Parametric design in MoI?
 1-12  …  313-332  333-352  353-372  373-392  393-412  …  893-912
Hi everyone,
While waiting the next official NodeEditor release by Max, here's my the first stable version (0.1) of some nodes i wrote :
N.B. these nodes requires the latest v.0.65b version of Max's NodeEditor.
- "PatternSelArray" : returns a PointArray, made by a patterned+subset selection of the input PointArray's element
- "ArrayShuffler" : returns a PointArray, by shuffling the elements inside the input PointArray (RMB -> Update : generate a new random shuffle)
For example, it may be useful to create objects like ball of wool.
- "ArrayFlipper" : returns a PointArray, made by flipping the elements of the input PointArray
- "ArrayLogger" : Outputs to a textarea the content of the input PointArray. It's useful for debugging.
You can copy/paste the textarea's content, to a text editor, in order to better view all the text.
Every line of text contains the full data of each point present in the input PointArray, separated by a single space :
X Y Z AngleX AngleY AngleZ Size
- "ArrayReplicator" : Replicates the input PointArray. It may be useful only in order to keep the graph cleaner.
In order to use these new nodes, follow these steps :
1) copy the "arraysExt.js" file into the "nodes" folder of NodeEditor
2) copy the "litegraphExt.js" file into the "core" folder of NodeEditor
3) add these lines of code to the "index.html" file of NodeEditor
<script type="text/javascript" src="core/litegraphExt.js"></script>
<script type="text/javascript" src="nodes/arraysExt.js"></script>
I hope that you will find these nodes useful.
Please, let me know if you will find bugs.
Nice day to all!
Marco (mkdm)
EDITED: 30 May 2016 by MKDM
Size: 75.3 KB, Downloaded: 104 times, Dimensions: 968x704px
Size: 176 KB, Downloaded: 146 times, Dimensions: 1721x971px
Size: 2.1 MB, Downloaded: 156 times, Dimensions: 1920x1034px
Size: 155.6 KB, Downloaded: 113 times, Dimensions: 1720x967px
7713.354 In reply to 7713.353
Hello Marco,
Thank You very much for sharing. I have tested some nodes and for now, everything works fine. Especially the ArrayLogger will help to debug while programming and also while using the nodeeditor. I'm very curious what's comming next.
Have a nice day
Karsten
7713.355 In reply to 7713.354
Hi Karsten,
I'm glad to know that you appreciated my little contribution and also that you haven't found some strange bugs...
Currently i'm working on a node that will be called "ArraySketcher".
It will process a PointArray and, following some criteria, it will use the array elements to draw some basic geometry objects :
"Triangles", "Quads", "Curve", "Interpcurve", "Arc3pt", "Circle3pt", "Rect3pts", "EllipseDiam","EllipseCen" and some others...
I also wrote "PatternSelObjects" node, that does the same things of "PatternSelArray", but with it,
it's possible to operate on a ObjectList rather than a PointArray.
I hope to post soon these new nodes.
Thank you for your reply and have a nice day!
Marco (mkdm).
EDITED: 31 May 2016 by MKDM
I believe that must be easy but I am a little stucked in the nodal world! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodal_problemo.zip
(no nodal file inside) Curve can be any flat curve like a Sinusoïde etc...Hllow object can be any thing like a bowl etc...
I make a "Flat Extrude" +"Vertical Extrude" because "Shell" is not yet implemented (Vertical Extrude Line + Shell)
All that for simulate this function! :)
Minute 25.00 - 25.54
EDITED: 6 Jun 2016 by PILOU
After much study learning how the Motor2.nod works, I did a documentation PDF.
Also, there were 3 miscellaneous observations of very minor concern:
1. The first rotate node has input label "In" instead of "Objects." (This is apparently an old version leftover?)
2. Regarding arcsin (asin), the order of mathematical operation appears to be
nonstandard. (An additional set of () was added around the asin opperands.)
