi Karsten.
I complete here the previous message.
IF MAX AGREE OF COURSE.
1) 64 x 64 : OK
2) format : Base64 png
3) 8 Bit : OK
4) "function Point() {Point.icon="iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AA...." : OK
5) Style : flat icons
Stay tuned.
Bye.
7713.665 In reply to 7713.664
P.S.
Max, if you think that an overall size of 64x64 it too big for the icon we can use 56x56 or 48x48.
All other measures shall be proportionate to what I wrote in my previous message :
56x56 : roud corner : 7, centered icon : 42
48x48 : roud corner : 6, centered icon : 36
7713.666
Hi Marco, Karsten
1) 64 x 64 : OK
I think 24x24 should be enough for LoDPI displays, and 48x48 or 64x64 for HiDPI.
OK
3) 8 Bit : OK
8-bit png doesn't support smooth transparency gradients. We can't make nice-looking rounded corners using 8-bit format.
So we should use 24-bit png ( or we can make smooth rounded corners using png8+html5+js )
function Point() { ... }
Point.icon ="iVBO...
OK
OK
P.S. Wait.. Does MoI support svg/svgz images? It's a best variant. If not, I would like to advise Michael add support of this format in v.4, and create new MoI interface using svgz icons.
In the nearest future all monitors will be 4k, so vector scalable icons will looks great.
..I'll check it today
7713.667 In reply to 7713.666
Hi Max.
1) @You : "...I think 24x24 should be enough for LoDPI displays, and 48x48 or 64x64 for HiDPI."
Hmm...I think 24x24 it's too small. Maybe 32x32 is better. For HiDPI let's go for 64x64.
How to check DPI in Moi scripting ?
3) @You : "...we should use 24-bit png..."
Maybe there's a little misunderstanding :)
With 8 Bit I mean 8 bits per channel....so 24 bit.
OK
@You : "...P.S. Wait.. Does MoI support svg/svgz images? It's a best variant..."
Ok I wait.
I think, too, that SVG would be perfect.
Now I ask to Michael.
We'll catch up!
Ciao.
Marco (mkdm)
EDITED: 6 Oct 2017 by MKDM
7713.668 In reply to 7713.666
P.s.
Max, about SVG icons I asked to Michael at http://moi3d.com/forum/index.php?webtag=MOI&msg=8613.1
Bye.
7713.669
Hi Marco,
I updated lib example. Now it can add a nodes.
You are free to use any icon size :) We can change it anytime we want.
Unfortunatelly, svg is not supported by MoI, so we should use png.
Maybe later we will make our own vector icon format for NE.
I think it is not bad idea for a plain design icons. We could draw a node icon and convert it to a compact data string.
It will be much smaller than base64 encoded png and can be exported directly from MoI.
7713.670 In reply to 7713.669
Hi Max.
Thanks a lot for this new updated lib! Great job!
But...in this way you've taken all the fun to coding on my own from scratch :)
Anyway...I'm going to use you example code as a solid base to build a new UI for that left panel.
Ok. For the icon size I will go for this solution :
1) If you want, during my spare time, I can design all icons for all standard nodes of NE.
I will design using Affinity Designer, a very powerful vector editor, therefore I won't have any problem with scaling and I will be able to export the icons at any resolution and size.
2) I will design the icons in flat style with these dimensions :
Dark grey rounded box 32x32 px round radius 4px color Hex 373737.
Inner icon max 24x24 flat white or bicolor
This is a real size example :
We can always decide to export the icons from Affinity with different sizes if we see that 32x32 is not good.
Is it OK for you ? if yes I can start the creation of icons and js coding.
3) @You : "...I think it is not bad idea for a plain design icons. We could draw a node icon and convert it to a compact data string.
It will be much smaller than base64 encoded png and can be exported directly from MoI."
I'm sorry but I didn't understand what you mean. Could you please be more clear ?
Thanks a lot and have a nice day.
We'll catch up.
Ciao.
7713.671 In reply to 7713.669
Hi max.
