Parametric design in MoI?
 1-20  …  321-340  341-360  361-380  381-400  401-420  …  901-912
Hi Max,
How are you ? I hope well.
Have you got some good news about a new official release of your NodeEditor ?
In my garbage time i'm continuing to code some new utility nodes for PointArray or in general but,
if i remember correctly, you said that the next version of NodeEditor will present a major rewrite of the fundamental datatypes,
so i would like to know if it's better for me to wait the new version, instead of coding nodes that will not work anymore.
Nice day,
Marco (mkdm).
7713.362 In reply to 7713.361
Hi Marco!
I'm fine, thank you! :)
I have no time for programming right now, but it will not last for long. Wait two or three weeks.
I have plans to replace Number type with NumberArray type. It should be last change in the datatype system.
Max's motor2.3dm is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.203
Also, to try out the continuous animation, copy the modified basic.js to nodeeditor/nodes directory.
EDITED: 2 Mar 2021 by BEMFARMER
7713.364 In reply to 7713.362
Hi Max,
It's good to know that you're okay.
Thank you for this heads-up.
I think that it shouldn't be a problem for the utility nodes i'm coding, for the PointArray datatype.
One more question, just about the PointArray.
Did you plan to code some business logic that will supply programmatic ways to select the PointArray's element ?
I realize that i've already asked this in other posts and with other words,
but i think that this would be a very very powerful thing.
For the time being, i've only written the "PatternSelArray" node, but it can be done much, much more :)
Nice day,
Marco (mkdm).
7713.365 In reply to 7713.363
Hi bemfarmer,
Thank you very much for your great work !!
It's kinda like a cornucopia for other similar ideas...
Nice day,
Marco (mkdm).
7713.366 In reply to 7713.362
Hi Max!
How are you ?
What about the new release of project Elephant ?
Ciao!
- Marco (mkdm).
7713.367 In reply to 7713.362
Repetita iuvant...
Hi Max!
How are you ?
Ciao!
- Marco (mkdm).
7713.368 In reply to 7713.367
Hi Marco! :)
I don't know when I release the new version. :(
I'll try to do it this month.
7713.369 In reply to 7713.368
Hello Max!
OK, that's good to know !
Message 7713.370 deleted 9 Sep 2016 by JFH
7713.371
Hi guys! :)
Sorry for delay.. My work takes all free time during last months.
But today I wrote a few lines of code :)
7713.372 In reply to 7713.371
Take your time!
7713.373 In reply to 7713.371
Hi Max!
I'm glad to see you back here!
Waiting for your new version of NodeEditor...
So, I can finally finish my bunch of utility nodes for pointArray() data structure.
Ciao!
7713.374 In reply to 7713.373
Hi Marco
I made a lot of changes in the internal structure today. The work goes faster than expected. :)
Right now I rewrite all nodes for using numarrays as input data. It will take couple of days.
Wait for the new version next week.
7713.375
EDITED: 7 Mar 2022 by SMIRNOV
7713.376 In reply to 7713.374
Hi Max,
I'm glad to know that your work is almost done!
Well...which means most likely I have to rewrite some portions of my utility nodes.
I'll wait and see :)
Ciao!
P.S. One last question Max.
Some times ago, when you developed the excellent SubDiv scripts, if I remember correctly,
you said that one day you'd add the ability to accept surfaces with more then 4 edges.
Do you think to upgrade SubDiv script in order to give it that feature ?
Thanks a lot and have a nice day.
Red star! ;)
7713.378
Today evening I rewrote all nodes except arrays. I'm very impressed with the results.
Yes you can! Bravo!
7713.380 In reply to 7713.378
Hi Max,
...very promising results!
Does it mean that you are not going to add any new features to PointArray ?
For example : programmatic ways to specify the iteration order, or parameters to specify start,end,step,
or the possibility to map every array element to a generic tag object (IMHO this would be a very powerful feature, for example link an array element with a
GeometryFactory Subclasses).
Etc...etc...
I hope you have the time and and desire to do it.
Ciao!
Show messages:  1-20  …  301-320  321-340  341-360  361-380  381-400  401-420  421-440  …  901-912
