Parametric design in MoI?
 1-20  …  601-620  621-640  641-660  661-680  681-700  …  901-912
7713.641 In reply to 7713.640
So Max's CubePts is a macro container, which can be opened.
Double clicking on a macro container also opens it in a new window with a back button.
I cannot open more than one macro at a time...
EDITED: 1 Oct 2017 by BEMFARMER
7713.642 In reply to 7713.640
>>I guess a MACRO is saved by saving a .nod file to the Macro directory?....There is a little box which says Macro.....<<
You need for example, to export the macro "cubePts.nod" out of Max's original "macro.nod" file, like so:
then it & others can be imported into a new project like so:
Hope this helps
EDITED: 2 Oct 2017 by JFH
7713.643 In reply to 7713.642
About this example CubePtrs.nod
It's only the node "CubePtrs" who is saved or the Node "CubePtrs" + Knob + Slider + OutPut who is saved as "Macro A" ?
7713.644 In reply to 7713.643
>>It's only the node "CubePtrs" who is saved<<
Yes, the macro can be exported with any name, though it makes sense to give the .nod file the same name as the macro within.
.>>or the Node "CubePtrs" + Knob + Slider + OutPut who is saved as "Macro A" ?<<
No, I only included "MacroA" highlighted to illustrate that multiple macros may be imported into a project.
The Knob + Slider + OutPut will not be included in the export.
7713.645 In reply to 7713.642
Thank you James, that did help. You must have a Mac export window.
I was incorrectly thinking that detailed views of multiple Macros could be viewable in one window, at the same time.
An attempt to document the Macros feature:
NodeEditor MACROS
1. To create a new Macro container:
In a nodeeditor window, right click on the screen, and select Macro, then select Create.
This creates a small box labeled Macro,
which is the Macros/Container as per the i Node Info window on the right of the screen.
(In effect this small box is a condensed second screen, a "Back" screen.)
2. There are two ways to open the Macros container and see the "Back" screen:
a. Double click on the Macros container.
b. Right click on the Macros container and select Open.
In the info window, the name of the Macro container may be changed, for example to QuartzClock.
3. To build a Macro:
In the "Back" screen, build what amounts to a .nod program.
Right click on an open area, select Node, then select a particular node,
for example Node/Basic/Quartz, also select Node/Widgets/Slider and change its name to Frequency.
Color can also be changed.
Right click on an open area, and select Output. (Input can be selected if needed.)
Wire Frequency to Quartz, and Quartz to Output.
Select the Back button at the top of the screen.
This returns to the main node screen, and the Macro container now has an output dot.
Right click on the Macro container and Export it to the Macro subdirectory, with an appropriate name.
Note that the Macro container "Back" window may also have other Macros loaded and wired in as well,
but they will appear as condensed Macro containers (with sub Back windows).
Nested Macros containers:
Note that steps 1, 2, and 3 can be repeated in a second condensed Macros container opened in the "Back" window,
and have also have subordinate "Back" window(s), so as to make nested Macros.
In summary, the Macro appears as a "condensed" .nod file, until opened in a "Back window."
This can "unclutter" a complicated and large .nod program file.
I do not see any way to view the entire detail of some wired node ensemble of multiple nodes and macros, in one window.
Importing a previously saved Macro is straightforward, and not documented here.
Multiple saved Macros may be imported to the main nodeeditor screen, but appear in "condensed" form there, and may be wired together
along with regular nodes.
EDITED: 12 Nov 2017 by BEMFARMER
7713.646
Hi Marco,
>>I would like to find some extra spare time (..it's a hard challenge) to write some sort of "UI Control Panel" for NodeEditor, with buttons/tabs/expandable sections, all dynamically created, in order to give a different UI other than menu, that is very uncomfortable.
Do you think is it feasible ?
Sure, the UI definetely needs redesigning. I'm not a designer, so I can't create good interface by myself. Maybe someone could make new interface for NE.
Brian,
thank you for documentation!
7713.647 In reply to 7713.646
Hi Max.
@You : "...Sure, the UI definetely needs redesigning. I'm not a designer, so I can't create good interface by myself. Maybe someone could make new interface for NE."
Well!
ASAP I hope to start writing a UI plugin with some nice look and above all with good UX, in order to speed up things in NE (or...PE...Project Elephant).
I also think that currently what we are really missing in NE is the support for keyboard shortcut,
but unfortunately I think that this can't be done, because I suppose that all keyboard events are captured and processed by Moi.
Anyway...let's change at least the UI!
I'll keep you up-to-date about this work.
Ciao!
7713.648 In reply to 7713.647
Hi Marco, re: keyboard shortcuts in node editor - for v4 it will be possible to implement OnKeyDownEvent() and OnKeyUpEvent() script functions on a dialog and when the dialog has focus MoI will look for those and call them.
It's used also by the new shortcut key definition dialog "ShortcutKeyDialog.htm" and there are comments in that file about how it works.
7713.649 In reply to 7713.648
Hi Michael.
@You : "...for v4 it will be possible...".
Perfect!! Thanks a lot.
"ShortcutKeyDialog.htm"....is in V4.....right ? I think so.
7713.650 In reply to 7713.649
Hi Marco,
Yes, that's correct.
