Parametric design in MoI?
 1-12  …  273-292  293-312  313-332  333-352  353-372  …  893-912
7713.313 In reply to 7713.311
Hi Karsten,
Thank you for your reply.
Only for info....my name's Marco, not Mauro.
Regarding my last nodes (Circles, GetBBoxes, Cones, Cylinders and Spheres), almost totally based on Max's original nodes,
i'll try to find time to publish some screen cap.
Meantime you could use the .node file that i posted in http://moi3d.com/forum/messages.php?webtag=MOI&msg=7713.310.
N.B. : All the nodes needs latest version of Max's node editor (0.65b).
In my garbage time i'm working on others ideas and little refinement for this fantastic plugin, that Max gave us.
1) Making nodes : Rectangles, Polygons, Stars
2) Creating a node that could do this thing :
a) Accept a Pointarray as input
b) Provide some criteria to define a sort of slicing rules to apply to the array.
c) Return a the resulting Pointarray or an "array of Pointarray"
For example, given a point array of 100 elements, define a criteria (using a math formula ?) to slice the original array
into 5 little arrays, each of which containing only certain elements of the original array.
3) Try to do a little refinement of the NodeEditor's UI, like illustraded in the attached pictures.
What do you think about these ideas ?
I also hope that Max will appreciate.
Ciao!
Marco.
Size: 291 KB, Downloaded: 188 times, Dimensions: 1637x1160px
Size: 1.3 MB, Downloaded: 135 times, Dimensions: 1917x1035px
7713.314 In reply to 7713.313
Hello Marco,
sorry for that! I know it :-)
I have made a quick test of your nodes and I like them :-) I hope that Max will integrate it. One thing I would prefer, is to collect new nodes first in a separate JS-File, so e.g. curvesMKDM.js with a separate Menu, so everybody can set apart the nodes from Maxs core development. And you can register them for tests very simple in the index.htm.
Updates and a discussion about is in my opinion also easier.
Anyway, the idea is good and we have some new nodes for playing:-)
Have a nice weekend
Karsten
Message 7713.315 deleted 8 Aug 2020 by JFH
7713.316 In reply to 7713.314
Hello Karsten,
Here's my new node : PatternSelectArray
It's an idea based on the Max's script PatternSelection.
(http://moi3d.com/forum/index.php?webtag=MOI&msg=6518.11)
// PatternSelectArray
function PatternSelArray()
	this.addInput("In","pointarray");
	this.addOutput("Out","pointarray");
	this.addOutput("Elems","number");
	this.properties = { pattern:"+-", elems:0 };
PatternSelArray.title = "PatternSelArray";
PatternSelArray.desc = "PatternSelArray";
PatternSelArray.prototype.onExecute = function()
	var output = new pointArray();
	var source = this.getInputData(0, new pointArray());
	if (this.properties.pattern == '') this.properties.pattern = "+-";
	var len = source.getLength();
	var cn = 0;
	for (i = 0; i < len ; i++) {
		if ( this.properties.pattern[cn] === '1' || this.properties.pattern[cn] === '+') {
			var source_elem = source.getElement(i);
			output.push(source_elem.pt.x,
				source_elem.pt.y,
				source_elem.pt.z,
				source_elem.AngleX,
				source_elem.AngleY,
				source_elem.AngleZ,
				source_elem.Size);
		cn = (cn < this.properties.pattern.length-1) ? cn+1 : 0;
	this.properties.elems = output.getLength();
	this.setOutputData(1, output.getLength());
LiteGraph.registerNodeType("Arrays/PatternSelArray", PatternSelArray);
In order to use it, it's necessary to add this function definition to the "pointArray" section of the file litegraph.js
pointArray.prototype.getElement = function(n)
	var shift = n*this.recordLength;
	var element = {"pt":this.getPoint(n),
		"AngleX":this.data[shift+3],
		"AngleY":this.data[shift+4],
		"AngleZ":this.data[shift+5],
		"Size":this.data[shift+6]};
	return element;
I hope it can be useful.
Ciao!
Marco.
Size: 114.2 KB, Downloaded: 158 times, Dimensions: 1520x822px
Size: 912 KB, Downloaded: 120 times, Dimensions: 1917x1035px
7713.317 In reply to 7713.315
Hi James,
>I wonder though whether it would be simpler to just add these to
>the CloneToArray node rather than to each of the curve/solid nodes,
>to achieve the same effect?
It could be a very good idea, but i don't know if the results would be the same.
That is, CloneToArray can generates Points, whilemy intention was to maintain the output as plain Pointarray.
But i'm sure that all this things could be intermixed.
I will make some test.
Anyway, thanks for your interesting suggestion.
Regards.
Marco.