3. The Rotate nodes Z angle inputs are obeying the "Left Hand Rule," rather than the "Right Hand Rule." (OK I guess)
4. Increasing positive angle results in Clockwise rotation. (OK)
The Word to PDF conversion makes the SnagIt MoI PNG blurry :-(
So I need a different way to make the PNG?
Edit: Updated PDF with new Figure 1 PNG from CustomUI Snapshot Right Click, and added a couple of sentences.
EDITED: 8 Jun 2016 by BEMFARMER
7713.358 In reply to 7713.357
Enlighting!
<<So I need a different way to make the PNG?
You have no choice to make different level of rendering image at the begining of the PDF process?
Seems remember that ...but a long time that i don't made a PDF! (i have not more this program)
Blurry for me only when you make a big zom!
French translation of your Tutorial in a few days! :)
7713.359 In reply to 7713.358
Thanks PILOU,
I updated the PDF a little bit.
Quartz is in the translate list.
Quartz is also a basic node, but its activation is commented out in the basic.js file.
Quartz refers to a quartz watch.
To activate Quartz, by editing the basic.js file, uncomment it by changing //LiteGraph.registerNodeType("Basic/Quartz", Quartz);
to: LiteGraph.registerNodeType("Basic/Quartz", Quartz);
Try replacing the slider in motor2.nod with a Quartz node for slow, continuous animation.
The Hz (Hertz) input should control cycles per second, somehow?
The Hz input does not seem to do anything?
Hmm, there is also a Watch node...
The Watch node can be wired in just after the Quartz node.
The Watch node displays the input numbers. With Quartz, the numbers go from 0 to 359.
Quartz can have its step value changed, and has a tic-tac mode.
So Quartz acts like an automatic slider?
Hi Max,
How are you ? I hope well.
Have you got some good news about a new official release of your NodeEditor ?
In my garbage time i'm continuing to code some new utility nodes for PointArray or in general but,
if i remember correctly, you said that the next version of NodeEditor will present a major rewrite of the fundamental datatypes,
so i would like to know if it's better for me to wait the new version, instead of coding nodes that will not work anymore.
Nice day,
Marco (mkdm).
7713.362 In reply to 7713.361
Hi Marco!
I'm fine, thank you! :)
I have no time for programming right now, but it will not last for long. Wait two or three weeks.
I have plans to replace Number type with NumberArray type. It should be last change in the datatype system.
Max's motor2.3dm is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.203
Also, to try out the continuous animation, copy the modified basic.js to nodeeditor/nodes directory.
EDITED: 2 Mar 2021 by BEMFARMER
7713.364 In reply to 7713.362
Hi Max,
It's good to know that you're okay.
Thank you for this heads-up.
I think that it shouldn't be a problem for the utility nodes i'm coding, for the PointArray datatype.
One more question, just about the PointArray.
Did you plan to code some business logic that will supply programmatic ways to select the PointArray's element ?
I realize that i've already asked this in other posts and with other words,
but i think that this would be a very very powerful thing.
For the time being, i've only written the "PatternSelArray" node, but it can be done much, much more :)
Nice day,
Marco (mkdm).
7713.365 In reply to 7713.363
Hi bemfarmer,
Thank you very much for your great work !!
It's kinda like a cornucopia for other similar ideas...
Nice day,
Marco (mkdm).
7713.366 In reply to 7713.362
Hi Max!
How are you ?
What about the new release of project Elephant ?
Ciao!
- Marco (mkdm).
7713.367 In reply to 7713.362
Repetita iuvant...
Hi Max!
How are you ?
Ciao!
- Marco (mkdm).
7713.368 In reply to 7713.367
Hi Marco! :)
I don't know when I release the new version. :(
I'll try to do it this month.
7713.369 In reply to 7713.368
Hello Max!
OK, that's good to know !
Message 7713.370 deleted 9 Sep 2016 by JFH
7713.371
Hi guys! :)
Sorry for delay.. My work takes all free time during last months.
But today I wrote a few lines of code :)
7713.372 In reply to 7713.371
Take your time!
Show messages:  1-12  …  293-312  313-332  333-352  353-372  373-392  393-412  413-432  …  893-912
