Parametric design in MoI?
 1-12  …  293-312  313-332  333-352  353-372  373-392  …  893-912
7713.333 In reply to 7713.321
Hi Michael and Max (and everyone),
While i was doing some testing with "Array" family nodes, i wondered a thing regarding the rules followed by Moi and Nodeeditor,
in order to manage the order of selected objects.
I hope that both the .3dm and .nod files that i have attached, are sufficiently clear to explain what i'm trying to understand.
In order to run the example i think that it is necessary the latest Nodeeditor version (0.65).
But, to be clearer, i'll show you what are the steps that i have followed, what is the result that i wanted and what instead is the result that i get.
Given that this is nothing more than an exercise, my goal is to better understand the way used by Moi to manage a set of selected objects,
and if it could be possible to control the order of the objects inside a specific set of selected objects,
and if it could be possible to get the same behavior inside Nodeeditor.
So, i have followed these steps :
01 - Open the .3dm and .nod files
02 - Select all the points in .3dm file, picking them individually in the order shown by the numbers
03 - Assign the selection to the "Selected" node present into the nodeeditor, via the "update" command by right-clicking the node
04 - Run the editor
And....as you can see in the 01_Capture.PNG file, the resulting curve, displayed in violet, doesn't follows the order of picked points.
My question is.....am i doing something wrong ?
Is there a way to instruct Moi or NodeEditor to keep unaltered the order of picked objects ?
Or does Moi apply a different rules to the selected objects, in order to manage a different ordering ?
And, a final consideration...
I think that having the ability to control the order of selected objects, manually or via some sort of programmatic criteria,
would be a very powerful thing inside both Moi and Nodeeditor.
Well then everyone... have a good day,
Marco (mkdm).
Size: 832.5 KB, Downloaded: 115 times, Dimensions: 1918x1039px
Size: 105.5 KB, Downloaded: 111 times, Dimensions: 1521x821px
7713.334
Hello to all,
I want to share the idea to make a wrapping function for additional outputs. The advantage would be to reduce nodes. Every node have nearly the same code and new functions could be registered central in one function. The new function would than present in every node that carries the code. The attached code is experimental and full of bugs, but it's the best I can give at the moment. So please study and give a feedback, if it worth to think about.
It's not useful to play with it or integrate the files - only to study what I'm making wrong or make it perhaps better.
The litegraph.js is needed for a function that Marco posted. Thanks for that(for those who can not leave it;-)
Have a nice day
Karsten
EDITED: 6 Mar 2019 by KMRQUS
7713.335 In reply to 7713.334
forgot to post!
Hi everyone!
While waiting for new versions of Max's NodeEditor,
i'm doing some experiments with PatternArray selection :
Here's my current unfinished version of the node PatternSelectArray :
// PatternSelectArray
function PatternSelArray()
	this.addInput("In","pointarray");
	this.addInput("Start","number");
	this.addInput("Qt_Max","number");
	this.addInput("Step","number");
	this.addOutput("Out","pointarray");
	this.addOutput("Elems","number");
	this.addOutput("Source","pointarray");
	this.properties = { mode:["Pattern + Subset", "Pattern + Subset", "Subset + Pattern"],
		pattern:"+",
		start:0,
		qt_max:-1,
		step:1};
PatternSelArray.title = "PatternSelArray";
PatternSelArray.desc = "PatternSelArray";
PatternSelArray.prototype.onExecute = function()
	//if (this.properties.order[0] == "By Selection") {
	var source = this.getInputData(0, new pointArray());
	this.properties.pattern = this.properties.pattern.trim();
	var usePattern = false;
	var isMixedPattern = false;
	// check the pattern
	if (this.properties.pattern != '') {
		// check if pattern contains valid characters
		usePattern = this.properties.pattern.match('^[+\-0-1]+$');
		if (usePattern) {
			// check if pattern contains only include characters (+ or 1)
			usePattern = !this.properties.pattern.match('^[+1]+$');
			if (usePattern) {
				// if pattern contains both include and exclude characters, then the pattrn will be used
				// otherwise it means that contains only exclude characters (- or 0), and therefore
				// the output pointarray list will be empty
				isMixedPattern = !this.properties.pattern.match('^[\-0]+$');
	var output = new pointArray(); // init to empty list
	if (usePattern) {
		if (isMixedPattern) {
			var len = source.getLength();
			var cn = 0;
