Parametric design in MoI?
 1-5  …  366-385  386-405  406-425  426-445  446-465  …  906-912
7713.406
v.0.80
Added function updateThisNodeGraph. This function updates node graph without canvas reloading.
Knob, Slider and Output nodes has been rewritten. Now they use updateThisNodeGraph. Significant interface performance boost!
Fixed pointArray.pushFrame deg/rad bug
Changed node connections (lot of graphical changes)
Arrays group renamed to Points
Due lack of time I didn't tested all new graphical features well. Send me a message if you find glitches and bugs.
EDITED: 7 Mar 2022 by SMIRNOV
7713.407 In reply to 7713.406
Hello Max,
thanks for the update, but I have some problems to get it to run. It seems that arrays.js is missing - as file and as link in index.html!?
Have a nice evening
Karsten
p.s.: Adding from 0.77a fixed it:-)
EDITED: 25 Sep 2016 by KMRQUS
7713.408 In reply to 7713.407
Hi Karsten,
I've renamed Arrays section to Points in the last version.
7713.409 In reply to 7713.408
Hello Max,
thanks for the reply. Ok, I understood! And now I see you mentioned it! I've tested the example.0.77 and get some errors, so I fixed it in the wrong way.
Have a nice evening
Karsten
v 0.8 with example 0.77a
7713.411
Dear friends, don't use .nod from the old beta version. And don't use old .js files.
This software still in developing. I'm changing nodes, variables, logic, names.
I'll think about back compatibility after v.1.0 release only.
7713.412
Bug found in Slider and Knob nodes. Please update interface.js
7713.413 In reply to 7713.412
EDITED: 26 Sep 2016 by PILOU
7713.414 In reply to 7713.413
Dear friends
can someone explain to me the features
(Points Math) with some example ..
something is simple ..... but other features
they are unknow for me-
I upload a starting file......
Many thank
al
7713.415
New tests
Inspired by this video
https://www.youtube.com/watch?v=twOUPaqo-ak
7713.416 In reply to 7713.414
Hi Al,
Tomorrow I'll explain how to use points and frames
7713.417 In reply to 7713.415
Hi Max,
> Inspired by this video https://www.youtube.com/watch?v=twOUPaqo-ak
Hey...the old good Grasshopper is back !
To be perfectly honest, Grasshopper is by far the very best of Rhino, its point of excellence.
7713.418 In reply to 7713.414
Al
(Points Math) with some example ..<
Point Math is simply Max's brilliant "FXGraph3d" script repurposed as a node.
An in depth discussion of FXGraph scripts can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.1
Attached is .nod file for generating Enneper surface with Points Math node.
Hope this helps
- James
EDITED: 25 Apr 2019 by JFH
7713.419 In reply to 7713.418
Good Morning James
thanks for the file
of considerable clarification, but I ask you
how to add input into
feature
al
Size: 344 KB, Downloaded: 104 times, Dimensions: 1920x1080px
7713.420 In reply to 7713.416
< Hi Al,
Tomorrow I'll explain how to use points and frames>
Hi Max
thanks in advance to all, look forward
your explanations, I'm sorry but I'm a beginner
al
7713.421 In reply to 7713.419
Hi Al,
To add inputs to node, right button click on node and pull down: inputs/a
as shown.
Hope this helps
- James
7713.422 In reply to 7713.418
Hi James, and Max ,
another question, sorry.......
How can I handle the n°. outputs
(In this case curves)-
As in the example posted to delete one
in order to make the Loft no Creased ?
(GH / Rhino you can)
and you can, in the future, implement this in "Elephant"
al
Size: 316.5 KB, Downloaded: 106 times, Dimensions: 1920x1080px
7713.423 In reply to 7713.421
Hi James
Many thanks for the help...
I need to ask other, maybe you could help my;
- How can I enter a domain of U and V in the Math node pt
into Fx3D Graph exists a field (Min) and (Max) ?
- you can create parametrically, with values on slider,
a Range -> (Domain / integer) ?
-and you can , always create parametrically ,
a Series of numbers -> Start Number / Interval / Number instances ?
thanks in advance
have a nice day
al
Size: 119.6 KB, Downloaded: 91 times, Dimensions: 1280x800px
7713.424 In reply to 7713.423
Hi Al
into Fx3D Graph exists a field (Min) and (Max) ?<<
An earlier iteration of MathArray node had inputs for UMin, UMax, VMin & UMax.
These have been removed with the name change to MathPoints.
I believe that Max is developing Range and series nodes to satisfy this requirement
and the others you mentioned We need to wait and see.
-James
7713.425 In reply to 7713.423
Hi Al
FROM YOUR IMAGE >> How insert domain Ex (-2pi to 2pi)<<
In the URange or VRange field type:
-2*PI,2*PI
exactly as above, and it will populate field with numerical values.
I'm noy sure if this answers your question.
Let me know
-James
Show messages:  1-5  …  346-365  366-385  386-405  406-425  426-445  446-465  466-485  …  906-912
