Parametric design in MoI?
 1  …  422-441  442-461  462-481  482-501  502-521  …  902-912
For a lighter canvas, as previously discussed:
The canvas background color is now coded at lines 24 and 27 in the litegraph-editor.js file.
grid.png is no longer used.
Line 19 seems to be unnecessary (?). Commenting it out seems to do no harm(?)
line 19: // graphcanvas.background_image = "core/imgs/grid.png";
Max's line 24, commented out: // bgvctx.fillStyle = "rgb(62,62,62)";
Replaced for a Lighter color: bgvctx.fillStyle = "rgb(225,223,217)";
Max's line 27, commented out: // bgvctx.strokeStyle = "rgb(50,50,50)";
Replaced for a Lighter color: bgvctx.strokeStyle = "rgb(208,206,201)"
Also changed the cursor from "crosshair" to "default" in line 4 of litegraph.css.
(I have not had time to test any nodes.)
Hi Max and good morning,
Considering that "Project Elephant" has become increasingly hefty,
I think that now it would be desirable, in order to leverage this wonderful tool,
that you create a specific topic for "Project Elephant tech-docs and user guide".
I know that many information are scattered here and there in this forum,
and I guess that it would be a time consuming job,
but this would greatly help us to use and learn this tool.
Best,
About nodes goto section Learn! http://www.grasshopper3d.com/
Amazing documentation : videos, books, articles, theory etc...
EDITED: 6 Oct 2016 by PILOU
7713.465 In reply to 7713.464
Oh yeah.....I already knew that web site.
It's a wonderful place to learn Generative Modelling (in truth also too technical for my very basic mathematics knowledge :)
But, Max is almost alone in its developing, while grasshopper3d.com has a lot of people behind it!!
From Max it would be fine also a coarser documentation...
Best,
7713.466 In reply to 7713.457
Hello Max,
while testing some node-experiments, I saw some inconsistencies with the interpolation node. Maybe I didn't understand the method right, but I think that spline interpolation gives better results. So I made some investigations I want to share.
By the way, It was possible to integrate the function in the modes (long,short) of V0.8. In V0.85 I don't have success.
Have a nice day
Karsten
7713.467 In reply to 7713.465
Hello Marco,
"But, Max is almost alone in its developing, while grasshopper3d.com has a lot of people behind it!!"
>>> Well, let us make some nodes:-)
PathArray (Performace now 3times faster for numarrays with reduced load of the moiDB), ScaleUVW
Have a nice day
Karsten
7713.468 In reply to 7713.467
Hi Karsen,
I know that you are very well-versed in mathematics, unlike me :(
I hope that Max will include your nodes improvements into the next versions of Elephant!
Nice day,
- Marco (mdkm)
7713.469
Hello, Max
First of all thanks for the Great Work you are doing ....
I ask if it was possible to make some improvements in the future:
1- We could add on- (Range Nod) various inputs to determine;
the beginning
the end
n°of divisions
so all you can handle with Slider or Knob
2- Create a Node Series with input, like Range
the beginning
the step
returning multiple values
3- Restoring and improving Plane/Frame
with the possibility of displaying or not in the Work area (Canvas)
to improve the use (See Karsten's post .... )
I know everything you're doing, it's completly free ,
a total benefit of us users Moi....
and I would not think I was a bit rude to make such requests-
Have a nice Day ,and
many thanks for your patience-
al
Size: 276.7 KB, Downloaded: 142 times, Dimensions: 1920x1080px
7713.470
Hi Friends
I want to share with all of you my humble
learning exercise
I hope it is of help to some beginners like me
al
Size: 299.1 KB, Downloaded: 181 times, Dimensions: 1920x1080px
7713.471 In reply to 7713.469
Hi speedy,
Thanks for sharing these ideas!
Some of your proposals remind me the "PatternSelArray" nodes that I have started to write some times ago and I never finished (was for the 0.65 version of Elephant).
Everything about "patterns and arrays" is my hobbyhorse !!
These are my original posts :
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.341
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.353
Best,
7713.472 In reply to 7713.470
Wow speedy,
....fantastic Job!!!
7713.473
Hello Karsten
By now you have become my adviser, and I hope you can tell me
how to solve my problem-
During v.077 and versions v .080
I tried to play some learning exercises -
With the advent of the v. 085 I have removed from the folder (nodeeditor)
all folders into of the old version, and I just added those relating at the latest version .....
Now , if I try to re-open the old files appear to me
error messages on the Canvas...
How can I overcome the problem ...
Possible that there is no compatibility between the old version
and the new.......
I attach a file that can not be loaded , and
I hope you can help me , and tell me how to fix it-
Thank you and excuse me if you abuse your time
and your patience-
Best
al
Size: 364.2 KB, Downloaded: 169 times, Dimensions: 1680x1050px
7713.474
I have 3 different objects: a, b, c.
