Parametric design in MoI?
 1-5  …  386-405  406-425  426-445  446-465  466-485  …  906-912
7713.426 In reply to 7713.425
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi to 2 * pi - like in Grasshopper-
Sorry...
Many appreciate your answers
al
7713.427 In reply to 7713.383
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
Message 7713.428 deleted 14 May 2019 by JFH
7713.429 In reply to 7713.428
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
7713.430 In reply to 7713.429
Hi Karsten,
I get it now. This will be very useful.
- James
EDITED: 25 Apr 2019 by JFH
7713.431 In reply to 7713.430
But I don't know, if average is the right word for that? Max has to decide about it!
7713.432 In reply to 7713.431
p.s.: for 2 values it degenerates to a linear interpolation:-)
7713.433 In reply to 7713.415
Hi Max and Friends .
I am trying to redo the exercise (twist), (simple in Grasshopper ) but can not find the same Node
Polygon pts-
Node that I can use at the time, has three called input
center, radius, sides,
and not two , as the one used in the video......
Where am I doing wrong ????
Thanks for your help
al
Size: 282.1 KB, Downloaded: 114 times, Dimensions: 1920x1080px
7713.434 In reply to 7713.433
Hello Al,
I think that Max hasn't released the node, typically he post also the exampe.nod file for new features -so we have to wait:-)
Have a nice day
Karsten
7713.435 In reply to 7713.434
Thanks Karsten ,
I thought so, but I was not sure
best
al
7713.436
Hi guys
I was busy few days, so I didn't wrote anything since tuesday.
Here is small announce for the new version:
PolygonPts node (done)
TransformPts node (done: twist, rotate; to do: explode)
Interpolation node (to do)
ConvertPts node improvements
pushFrame rad/deg bug fixed (again) :)) I accidentally wrote Math.pi instead of Math.PI in the last version.
I don't know when I will release the new version. Maybe this Sunday.
7713.437 In reply to 7713.436
Good to know! Thanks a lot!
7713.438 In reply to 7713.437
Sweet sounds to my ears.......
do not forget (tutor) exercises for beginners like me-
Great
al
7713.439
I am testing it and it's great! Thanks.
Question for newbies: how do I extrude some shapes randomly? I can generate a random number but of course the number is used for every extrusion.
M.
7713.440 In reply to 7713.439
maybe you have to set Long rather than Short
in the field math
al
7713.441
PathPoints:-) only integration of the startframe evaluation is missing at the moment!
Have a nice day
Karsten
EDITED: 21 Nov 2016 by KMRQUS
7713.442 In reply to 7713.430
Hello James,
I had make some tests with the average-mode and found two bugs. If you want, you should correct this two lines:
r.push((e[1]-e[0])); //error corrected was r.push(2*(e[1]-e[0])); !!!
r.push((e[i]-e[i-1])-((r[i-1]*h[i-1])/u[i-1])); // error corrected was r.push((e[i]-e[i-1])-(r[i-1]*h[i-1]/u[i-1]));!!!
in basicFunctions.js -splineMap-function.
Have a nice day
Karsten
7713.443 In reply to 7713.442
Thanks Karsten,
It fixed an anomaly in interpolation with > 3 values in radii input series
as well as crashing bug if U,V or W input centre value < the number
of values values in radii input series.
I can't wait until Max has finalised the foundations of node editor,
to see what you build upon it.
Keep up the great work
7713.444 In reply to 7713.443
Hello James,
thanks for the reply. If you want to test another node, please test this one. But first you have to correct pushFrame in litegraph.js as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.436
PathArray in Points2.js generates an aligned pointarray along a curve. ShowFrame shows now all Frames in a pointarray - I think useful for test.
Have a nice day
Karsten
EDITED: 6 Mar 2019 by KMRQUS
7713.445
The new version is not ready yet. But today I wrote interpolation node for using with numarrays. At the moment it supports the following interpolation methods:
Linear, Cosine, Cubic, CatmullRom, Hermite, FritschCarlson
EDITED: 7 Mar 2022 by SMIRNOV
Show messages:  1-5  …  366-385  386-405  406-425  426-445  446-465  466-485  486-505  …  906-912
