Parametric design in MoI?
 1-3  4-23  24-43  44-63  …  904-912
7713.4 In reply to 7713.1
Hi artisanicview, usually "Parametric" refers to something different than Rhino blocks - usually "Parametric" in a CAD sense means that the CAD program maintains a history tree of operations and allows you to go in to that history tree and change parameter values like change the diameter of a hole or change the radius value of a fillet and then have the model be recreated.
Blocks in Rhino are a pretty different mechanism than that - that works more like a kind of object template where you can insert many copies of an object and each copy knows that it is a lightweight copy of the base object template and that helps to keep the file size down for a lot of repeated objects. There is some commonality with updating since you can change the object template and the instances will update to the new object but it's fairly different than editing parameter values of "features" in the history tree like Parametric modeling usually involves.
I do want to have an instancing mechanism in MoI in the future, it's definitely on my radar.
If you want parametric system try the free Onshape! ;)
7713.6 In reply to 7713.5
"If you want parametric system try the free Onshape! ;)"
Thank you for answer but unfortunately OnShape is an on-line tool and I need to use a software without any internet connection.
7713.7 In reply to 7713.6
So FreeCad ?
http://www.freecadweb.org/
or wait a little for have this inside MOi!
http://moi3d.com/forum/index.php?webtag=MOI&msg=3145.28
EDITED: 9 Nov 2015 by PILOU
7713.8 In reply to 7713.4
Thank you Michael. I know that blocks are different than "Parametric" but at least it is the most basic way to quickly replace components if the design require to make changes.
Please take a look at the SketchUP component, are plenty of videos in Youtube. The are very simple to make and use but also very effective. MoI already have scripting capabilities, so basically needs to link the scripting with the objects.
7713.9 In reply to 7713.7
@Pilou: Thank you for the answer.
I tried FreeCAD but it's difficult to use, the interface is very confusing.
MoI is much simpler to use. Only needs some "Components" a la Sketchup, or dimension constraints.
I'm designing furniture, and a lot of elements are repeated tens or hundreds of times. If I need to make adjustments, its very time consuming to adjust every single element individually. In Sketchup, if I'm changing the parameters from one component, all the instances of the same component are updated automatically. Simple, but dead effective. Also the components from SK have some driven logic, so I can add some kind of parametrization.
7713.10 In reply to 7713.7
Project Elephant: This is generative design. Not exactly what I'm looking for, but also will be useful to have such features in MoI, especially for the architects.
7713.11 In reply to 7713.10
So maybe free DesignSpark Mechanical ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
But take this V1 http://zwcad.com.tw/nick/FREE3D/ for have maximum functions!
7713.12 In reply to 7713.11
Is this running under OSX and Linux?
You see, it is not so simple as it seems. :)
7713.13 In reply to 7713.12
Only PC :)
7713.14 In reply to 7713.11
Hi, Pilou...
Could you please elaborate more with the V1 'have maximum functions'?
I would like to know before download it.
Thank you very much in advance.
7713.15 In reply to 7713.14
You have for example this very cool function Blend who don't more existing in the V2 !!!
7713.16 In reply to 7713.7
Frenchy Pilou
A little? :) I never told that. It will come right after MoI v4, or later, or it will never come at all.
7713.17 In reply to 7713.16
So a big little during a new moment of inspiration! :)
7713.18
7713.19 In reply to 7713.18
Seems you don't drop the affair! ;)
Courage!
7713.20 In reply to 7713.19
In fact I didn't spend a lot of time writing it. I decided to finish the main core script, and then share it with community.
I still do not have plans to write the whole node-system for MoI.
7713.21
Max,
I think there is a real business opportunity here.
I for one, would be prepared to pay for a node-based parametric add-on for Moi3d.
7713.22
This project is very close to alpha release :)
In the last build I added Save/Load functions, node info/edit panel, slider node.
EDITED: 7 Mar 2022 by SMIRNOV
Seems terrific! Pleasure of the coding! ;)
Any functions valuable ?
EDITED: 23 Nov 2015 by PILOU
Show messages:  1-3  4-23  24-43  44-63  64-83  …  904-912