How do I linear array them randomly? For instance a,a,b,a,c,c,a,b,b,a etc..
My main purpose using nodeeditor is random management of objects, but I can't seem to understand.. I cannot find a "linear array" node, only circular.
M.
7713.475 In reply to 7713.473
Hello Al,
I had a look at the picture and downloaded the nod-file. The problem are all the frame-Nodes in your file. V0.85 hasn't Frames - have a look to Max post, but you can use point and rotatePoints for the same function. So connect the inputs of ellipsoide and polygon with the point output of the sin/cos stuff following point and everything should work.(Maybe replace polygon and reconnect it)
Have a nice day
Karsten
7713.476 In reply to 7713.469
Hi Al,
Your experiments are very impressive! Great work.
>>Node Series with input, like Range, the beginning, the step, returning multiple values <<
Yes, a series node would be useful, but in the interim you can use "Const" node to input series arrays,
giving greater clarity to your node diagrams.
-James
EDITED: 25 Apr 2019 by JFH
7713.477 In reply to 7713.476
Hello James, Hello Al,
the attached nodefile shows a way to generate a numarray. You can also put more values in a const-node as a replacement for the slider.
Have a nice day
Karsten
7713.478 In reply to 7713.476
Hi James,
Thank you very much your experiments!
Just a little debug info.
Running your .nod file and assigning to Ellipsoide node, a "Mode" other than Union, that is Long or Short,
Moi always crashes.
Best,
7713.479
Thank you!
Marco
>>It is necessary that you provide us with an updated and complete technical documentation of all the nodes, or at least of all the inner changes that this new "Project Elephant" has.
Sometime ago a asked community to help me with documentation. I haven't enough time even for coding :) Could someone help me with that? Of course I can provide all information about this project.
>>Instead of shortcuts, it would be possible when you have time, to have a control panel with simple buttons in order to have a fast access to all nodes
with one single click ?
I'll think how to implement it, but not instead of shortcuts :) I definitely need shortcuts. Copy-paste.. run-stop.. load-save etc..
Frenchy Pilou
>>Does it possible Expand / Reduce all nodes in one time ?
It's possible. I already thought about this.
>>does it possible to have the current name of the current file's node beside the Name of the version ?
I tried to do it, but MoI restricts title change from javascript. Maybe Michael could help us with that.
Brian
Thank you! I'll add a bright color scheme in the nearest future
Marco
>>Considering that "Project Elephant" has become increasingly hefty, I think that now it would be desirable, in order to leverage this wonderful tool, that you create a specific topic for "Project Elephant tech-docs and user guide".
I'll make it right after v.1.0 release
Frenchy Pilou
Thank you. I'll read it tomorrow
Karsten
Spline interpolation produces values outside the range. I prefer to use different interpolation methods for every particular case.
I can implement spline interpolation method later.
I decided to not integrate it as processInOut method. It will make this fuction more complex and less flexible. Also while playing with interpolation, I understood that I often need different interpolation modes in the same time. For example linear method for X and Y coordinates, and CatmullRom for Z coordinate.
Thank you! I'll check it tomorrow.
Marco
I'll make a separate directory for custom script and extensions. Elephant will load them automatically.
Of course I'll add good stable nodes in the main node set.
Al
>>1- We could add on- (Range Nod) various inputs to determine; the beginning the end n°of divisions so all you can handle with Slider or Knob
If I understood clearly, you already can do it using the Interp node. You need to set Linear interpolation, range and number of divisions.
>>2- Create a Node Series with input, like Range/ the beginning/ the step/ returning multiple values
I'll think about Series node. Thank you.
>>I want to share with all of you my humble learning exercise
Great! I like it!
>>Possible that there is no compatibility between the old version and the new.....
Yes, I've removed the Frame node because the latest version of RotatePts makes exactly the same. Unfortunately I forgot to add this node to compatibility.js and enable Long mode support. I'll fix it in the new version.
wastzzz
You can use Random node and then Math (floor(a*3)). You will get group of values from 0 to 2. (something like 1,2,2,1,0,1,1,0,2,2)
7713.480 In reply to 7713.478
Hi Al & Marco
Al, sorry my last .nod file was an earlier version than screen grab.
I have attached new file incorporating Karsten's clever suggestion
for Range/Interp series output.
>>other than Union, that is Long or Short, Moi always crashes<<
Marco, yes I revised Al's original .nod file so I had not tried alt modes.
-James
7713.481 In reply to 7713.480
Hi James, re: ellipse revolve - it's built in to revolve that it trims any curve that crosses the revolve axis so a closed ellipse will internally get converted into a half ellipse for the revolve.
If it didn't do this and actually allowed you to revolve a closed curve, the resulting surface would have messed up normals, with half of it having a normal pointing inwards and the other half pointing outwards.
Show messages:  1  …  402-421  422-441  442-461  462-481  482-501  502-521  522-541  …  902-912