			for (i = 0; i < len ; i++) {
				if ( this.properties.pattern[cn] === '1' || this.properties.pattern[cn] === '+') {
					var source_elem = source.getElement(i);
					output.push(source_elem.pt.x,
						source_elem.pt.y,
						source_elem.pt.z,
						source_elem.AngleX,
						source_elem.AngleY,
						source_elem.AngleZ,
						source_elem.Size);
				cn = (cn < this.properties.pattern.length-1) ? cn+1 : 0;
	} else {
		// elaborate the whole source pointarray
		this.properties.pattern = '';
		output = source;
	var outLength = output.getLength();
	this.properties.start = this.getInputData(1, this.properties.start);
	if (this.properties.start < 0) this.properties.start = 0;
	if (this.properties.start > (outLength - 1)) this.properties.start = (outLength - 1);
	this.properties.qt_max = this.getInputData(2, this.properties.qt_max);
	if ((this.properties.qt_max < 0) || (this.properties.qt_max > outLength)) this.properties.qt_max = outLength;
	this.properties.step = this.getInputData(3, this.properties.step);
	if (this.properties.step <= 0) this.properties.step = 1;
	if (this.properties.step > outLength) this.properties.step = outLength;
	// generate the final pointarray list
	var outputFinal = new pointArray();
	for (i = this.properties.start, cont = 0; i < outLength && cont < this.properties.qt_max; i += this.properties.step, cont++) {
		var source_elem = output.getElement(i);
		outputFinal.push(source_elem.pt.x,
			source_elem.pt.y,
			source_elem.pt.z,
			source_elem.AngleX,
			source_elem.AngleY,
			source_elem.AngleZ,
			source_elem.Size);
	output = null;
	this.setOutputData(0, outputFinal);
	this.setOutputData(1, outputFinal.getLength());
	this.setOutputData(2, source);
	this.outputs[1].label = "Elems(" + outputFinal.getLength() + ")";
LiteGraph.registerNodeType("Arrays/PatternSelArray", PatternSelArray);
The inputs and outputs are :
1 - In : the source PointArray
2 - pattern : the filter pattern string : 1 or + pick the element, 0 or - skip the element
Example "1001" or "+--+"
3 - Start : the first element index of the resulting array after the pattern filtering
4 - Qt_Max : Max quantity of elements present in the final output array
5 - Step : The step used while iterate over the patterned array
6 - Out : the final array
7 - Elems : the number of elements present in the final array
8 - Source : The initial source PointArray
Actually the node works in this way :
1) The pattern is applied to the source array
2) Start , Qt_Max and Step are used to iterate over the patterned PointArray
Actually the property "mode" is not used, but when activated,
will determine the order of the used logic :
First do Pattern operation and then Iterates
or
First Iterates and then do Pattern operation
Nice evening to all,
Marco.
7713.337 In reply to 7713.334
Hi Karsten
Great work!
I am totally onboard with your wrapping function for additional outputs proposal.
However could it be achieved with a two tiered menu as shown?
& removed in a similar method to the removal of additional inputs
This way the info panel is not further crowded with non-dynamic elements.
Just a thought
-James
7713.338 In reply to 7713.337
Hello James,
I had the same idea also, but I could not get it to run:-( I don't understand the core stuff already. Every time I have a short look in it, I have to google for hours. Nevertheless I am still learning. The other reason why I switched back to a selection of the function in the info panel was, that I don't know a good way for multiple outputs (not implemented, but I think possible this way) So the code is only an experiment to explain the idea, not a real solution. I hope Max will implement such a feature. It would help to extend the nodeeditor with such basic functions in a simple way.
Have a nice day
Karsten
7713.339 In reply to 7713.338
Karsten/Max
I also think it would be useful to introduce a radio button associated to inputs as shown.
In the case of array nodes, range inputs could all be activated with cascade menu directly on node
or individually in info panel. It would be immediately apparent in the info panel which field has an
active input and which can be activated/deactivated if need be.
The simple remains simple; & the complex is possible
-James
EDITED: 6 May 2019 by JFH
7713.340 In reply to 7713.339
Hi James,
i agree with you.
It would be very useful having the possibility to use a bunch of classic input controls inside nodes,
like radiobuttons and checkboxes.
In my garbage time i'm testing some javascript code that goes in that direction.
But i think that until Max will not release a new updated version of Nodeeditor, all these idea are only valid as a javascript developing practise...
Nice day,
Marco.
