Parametric design in MoI?
 1-13  …  394-413  414-433  434-453  454-473  474-493  …  894-912
7713.434 In reply to 7713.433
Hello Al,
I think that Max hasn't released the node, typically he post also the exampe.nod file for new features -so we have to wait:-)
Have a nice day
Karsten
7713.435 In reply to 7713.434
Thanks Karsten ,
I thought so, but I was not sure
best
al
7713.436
Hi guys
I was busy few days, so I didn't wrote anything since tuesday.
Here is small announce for the new version:
PolygonPts node (done)
TransformPts node (done: twist, rotate; to do: explode)
Interpolation node (to do)
ConvertPts node improvements
pushFrame rad/deg bug fixed (again) :)) I accidentally wrote Math.pi instead of Math.PI in the last version.
I don't know when I will release the new version. Maybe this Sunday.
7713.437 In reply to 7713.436
Good to know! Thanks a lot!
7713.438 In reply to 7713.437
Sweet sounds to my ears.......
do not forget (tutor) exercises for beginners like me-
Great
al
7713.439
I am testing it and it's great! Thanks.
Question for newbies: how do I extrude some shapes randomly? I can generate a random number but of course the number is used for every extrusion.
M.
7713.440 In reply to 7713.439
maybe you have to set Long rather than Short
in the field math
al
7713.441
PathPoints:-) only integration of the startframe evaluation is missing at the moment!
Have a nice day
Karsten
EDITED: 21 Nov 2016 by KMRQUS
7713.442 In reply to 7713.430
Hello James,
I had make some tests with the average-mode and found two bugs. If you want, you should correct this two lines:
r.push((e[1]-e[0])); //error corrected was r.push(2*(e[1]-e[0])); !!!
r.push((e[i]-e[i-1])-((r[i-1]*h[i-1])/u[i-1])); // error corrected was r.push((e[i]-e[i-1])-(r[i-1]*h[i-1]/u[i-1]));!!!
in basicFunctions.js -splineMap-function.
Have a nice day
Karsten
7713.443 In reply to 7713.442
Thanks Karsten,
It fixed an anomaly in interpolation with > 3 values in radii input series
as well as crashing bug if U,V or W input centre value < the number
of values values in radii input series.
I can't wait until Max has finalised the foundations of node editor,
to see what you build upon it.
Keep up the great work
EDITED: 25 Apr 2019 by JFH
7713.444 In reply to 7713.443
Hello James,
thanks for the reply. If you want to test another node, please test this one. But first you have to correct pushFrame in litegraph.js as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.436
PathArray in Points2.js generates an aligned pointarray along a curve. ShowFrame shows now all Frames in a pointarray - I think useful for test.
Have a nice day
Karsten
EDITED: 6 Mar 2019 by KMRQUS
7713.445
The new version is not ready yet. But today I wrote interpolation node for using with numarrays. At the moment it supports the following interpolation methods:
Linear, Cosine, Cubic, CatmullRom, Hermite, FritschCarlson
EDITED: 7 Mar 2022 by SMIRNOV
7713.446 In reply to 7713.445
What a supense! ;)
7713.447 In reply to 7713.445
Hello Max,
good news and very interesting - I've never heard before about FritschCarlson. (Something I have to Google now:-)
And, Is this a new node or are there new modes like short and long?
Have a nice evening
Karsten
7713.448 In reply to 7713.440
wastzzz
it's not like I write, I tried to change the sequence ,
and set long but no result....
can someone explain how to use
this random function ....
James , Karsten .....
much good results,with our script, but
you can enter the script into original nodeditor folder for them
try , without damaging the original files ???
thank you
al
_Sorry for my bad english
Size: 246.5 KB, Downloaded: 107 times, Dimensions: 1920x1080px
Message 7713.449 deleted 3 Oct 2016 by KMRQUS
7713.450 In reply to 7713.448
wastzz
With a bit of logic , I think I found the solution, but can not understand how the input values are interpolated-
I enclose two pictures;
-Input data ( before picture)
- transformed data (after picture)
Can you me better understand the operation?
al
Size: 252.8 KB, Downloaded: 114 times, Dimensions: 1920x1080px
Size: 229.3 KB, Downloaded: 98 times, Dimensions: 1920x1080px
7713.451 In reply to 7713.448
Hello Al,
try something like this:
If you want o test other nodes, You have to copy the nodefiles into the nodes folder an register them in index.html. If you replace core Stuff like litegraph.js you should make a copy of the original first. For the average stuff (better interpolation) I made only little changes in litegraph.js to show the function. To use it You have to make corrections in the basicFunctions.js file I have posted, but Max has created already a special node for that. The patharray is untested an has a performance problem for a sequence of numarray inputs. I have to improve it.
Have a nice day
Karsten
7713.452 In reply to 7713.451
Can we have Knobs or Cursors on the left of the Node math for input A & B and these ones will be randomised?
(for avoid to manually input values)
7713.453 In reply to 7713.452
Hi Pilou
I think this is one of the node problems
math, does not accept incoming of a b etc. multi values, then
it is always forced to write, greatly reducing the manipulation of the data-
It would also be nice that the single node result could be used
also for other transformations, then with more outputs
al
I Hope in a "wonderfull " solution Max's Problem
Show messages:  1-13  …  374-393  394-413  414-433  434-453  454-473  474-493  494-513  …  894-912
