Parametric design in MoI?
 1-19  …  380-399  400-419  420-439  440-459  460-479  …  900-912
7713.420 In reply to 7713.416
< Hi Al,
Tomorrow I'll explain how to use points and frames>
Hi Max
thanks in advance to all, look forward
your explanations, I'm sorry but I'm a beginner
al
7713.421 In reply to 7713.419
Hi Al,
To add inputs to node, right button click on node and pull down: inputs/a
as shown.
Hope this helps
- James
EDITED: 25 Apr 2019 by JFH
7713.422 In reply to 7713.418
Hi James, and Max ,
another question, sorry.......
How can I handle the n°. outputs
(In this case curves)-
As in the example posted to delete one
in order to make the Loft no Creased ?
(GH / Rhino you can)
and you can, in the future, implement this in "Elephant"
al
Size: 316.5 KB, Downloaded: 106 times, Dimensions: 1920x1080px
7713.423 In reply to 7713.421
Hi James
Many thanks for the help...
I need to ask other, maybe you could help my;
- How can I enter a domain of U and V in the Math node pt
into Fx3D Graph exists a field (Min) and (Max) ?
- you can create parametrically, with values on slider,
a Range -> (Domain / integer) ?
-and you can , always create parametrically ,
a Series of numbers -> Start Number / Interval / Number instances ?
thanks in advance
have a nice day
al
Size: 119.6 KB, Downloaded: 91 times, Dimensions: 1280x800px
7713.424 In reply to 7713.423
Hi Al
into Fx3D Graph exists a field (Min) and (Max) ?<<
An earlier iteration of MathArray node had inputs for UMin, UMax, VMin & UMax.
These have been removed with the name change to MathPoints.
I believe that Max is developing Range and series nodes to satisfy this requirement
and the others you mentioned We need to wait and see.
-James
7713.425 In reply to 7713.423
Hi Al
FROM YOUR IMAGE >> How insert domain Ex (-2pi to 2pi)<<
In the URange or VRange field type:
-2*PI,2*PI
exactly as above, and it will populate field with numerical values.
I'm noy sure if this answers your question.
Let me know
-James
7713.426 In reply to 7713.425
Hi james
Sorry, I'm too "speedy", I had not noticed
the comma as separator in the fields ,
I wrote-2 *pi to 2 * pi - like in Grasshopper-
Sorry...
Many appreciate your answers
al
7713.427 In reply to 7713.383
Hello Max,
I thougth about an interpolation for numarrays. I choose a spline interpolation and activated your average mode. Maybe you can use parts of the code. Maybe someone can test it, if it is useful ...
Have a nice day
Karsten
Message 7713.428 deleted 14 May 2019 by JFH
7713.429 In reply to 7713.428
Hello James,
it is exacly what it should do. You have 11 circles and the radius is given as a sequence of numbers (1,2,1). The average mode in the circles-node, maps a interpolation of the three values to the radii of the circles. You can add or delete a value also- (I hope so:-) It isn't tested well, because the integration in litegraph.js is just a hack - as good as I understand the code.
Have a nice day
Karsten
7713.430 In reply to 7713.429
Hi Karsten,
I get it now. This will be very useful.
- James
7713.431 In reply to 7713.430
But I don't know, if average is the right word for that? Max has to decide about it!
7713.432 In reply to 7713.431
p.s.: for 2 values it degenerates to a linear interpolation:-)
7713.433 In reply to 7713.415
Hi Max and Friends .
I am trying to redo the exercise (twist), (simple in Grasshopper ) but can not find the same Node
Polygon pts-
Node that I can use at the time, has three called input
center, radius, sides,
and not two , as the one used in the video......
Where am I doing wrong ????
Thanks for your help
al
Size: 282.1 KB, Downloaded: 114 times, Dimensions: 1920x1080px
7713.434 In reply to 7713.433
Hello Al,
I think that Max hasn't released the node, typically he post also the exampe.nod file for new features -so we have to wait:-)
Have a nice day
Karsten
7713.435 In reply to 7713.434
Thanks Karsten ,
I thought so, but I was not sure
best
al
7713.436
Hi guys
I was busy few days, so I didn't wrote anything since tuesday.
Here is small announce for the new version:
PolygonPts node (done)
TransformPts node (done: twist, rotate; to do: explode)
Interpolation node (to do)
ConvertPts node improvements
pushFrame rad/deg bug fixed (again) :)) I accidentally wrote Math.pi instead of Math.PI in the last version.
I don't know when I will release the new version. Maybe this Sunday.
7713.437 In reply to 7713.436
Good to know! Thanks a lot!
7713.438 In reply to 7713.437
Sweet sounds to my ears.......
do not forget (tutor) exercises for beginners like me-
Great
al
7713.439
I am testing it and it's great! Thanks.
Question for newbies: how do I extrude some shapes randomly? I can generate a random number but of course the number is used for every extrusion.
M.
Show messages:  1-19  …  360-379  380-399  400-419  420-439  440-459  460-479  480-499  …  900-912