Message 7713.318 deleted 25 Apr 2019 by JFH
7713.319 In reply to 7713.317
Hello Marco,
I don't have tested the pattern manipulation at the moment, but it's another very interesting idea. I'm not a "pattern man", but I can't avoid some ideas to the stuff (damn, I really wanted to do something different ;-): Is it possible to make a random option? Would it then be possible to create sinter materials, porous materials like cheese, particles ... with some clicks? Or is it possible to split in two,three, ... streams of pointarrays (random or structured) to create mosaics???
Anyway, let the ideas flow and share them:-)
Many thanks
Karsten
7713.320 In reply to 7713.319
@Marco,
in my opinion, the idea with the node overview panel can help a lot in the future, but think about scrollbars:-) Max should have a look!
7713.321
Hi Marco,
thank you for nodes.
In fact I already writing SplitArray node, which can split point arrays according a pattern or a logical expression.
Also I have plans to use series everywhere instead of number type. Therefore I'll rewrite all basic nodes such as circle, sphere, cone etc.
7713.322 In reply to 7713.318
Hi James,
Thanks a lot for your appreciations...
At the moment i'm thinking about many ideas regarding the possibility to integrate all pointArray nodes,
with a unified logic in order to better manages series, patterns, and the order in witch those points are picked and passed to output.
But i must admint that it's not so easy, 'cause i'm not quite familiar with math formulas :)
But, some minutes ago, i've just read that Max is working on all these ideas....
So while waiting its solutions, i keep on working on my personal tests.
Have a nice day!
P.S. Where's the Sweep node that you used in your test ? Could you share it ?
Marco.
7713.323 In reply to 7713.321
Hi Max,
Thanks for everything, i'm pleased that you appreciated my attempts to create new logic for array nodes.
with a unified logic in order to better manages series and patterns.
I'm also thinking about a unified method to specify how is the order in witch the points of the array, could be picked up.
just in order to create a less random and not predictable outputs.
This is hard to achieve i think...
But i must admit that it's not so easy, 'cause i'm not quite familiar with math formulas :)
Anyway, i was happy to read that you are already working on all these ideas!
So while waiting your solutions, i keep on working on my personal tests.
P.S.
I hope hat you share this idea.
Have a nice day!
Marco.
7713.324 In reply to 7713.319
Hi Karsten,
Thanks a lot for your appreciations and suggestions!
And keep on working together on sharing new ideas.
Have a nice day!
Marco.
7713.325 In reply to 7713.322
Hi Marco
Sweep node was one contributed by Karsten.
I can't find the original thread
but please find all attached
-James
EDITED: 14 May 2019 by JFH
7713.326 In reply to 7713.324
Hello Marco,
if you want to use sweep it is also useful to evaluate the startFrame of the railcurve for profile placement. You will find a node for that in infonodes. To get it run you have to replace the pushFrame function in litegraph.js with the posted in this thread. What I am think about at the moment is to put such meta informations like startframes of curves, boundingboxes, curve length, mass, ... in a functions container. Max has already made a addOutput-function. I think it would be better to put such functions as additional outputs to nodes, than create separate nodes for it. Unfortunateli are my programming skill are very limited and I can't find a node with an addOutput as a template to study. Maybe Max have one?
A nice weekend to all
Karsten
7713.327 In reply to 7713.325
Hi James,
Thanks for your prompt reply!
Ciao!
Marco.
7713.328 In reply to 7713.326
Hi Karsten,
Thanks for your reply and your suggestions.
As soon as possible i'll take a better look at those functions and nodes.
Nice day,
Marco.
7713.329
Hi Karsten,
looking at your motor node using the boolean function to indicate a clash of objects gave me an idea.
Is it possible to automatically space an array by using the boolean function.
At the moment I have a AutoArray based on the object bounding box plus gap and orientation
that will automatically fill a given square or rectangle area.
The only problem with this is I have to manually adjust the gap for objects that can
overlap the bounding box.
Ideally I would like to set a minimum gap between objects to maximise the fill.
The way I see it working is to Offset the object by half the gap required.
Space the array centres based on the offset object bounding box .
If boolean of offset object = true ok finish
else reduce centres by given step till boolean true.
So the question is how do I get a true or false from the boolean to use and how to keep
looping reducing the centre distance till true.
Any idea's ?
Barry.
7713.330 In reply to 7713.329
Hi Barry,
the simplest way to detect a clash is in my opinion the number of result objects of an intersection. No intersection - no result. So it should be possible to make an interation until no resultobjects exists or vice versa. I don't have time at the moment, so I hope it helps in a first step.
Have a nice day
Karsten
7713.331 In reply to 7713.330
p.s.: An iterration algorithm has to be defined inside one node, because I`m not sure if loops are really possible in the nodeeditor.
7713.332 In reply to 7713.331
I have seen a feedback loop for another node-type program.
Show messages:  1-12  …  253-272  273-292  293-312  313-332  333-352  353-372  373-392  …  893-912