Hi everyone!
here's the new code of my "PatternSelArray" and "ArrayReplicator".
The attached pictures show a simple example.
If you find bugs and errors, please, let me know...
Marco (mkdm)
	this.size = [160,70];
	this.minsize = [160,70];
	this.addInput("Start_Idx","number");
		pattern:"",
		start_idx:0,
		qt_max:-1,
		step:1 };
		source = the source array
		start_idx = index of the first element to pick
		numMaxElem = max number of elements that will be present in the resulting array
		step = step amount for the for..loop
	var getPointArraySection = function(source, start_idx, numMaxElem, step) {
		var result = new pointArray();
		if (source) {
			var sourceLength = source.getLength();
			for (i = start_idx, cont = 0; i < sourceLength && cont < numMaxElem; i += step, cont++) {
				result.push(source_elem.pt.x,
					source_elem.pt.y,
					source_elem.pt.z,
					source_elem.AngleX,
					source_elem.AngleY,
					source_elem.AngleZ,
					source_elem.Size);
		return result;
		pattern = string that define the selection pattern
			1 or + = pick element
			0 or - = skip element
	var applyPatternToPointArray = function(source, pattern)
		function ResultObj(pattern) {
			this.array = new pointArray();
			this.pattern = pattern;
		var result = new ResultObj(pattern);
		if (pattern) {
			result.pattern = pattern.trim();
			if (result.pattern != '') {
				usePattern = result.pattern.match('^[+\-0-1]+$');
				if (usePattern) {
					usePattern = !result.pattern.match('^[+1]+$');
					if (usePattern) {
						isMixedPattern = !result.pattern.match('^[\-0]+$');
		if (usePattern) {
				var patLen = result.pattern.length;
				var cn = 0;
					if ( result.pattern[cn] === '1' || result.pattern[cn] === '+') {
						result.array.push(source_elem.pt.x,
							source_elem.pt.y,
							source_elem.pt.z,
							source_elem.AngleX,
							source_elem.AngleY,
							source_elem.AngleZ,
							source_elem.Size);
					cn = (cn < (patLen - 1)) ? (cn + 1) : 0;
		} else {
			result.pattern = '';
			result.array = source;
		return result;
	// Business logic
	this.properties.start_idx = this.getInputData(1, this.properties.start_idx);
	var patternedArray;
	var outputIntermediate;
	var outIntermLength;
	if (this.properties.mode[0] == "Pattern + Subset") {
		patternedArray = applyPatternToPointArray(source, this.properties.pattern);
		outputIntermediate = patternedArray.array;
		outIntermLength = outputIntermediate.getLength();
	} else {
		outputIntermediate = source;
		outIntermLength = source.getLength();
	if ((this.properties.start_idx < 0) || (this.properties.start_idx > (outIntermLength - 1))) this.properties.start_idx = 0;
	if (this.properties.qt_max < 0) this.properties.qt_max = outIntermLength;
	outputIntermediate = getPointArraySection(outputIntermediate,
						this.properties.start_idx,
						this.properties.qt_max,
	if (this.properties.mode[0] == "Subset + Pattern") {
		patternedArray = applyPatternToPointArray(outputIntermediate, this.properties.pattern);
	this.properties.pattern = patternedArray.pattern;
	patternedArray = null;
	this.outputs[0].label = "Out (" + outputIntermediate.getLength() + ")";
	this.outputs[1].label = "Elems (" + outputIntermediate.getLength() + ")";
	this.inputs[0].label = "In (" + source.getLength() + ")";
	this.setOutputData(0, outputIntermediate);
	this.setOutputData(1, outputIntermediate.getLength());
// ArrayReplicator
function ArrayReplicator()
	this.labels = "abcdef";
	this.size = [140,40];
	this.minsize = [140,40];
	this.internal = {a:1, b:1};
ArrayReplicator.title = "Array Replicator";
ArrayReplicator.desc = "Array Replicator";
ArrayReplicator.prototype.onGetOutputs = function()
	var list = [];
	for ( var i = 0; i<this.labels.length; i++ )
		var out = this.labels.charAt(i);
		if ( !(out in this.internal)) { list.push([this.labels.charAt(i),"pointarray", {locked:true}]); break; }
	return list;
ArrayReplicator.prototype.onOutputAdded = function(out)
	this.internal[out.name] = 1;
	for ( var i in this.outputs ) this.outputs[i].locked = true;
	if (i>1) this.outputs[i].locked = false;
ArrayReplicator.prototype.onOutputRemoved = function(slot, name)
	if ( this.internal[name] ) delete this.internal[name];
	if ( this.outputs.length > 2 )this.outputs[i].locked = false;
ArrayReplicator.prototype.onAdded = function()
	for ( var i = 0; i<this.labels.length; i++ ) if ( this.internal[this.labels.charAt(i)] && this.outputs.length == i ) this.addOutput(this.labels.charAt(i), "pointarray");
	this.setDirtyCanvas(true);
ArrayReplicator.prototype.onExecute = function()
	for ( var i = 0; i<this.outputs.length; i++)
		this.setOutputData(i, source);
LiteGraph.registerNodeType("Arrays/ArrayReplicator", ArrayReplicator);
Size: 155.3 KB, Downloaded: 146 times, Dimensions: 1522x822px
Size: 1.1 MB, Downloaded: 181 times, Dimensions: 1918x1035px
Cool thing to have all possible nodes in one wink!