7713.651
v.0.97
Removed Clone function
Added Copy/Paste functions (also you can use Ctrl + drag)
Removed buttons icons (all icons generating on the fly)
I've started an optimization process. About 650 lines in main.js has been changed since v.0.96
This version is unstable. Waiting for a bug reports.
EDITED: 7 Mar 2022 by SMIRNOV
7713.652
Hi Marco
Good news. What kind of interface you want to make?
7713.653 In reply to 7713.651
Thanks Max for latest update,
Copy/Paste will be a productivity boon in general use, and...
ingeniously answers my call for a "make macro" function
by allowing to paste into a new macro, so kudos!
This is just a thought, but would it be possible to have a
"Copy & Remove" option (or "Cut" in Adobe nomenclature)?
It would be handy when cleaning up node circuitry, by copying out
groups of nodes to package into a macro, without then have to
reselect the same nodes to remove. If you agree that this would be
useful, then perhaps, sometime in the future this option could be included.
For now, I'm so happy with the new functionality, especially
Ctrl + drag copying! This is something that I have long desired.
Thanks again
P.S. >>Removed buttons icons (all icons generating on the fly)<<
This may be a dim witted question, but could explain this
or illustrate with image. I don't know what are "buttons icons"
The only things that would fit the description that I can see is:
"NEW","LOAD","SAVE" etc. but they have not been removed.
EDITED: 4 Oct 2017 by JFH
7713.654 In reply to 7713.652
Hi Max.
@You : "...Good news. What kind of interface you want to make?..."
Well...I still don't know.
I have in mind some kind of simple "buttons driven" UI with expandable/collapsible grouping of buttons.
I want to start with a simple thing and to see how it works.
Something like this (please don't care about colors or icons, are only examples)
As you can see I wrote "dynamically generated" (also with icons if possible).
I will need to parse in some way the .js source code of P. Elephant to extract the names of the various nodes.
I think that with just this simple UI working with P. Elephant will be much, much faster.
Please let me know what do you think about it.
Cheers.
Marco (mkdm)
7713.655 In reply to 7713.652
Hi Max.
P.s....
@Me : "..(also with icons if possible)..."
I think it's easily feasible for example assuming " icon file name.png = node name".
Icons could be placed into a folder inside the root of P.E.
Anyway...let me know.
Ciao!
7713.656
>>This is just a thought, but would it be possible to have a "Copy & Remove" option (or "Cut" in Adobe nomenclature)?
I added this function today morning.
>>The only things that would fit the description that I can see is: "NEW","LOAD","SAVE" etc. but they have not been removed.
In v0.96 and earlier versions the icons was stored in /imgs directory as png files. In v0.97 this directory has been removed. Now NE engine draws icons automatically every time you you run it.
Now you can change color of the icons in colors.js file.
Marco
>> want to start with a simple thing and to see how it works. Something like this (please don't care about colors or icons, are only examples)
It's OK. Looks good. I'll make small change in init.js (or index.html) today, so you can add custom buttons and windows without making any changes in the core files.
I'll send you an example today evening.
>>I think it's easily feasible for example assuming " icon file name.png = node name". Icons could be placed into a folder inside the root of P.E.
Huge amount of separate png icons will affect on overall engine performance. Especially when you open NE window.
The better and more clear way is store the icons inside every node as base64 encoded image.
7713.657 In reply to 7713.656
Hi Max.
@You : "...It's OK. Looks good....I'll make small change in init.js...I'll send you an example today evening."
PERFECT!!!
@You : "...The better and more clear way is store the icons inside every node as base64 encoded image...."
Ok, I agree. Every node must expose a property for the based64 image,
so I can read it in runtime during the generation of the graphical menu UI.
And each author of any node must fill that information.
Anyway, this should be optional.
If an author doesn't want to provide any icon for its node he is free to do that.
But if an author want the icon displayed for his node he must fill that property of the node with the based64 data.
Right ?
I stay tuned.
Ciao.
7713.658 In reply to 7713.657
Hi Marco
Here a example of ui extension
Find this line in index.html
loadScripts('core','init');
and change it to
loadScripts('core','init, *');
after this modification NE will load all additional .js files in /core directory
Copy atteched file to /core
7713.659 In reply to 7713.658
Hi Max.
Thank you very much!
ASAP I will study your code and starting to write my UI plugin.
Meanwhile, I want to inform you that I'm getting some strange errors with latest nodeeditor.v.0.97.2017.10.05,
but you already said that is unstable.
Also, as you can see, your UI example loads correctly only the very first time I open it in N.E.
Anyway, please check this video to see what's happening : http://take.ms/hOEL0
I don't know if this may help you but this is the shortcut definition in Moi's ini that I use to open N.E :
Alt+F2=script: moi.ui.createDialog( 'nodeeditor.v.0.97.2017.10.05/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
I stay tuned.
Marco (mkdm)
7713.660 In reply to 7713.659
Hi Marco,
I just forgot how my loadScript function works :)
rename mylib.js to ext.mylib.js and change the line in index.html to loadScripts('core','init, ext.*');
Show messages:  1-20  …  581-600  601-620  621-640  641-660  661-680  681-700  701-720  …  901-912
