Parametric design in MoI?
 1-20  …  361-380  381-400  401-420  421-440  441-460  …  901-912
7713.401 In reply to 7713.400
Hello
My Friends I are in confusion.............
I started using Elephant, and I uploaded some applications....
Now, I post pictures of my ui
where you see what I've uploaded ...
Considering the last release of the legendary Max
the question is;
What should I charge, to have the updated features, I can add
that load in my Node Editor without removing what is already
..... or , do I have to remove everything, and in this case what should I enter
I await yours suggestion
regards
al
sorry for my bad English, I hope
I understand my problem
7713.402 In reply to 7713.401
Hello Al,
it seems that you use a very old version of the Elephant.(Date 2015). So you should rename your nodeeditor folder to e.g. nodeeditor-old. Than extract the archive and rename the folder nodeeditor.0.77.a to nodeeditor. Copy the folder to /ui of your Moi installation. Your node-files will not work with the new version - if you need them, you can change or dublicate your shortcut-key and can use them also.
Have a nice day
Karsten
It's me or there is no "a" on the N° 0.77a of the last Elephant ?
@Max : here the lang.js (0.77a) If you can add this part in your futur version (s) that will help me for avoid to reload numerous old versions! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
Maybe there is somewhere in Sub- menus, ... something other to translate ?
French version of the Nodes! :)
EDITED: 23 Sep 2016 by PILOU
7713.405 In reply to 7713.402
Hi Karsten
Many Many Many....Thanks for your indication
Now Ok - Work fine
best
al
7713.406
v.0.80
Added function updateThisNodeGraph. This function updates node graph without canvas reloading.
Knob, Slider and Output nodes has been rewritten. Now they use updateThisNodeGraph. Significant interface performance boost!
Fixed pointArray.pushFrame deg/rad bug
Changed node connections (lot of graphical changes)
Arrays group renamed to Points
Due lack of time I didn't tested all new graphical features well. Send me a message if you find glitches and bugs.
EDITED: 7 Mar 2022 by SMIRNOV
7713.407 In reply to 7713.406
Hello Max,
thanks for the update, but I have some problems to get it to run. It seems that arrays.js is missing - as file and as link in index.html!?
Have a nice evening
Karsten
p.s.: Adding from 0.77a fixed it:-)
EDITED: 25 Sep 2016 by KMRQUS
7713.408 In reply to 7713.407
Hi Karsten,
I've renamed Arrays section to Points in the last version.
7713.409 In reply to 7713.408
Hello Max,
thanks for the reply. Ok, I understood! And now I see you mentioned it! I've tested the example.0.77 and get some errors, so I fixed it in the wrong way.
Have a nice evening
Karsten
v 0.8 with example 0.77a
7713.411
Dear friends, don't use .nod from the old beta version. And don't use old .js files.
This software still in developing. I'm changing nodes, variables, logic, names.
I'll think about back compatibility after v.1.0 release only.
7713.412
Bug found in Slider and Knob nodes. Please update interface.js
7713.413 In reply to 7713.412
EDITED: 26 Sep 2016 by PILOU
7713.414 In reply to 7713.413
Dear friends
can someone explain to me the features
(Points Math) with some example ..
something is simple ..... but other features
they are unknow for me-
I upload a starting file......
Many thank
al
7713.415
New tests
Inspired by this video
https://www.youtube.com/watch?v=twOUPaqo-ak
7713.416 In reply to 7713.414
Hi Al,
Tomorrow I'll explain how to use points and frames
7713.417 In reply to 7713.415
Hi Max,
> Inspired by this video https://www.youtube.com/watch?v=twOUPaqo-ak
Hey...the old good Grasshopper is back !
To be perfectly honest, Grasshopper is by far the very best of Rhino, its point of excellence.
7713.418 In reply to 7713.414
Al
(Points Math) with some example ..<
Point Math is simply Max's brilliant "FXGraph3d" script repurposed as a node.
An in depth discussion of FXGraph scripts can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.1
Attached is .nod file for generating Enneper surface with Points Math node.
Hope this helps
- James
EDITED: 25 Apr 2019 by JFH
7713.419 In reply to 7713.418
Good Morning James
thanks for the file
of considerable clarification, but I ask you
how to add input into
feature
al
Size: 344 KB, Downloaded: 104 times, Dimensions: 1920x1080px
7713.420 In reply to 7713.416
< Hi Al,
Tomorrow I'll explain how to use points and frames>
Hi Max
thanks in advance to all, look forward
your explanations, I'm sorry but I'm a beginner
al
Show messages:  1-20  …  341-360  361-380  381-400  401-420  421-440  441-460  461-480  …  901-912