7713.343
Hi guys!
Sorry, I didn't write a line of code this week. I was so busy at work.
Maybe next week I'll continue developing of this project.
Marco, this ArrayReplicator looks good, but it will be better if we use a multiple output connections. ;)
EDITED: 7 Mar 2022 by SMIRNOV
7713.344 In reply to 7713.343
Hi Max,
I totally agree with you!
While waiting your next NodeEditor release, i'm still playing with array nodes, and after "PatternSelArray" and "ArrayReplicator",
i'm thinking to write :
- "ArrayShuffler" : shuffle the elements inside one array
- "ArrayInspector" : it should output to a textarea, the numeric values of all array elements. Useful for debugging purposes.
- "ArrayExporter" : it should output to a file, the numeric values of all array elements.
- "RandomArray" : In should generate random points inside a 3d cube area.
These ideas are nothing more then a funny and simple javascript programming practice for me,
simple ideas that you might find interesting.
Nice night to all,
Marco.
7713.345 In reply to 7713.343
Hello Max,
the main thing , you are well . I enjoy the break:-)
Have a nice weekend
Karsten
Here is a lighter color for the Canvas.
Under nodeeditor/core/imgs, save the original grid.png, and replace it with the lighter grid.png.
The colors of the original grid was inverted. This was done with Gimp2, or with Greenfish Icon Editor Pro (GFIE).
The lighter colors were swapped with GFIE. GFIE does not compress the PNG, so PNGGauntlet was used to shrink the PNG file size.
A button to select the grid colors might be nice, as well as an even lighter grid for printing.
- Brian (Grid.png removed as it is no longer used.)
EDITED: 18 Mar 2017 by BEMFARMER
7713.347 In reply to 7713.346
I made an even lighter grid, but the cursor is almost invisible. :-(
The few icon/png editors I've tried have been difficult to use as well.
7713.348 In reply to 7713.346
. So how do I delete a message?
7713.349 In reply to 7713.348
In the bottom right corner of a message there's a "more" link and if you click it a menu will pop out with a "Delete" link on it.
If that doesn't work, just give a link to the message you want to delete and I can do it for you too.
7713.350 In reply to 7713.349
Thank you Michael.
(I've been unable to delete from the edit window.)
7713.351 In reply to 7713.348
Hello Brian,
dont't delete the message. The cursor can be customized with e.g. Gimp. Take a cursor example (also png) from this thread and change form and color and share it also, please.
Have a nice day
Karsten
7713.352 In reply to 7713.351
To switch to an arrow cursor, locate the litegraph.css file under nodeeditor\css\, and change "crosshair" to "default", without the quote marks.
(Line 4)
https://css-tricks.com/almanac/properties/c/cursor/
Attached is a lighter grid.png replacement for the canvas. In the canvas display it still seems to be relatively dark.
The Wand selector of the Greenfish Icon editor cannot distinguish between two different tints and/or tones and/or shades, which are nearly the same .
This makes it hard to select the proper areas of the grid.png for editing.
The Wand selector of the IcoFX2 icon editor can so distinguish, but does not do Hex colors. Setting one of the two colors of Grid.png to a very different color allows the .png to be edited in the Greenfish Icon editor, which does do Hex colors.
Grid.png removed as no longer needed.
Show messages:  1-12  …  273-292  293-312  313-332  333-352  353-372  373-392  393-412  …  893-912