I's sorry if I ping you again but I'm waiting your response before I go any further with icon designing and JS coding for the new NE ui.
My question is at : http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.670
Please, let me know.
Bye.
7713.672 In reply to 7713.670
Hi Marco,
It was just an example. :) I tried to show how your script can interact with ne kernel.
It will be great.
How about HiDPI displays support? It will be better to store 64x64 icons in a node files.
You can generate 24x24 or 32x32 from 64x64 on the fly using js/html5. Also using js you can make rounded corners with any radius you want,
so you don't need draw icons with rounded corners.
In my opinion the icons should be: 64x64, straight corners, png8 (not 24).
>>3) I'm sorry but I didn't understand what you mean. Could you please be more clear ?
In the future we can store icons using our own vector format.
A workflow can be like this:
1. Draw icon using MoI
2. Using script convert the icon to string which describes all colors, lines and curves of the icon.
3. Insert string to node script
NE will render each icon every time when you start it.
7713.673 In reply to 7713.672
Hello Max.
I'm glad to read your reply.
@You : "...How about HiDPI displays support? It will be better to store 64x64 icons in a node files.
so you don't need draw icons with rounded corners."
Ok Perfect!!
So, before coding a bunch of JS code to create my own UI for NE based on your example,
ASAP, first of all, my first step will be to draw all the icons!
So, to recap :
1) I will draw all the icons in Affinity Designer to build them in vector mode so I can easily modify them without any quality loss.
2) The icons will be exported in 64x64 PNG24 , flat, squared, with background set to Hex 373737
3) Each icons will have a centered glyph, white or two-colors, flat, no shadows, size 48x48
4) I will add the rounded corner radius with js/css to the icons squared background
5) As you said all the icons will be stored in a node files.
I will ask you an example of how do you think this node file should be done.
So, everything is fixed :)
Almost...
Because, Max, again... I think that there is a misunderstanding...
You wrote : "...In my opinion the icons should be: ...png8 (not 24)."
Why png8 ? A PNG8 is limited to 256 palette entries, while a PNG24 can have 16 million different colors.
And PNG24 will be rounded much better with js/css than PNG8 that would be pixelated.
So, I'd like to use PNG24.
I wait your final response about this last point and then I can start this new project.
Please let me know and if all is fine for you, please write "OK. YOU CAN START" at the end of your message.
I stay tuned.
Ciao!
7713.674 In reply to 7713.673
Hi Marco
Yes, I know :) 256 colors will be enough for a flat design icon, and png8 about 30% smaller than png24.
Each 64x64x24bit icon will be about 2kB in base64.
But at the moment it doesn't matter.
Let's make png24 icons.
OK. YOU CAN START
7713.675 In reply to 7713.674
Perfect! Thanks.
I will create the very first icon and for the moment I will put it into your example code, just to see how things go.
Then I will show you the result and if all will be fine I will create all other icons, coded in Base64 and placed into a specific node file.
We'll catch up :)
Ciao!
7713.676
Stuck.
I'm trying to run 0.97 in Windows 10 latest version.
Node Editor comes up OK with all the normal buttons New, Load, Save, Apply Run, Step.
And all is well if I load the attached file strainer 01.nod
But, when I load either strainer 02.nod or strainer 03.nod all the buttons are blanked out except New, and Load.
I suspect that I've created this problem by trying to use the RMB copy and paste function with the Macro feature the wrong way.
Anyway out of this mess outside of starting again?
And is there a specific order order in which the RMB copy/paste/macro system should be used?
Mike.
EDIT.
Tried strianer 03.nod in 0.96 no good.
Tried in 0.95, buttons back so could run and save. Saved with new name but still no good when loaded into 0.97. No Run, no Save.
EDITED: 9 Oct 2017 by MGG942
7713.677 In reply to 7713.676
Hi Mike
Nodeeditor blocks Save/Load/Run function when you load nod-file with missed nodes.
02 and 03 contains PatternSelArray node. Install extension file with this node or remove it.
Show messages:  1-17  …  598-617  618-637  638-657  658-677  678-697  698-717  718-737  …  898-912
