Parametric design in MoI?
 1-16  …  557-576  577-596  597-616  617-636  637-656  …  897-912
7713.597 In reply to 7713.595
Hi Al,
Yes, I have plans to add a macro-nodes to this project, but you have to wait a few months.
Right now I'm pretty close to v1.0 release. But then I'll stop the development for an indefinite time. I'll continue this project after the first MoI V4 Beta release.
7713.598 In reply to 7713.597
Hi Max!
Thanks a lot for the latest Project Elephant update.
@You "Right now I'm pretty close to v1.0 release. But then I'll stop the development for an indefinite time. I'll continue this project after the first MoI V4 Beta release."
I totally agree with you.
Until the first beta of V4 it's ready it's almost useless to waste effort and energy
adding features to the current Elephant.
See you.
A Thank you to Max for version .93, which was quick to install.
As I've previously posted some months ago, with only slight changes:
1. The yellow crosshair cursor can be added by including cursor.png.
2. Under \core, editor.js can be edited for a lighter background by replacing,
at about line 26, replacing 62 with 250, 3 places, and
at about line 29, replacing 50 with 200, 3 places.
(I Commented out the two old lines, and replaced them with the higher numbers.)
3. To activate quartz timer/clock/counter, under \nodes, edit out appropriate comments (\\) in basic.js.
The motor2Quartz.nod worked well with motor2.3dm.
The epiCycloidQuartz1.nod worked well with Cycloid11to1_03.3dm.
7713.600
Hi Max
Thank you for the reply.
As usual............ enlightening........
thanks to the new tools that have implemented
Was wondering, could you show us
some other examples
with the application of the new nodes
Progression , Split , and Extract ?
Thanks in advance
Have a nice day
best
al
7713.602 In reply to 7713.600
Just wanted to chime in a thank you for this project! I was wondering if there will be assemblies/hierarchies in V4, can we use the node editor to make the workflow more like Solidworks (MoI is so much better for quick sketching, however complex assemblies are a problem).
A few items to add to the nodeeditor wiki:
Shift+doubleclick on a node will also open the info panel.
Multiple nodes may be displayed in the info panel by shift+clicking on additional nodes.
There is a rounded rectangle to the left of each node name.
Clicking on the rounded rectangle to the left of the node name, will minimize/maximize the node.
The rounded rectangle is grey for many nodes. If red, the associated js node is likely not installed.
For the output node, the color of the rounded rectangle is an indication of the status of the node.
Like a traffic stoplight, green indicates a favorable setup.
Red indicates a problem. Orange indicates some intermediate state (?)
7713.604 In reply to 7713.603
Hello Brian,
any help is welcome. So please ask Michael to get an account to the wiki. so you can place all the informations directly into it.
Feel free to Change everything you want in it - it should be a living documentation.
Have a nice day
Karsten
7713.605 In reply to 7713.604
Thank you Karsten,
Just sent an email message to Michael, requesting access.
7713.606 In reply to 7713.605
Hi Brian, you're all set up now. Thanks!
7713.607 In reply to 7713.606
Thank you Michael.
7713.608
Nodeeditor v.0.94
- Added initial suport of color schemes. Edit colors.js file to create your own color scheme. You don't need to replace all colors in a custom color scheme, just colors you want to override.
Use custom color scheme name as parameter when you start nodeeditor.
Example: moi.ui.createDialog( 'nodeeditor/index.html?Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
- Added Quartz node (now it works exactly as I planned)
I've not tested it well, so there can be bugs. Waiting for a bugreport.
- Added Edges switch in Output node
- Added mouse wheel support for Knob and Slider nodes (I like it!)
- Added JSON.prettify funcion which affects on nod-files internal structure.
- UI tweaks
- And one more thing..
will be announced later :)) v.0.95 in progress ;)
P.S. Page added http://moi.maxsm.net/item/56/category/3
P.P.S. 18.09.2017 Bug fixed in nodes/basic.js (Edge switcher)
EDITED: 7 Mar 2022 by SMIRNOV
7713.609 In reply to 7713.608
Thank you very much Max for this long-awaited update.
A triple Hip, hip hurrah!
Max is back.
7713.610 In reply to 7713.608
Hi Max.
I was playing for about two minutes with the new node editor and I probably don't know how it should work,
but I'm pretty sure there's a bug regarding the "Edge switch on-off" of the "Output" node.
For what I've tested, when you switch to off and then to on the edges never appears.
Please watch this brief video : http://take.ms/w3kGK
Bye.
Max the return
Message 7713.612 deleted 19 Sep 2017 by JFH
7713.613
Marco, thank you. Bug fixed. Nodeeditor reuploaded. (nodeeditor.v.0.94.2017.09.17.zip -> nodeeditor.v.0.94.2017.09.18.zip)
7713.614 In reply to 7713.613
Thanks!
Bye.
7713.615 In reply to 7713.608
Hi, Max.
Love the mouse support for the slider and knob.
On my system on click of the mouse wheel gives a change of 5% of the maximum value.
Is there a way to change this to give a much smaller change, say 1%?
BTW I've checked in Control Panel and my mouse wheel is set for the minimum change of 1 line.
Mike.
Nice "light blue" cursor.
The quartz node, with high frequency input, really moves the motor rapidly.
Changed the nodebox for motor rod from green to blue. (trivial)
Three+ ways to start nodeeditor94, for "Light" color version. (Somewhat relevant to default "dark" version and perhaps custom colors, and Mod version.)
1. By Shortcut key: (My example keys shown here: Ctrl+Alt+M for Dark, and Ctrl+Alt+N for Light.)
Light version: Ctrl+Alt+N moi.ui.createDialog( 'nodeeditor/index.html?Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Dark version: Ctrl+Alt+M moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
2. By using MoI command window: Highlight one of the lines above beginning with moi.ui.createDialog. In MoI press keyboard Tab, Ctrl+v, enter.
3. By CustomUI, (Involves editing, so this is for knowledgeable/experienced users, and are vague, as the difficulty level could vary.):
a. Under ui/customui, copy item 99 to say new item 97 and edit/modify for Light parameters.
or b. Under ui/customui, copy item 99 to say new item 98, edit/modify, and add subfolder link for 3rd party Mod nodes.
EDITED: 18 Sep 2017 by BEMFARMER
Show messages:  1-16  …  537-556  557-576  577-596  597-616  617-636  637-656  657-676  …  897-912
