Parametric design in MoI?
 1-15  …  576-595  596-615  616-635  636-655  656-675  …  896-912
Nice "light blue" cursor.
The quartz node, with high frequency input, really moves the motor rapidly.
Changed the nodebox for motor rod from green to blue. (trivial)
Three+ ways to start nodeeditor94, for "Light" color version. (Somewhat relevant to default "dark" version and perhaps custom colors, and Mod version.)
1. By Shortcut key: (My example keys shown here: Ctrl+Alt+M for Dark, and Ctrl+Alt+N for Light.)
Light version: Ctrl+Alt+N moi.ui.createDialog( 'nodeeditor/index.html?Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Dark version: Ctrl+Alt+M moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
2. By using MoI command window: Highlight one of the lines above beginning with moi.ui.createDialog. In MoI press keyboard Tab, Ctrl+v, enter.
3. By CustomUI, (Involves editing, so this is for knowledgeable/experienced users, and are vague, as the difficulty level could vary.):
a. Under ui/customui, copy item 99 to say new item 97 and edit/modify for Light parameters.
or b. Under ui/customui, copy item 99 to say new item 98, edit/modify, and add subfolder link for 3rd party Mod nodes.
EDITED: 18 Sep 2017 by BEMFARMER
7713.617 In reply to 7713.608
Hello Max,
thanks for the update!
>>>And one more thing..
will be announced later
I am curious:-)
Have a nice day
Karsten
p.s.: An older and small Problem: While running in Progress and Switching Basic\Extract by RMB to Numbers the node crahes - it seem that the open Input won't be catched.
7713.618
Fantastic job Max!
7713.619 In reply to 7713.617
Hi Karsten,
basic.js line 449 should be: inp = this.getInputData(0, [0]);
Fixed. Thank you.
7713.620 In reply to 7713.615
Hi Mike,
>>On my system on click of the mouse wheel gives a change of 5% of the maximum value.
Each step = range/20
>>Is there a way to change this to give a much smaller change, say 1%?
interface.js line 134 and 254
change v += delta/20; to v += delta/100;
UPD:
Added dynamic delta adjusting
EDITED: 7 Mar 2022 by SMIRNOV
French Version of the update release ;)
7713.622 In reply to 7713.620
Hi Max.
Only a simple question about update of Project Elephant, in general.
Will you release every further update, big or small, using your moi.maxsm.net web site (Nodeeditor AddOns) ?
I hope so, because in this way everyone can easily get the latest official version,
without the need, as happened so far, to search here and there single files to update our local version of Elephant.
For example, in your last message you have attached the file "interface.js".
if I instead pick the "nodeeditor.v.0.94.2017.09.18.zip" file currently stored into your web site, will I get the latest update of Elephant including this new "interface.js" file ?
In order to make our life easier :) I kindly ask you to publish every updates in your web site or in one single zip file placed everywhere, containing the whole Project Elephant folder.
In this way we can simply unpack the folder and overwrite every old local file with one simple operation.
Thanks again and have a nice day.
7713.623 In reply to 7713.620
Thanks, Max.
Mike.
7713.624 In reply to 7713.622
Hi Marco,
Yes. I will upload every new version to my site. Use this links to download: http://moi.maxsm.net/nodeeditor or http://moi.maxsm.net/files
No, the file will be same. Updated interface.js (and all other updated files) will be added to a next release.
Every nodeeditor release (nodeeditor.v.0.xx.xxxx.xx.xx.zip) always contains all project files. In some cases I can upload some changed files separately, before the next release. In that case you need to copy files over the existing ones.
7713.625 In reply to 7713.624
Hi Max.
@You : "...Yes. I will upload every new version to my site...
Every nodeeditor release (nodeeditor.v.0.xx.xxxx.xx.xx.zip) always contains all project files. In some cases I can upload some changed files separately, before the next release. In that case you need to copy files over the existing ones..."
This is Perfect. Thanks Max.
I've been waiting a long time to see the end of the never-ending-story of mixed version of P. Elephant and : "why this .nod file doesn't work? Where is the missing .js file or node ? Where is the download link ?"
I'm a software developer and one of the things I hate most is the versioning mess.
Thanks again!
Bye.
Marco (mkdm)
7713.626
Hi Max
I was wondering if you could improve Math and Math Point nodes
increasing the opportunity to place input-
Now we get to the letter d- , but
in the case of complex formulas there is need for more inputs
thank you-
Have a nice day
al
7713.627 In reply to 7713.626
Hi Al,
>>I was wondering if you could improve Math and Math Point nodes increasing the opportunity to place input-
Maybe later but not now. At the moment my high priority task is bugfixing and optimization. Also I prepare new features for v.1.xx releases.
Right now I would prefer do not touch well working code.
7713.628 In reply to 7713.627
Hi Max!
@You : "...Right now I would prefer do not touch well working code..."
+1 for this wise choice :)
Bye.
7713.629 In reply to 7713.626
Hello Al,
in many situations it should be possible to split calculations in steps, to get more parameters involved.
a+b+c+d+e=x - > a+b+c=m; d+e=n; m+n=x
I know that you already use this workaround and it has the advantage that very complex formulas will be broke down for a better understanding of the structure.
So have a nice day
Karsten
p. s. Nevertheless it is always a good idea to push boundaries away;-)
7713.630
Well..
In fact I planned this feature for 1.xx versions, but two last evenings was enough to take mess with it.
Macro nodes! :)
Other changes:
Added dynamic mousewheel delta adjusting (Knob/Slider nodes)
Fixed Extract node bug
Fixed Polyline nodebug
Fixed Mouse scroll glitch
Changed Node info windows scroll method
Minor interface improvements
Attention!
I've made changes in getInputData function in core.js.
It's one of the most important and frequently used functions in nodeeditor.
Please test your node projects! Everything should work good.
What a productivity!
7713.632 In reply to 7713.630
Bravo Max,
Thank you for Macro function. It'll greatly enhance legibility of node circuitry so as to not intimidate non-noders.
Will it be possible to marque a group of nodes and make them into a macro? Like so:
Also, will there be a way of loading multiple nod files into Nodeeditor so that macros may be shared between projects? (assuming that there is not to be a new file type for macros)
Thanks again for your inspiring work
7713.633 In reply to 7713.632
Hi James
Yesterday I wrote Macro Export / Import tool. It can import nod files as macro. Wait for a next nodeeditor release.
Yes, but not in the next release.
7713.634 In reply to 7713.633
Thanks Max,
>>Yesterday I wrote Macro Export / Import tool. It can import nod files as macro. Wait for a next nodeeditor release.<<
This will be brilliant! The ad hoc approach to node wiring can be anything but systematic, so to be able to encapsulate working chunks into macros and then reimport into a overall scheme will provide a much needed layer of structure; so kudos.
Yes, but not in the next release<<
I look forward to then!
I greatly appreciate all your hard work
EDITED: 25 Sep 2017 by JFH
7713.635
Hi Max
Great excitement and gratitude for the
continuous improvements
Good job....
we look forward to the next .....
Thanks so much ,
have a nice day-
al
Show messages:  1-15  …  556-575  576-595  596-615  616-635  636-655  656-675  676-695  …  896-912
