Parametric design in MoI?
 1-11  …  252-271  272-291  292-311  312-331  332-351  …  912
7713.292
Added properties fix for Output node for back compatibility with old .nod files.
EDITED: 7 Mar 2022 by SMIRNOV
7713.293 In reply to 7713.289
Hi Pilou
See attached, Includes:
Series
Range
DegToRad ( degree to Radian Conversion, You can use Math node for this )
RadToDeg ( Radian to Degree Conversion, You can use Math node for this )
sharif
7713.294 In reply to 7713.288
@Sharif: thx!
@Max
Any of previous nodes works with this new version ???
Result of expression "This properties style" [undefined] is not an object.
EDITED: 12 May 2016 by PILOU
7713.295 In reply to 7713.294
Pilou, yes, I'm sure.
Replace original litegraph-editor.js with the attached file
Now you need to press New button longer to reset the editor.
7713.296 In reply to 7713.295
OK I have now several colors for the Style but not this "Draft" :)
but always all previous nodes loaded don't work with this version 6.5
Nodes saved with this version 6.5 work fine!
7713.297 In reply to 7713.292
Hello Max,
I'm not sure that the pushFrame works:
pointArray.prototype.pushFrame = function(frame)
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?90:-90; }
else
rx = Math.atan2(frame.zaxis.y, frame.zaxis.z);
ry = -Math.asin(frame.zaxis.x);
rz = Math.atan2(frame.xaxis.z*Math.sin(rx)-frame.xaxis.y*Math.cos(rx), frame.xaxis.x*Math.cos(ry)+(frame.xaxis.y*Math.sin(rx)+frame.xaxis.z*Math.cos(rx))*Math.sin(ry));
this.data.push(frame.origin.x); this.data.push(frame.origin.y); this.data.push(frame.origin.z);
this.data.push(rx); this.data.push(ry); this.data.push(rz);
this.data.push(1);
this.xlength++;
I'm missing the conversion to deg?
What works for me at the moment is something like:
pointArray.prototype.pushFrame = function (frame)
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?Math.PI/4:-Math.PI/4; }
else
ry = -Math.asin(Math.round(frame.zaxis.x*10000)/10000);
this.data.push(rx * 180 / Math.PI);
this.data.push(ry * 180 / Math.PI);
this.data.push(rz * 180 / Math.PI);
this.data.push(1);
// this.xlength++;
Although, for the gimbal lock is a calculation vor rx or rz is missing?? e.g. rz = Math.atan2(frame.yaxis.z,frame.yaxis.y); with rx=0;???
Nevertheless, tomorrow is a new day!
Karsten
7713.298 In reply to 7713.297
Hey Max,
If you try and set output style property "before" running the node it will produce an error. If you run node first, then style is applied great!
I ran old "jitter node"... But example node and others like motor error out. Hopefully you are just making those future changes now...
7713.299
Pilou, BurrMan
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.292
Karsten,
Yes, I forgot about rad-deg translation :)
Thank you
7713.300 In reply to 7713.299
Works now like a charm! :)
It's always no need to translate what is out of the lang.js file ?
(for the Info or some info node message like "(input locked)" when you Right Click on an input node point
7713.301 In reply to 7713.299
Hey Max,
Here's the workflow error with the new styles element:
And then a quick error on the old "example" node:
7713.302 In reply to 7713.301
Hello Burrman,
please try to replace the marked area with shown line in nodes\basic.js - and give a feedback:-)
MoIOutput.prototype.updateObjects = function()
this.onClear();
var changeStyle = (this.properties.style[0] !== this.properties.style[1] && this.sIndex !== -1);
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
if(inObj!==null){for ( var i = 0; i<inObj.length; i++) this.tempobjects.addObject(changeStyle?inObj.item(i).clone():inObj.item(i));};
for ( var i=this.tempobjects.length; i>0; i-- ) this.tempobjects.item(i-1).setHitTest(0);
if (changeStyle) this.tempobjects.setProperty( 'styleIndex', this.sIndex);
moi.geometryDatabase.addObjects(this.tempobjects);
Have a nice day
Karsten
7713.303 In reply to 7713.302
That worked..... That eliminated the workflow error. Should ask Max to take a look.
Thanks Karsten.
7713.304 In reply to 7713.303
The example node error still exists in the construct.js file though.
I'm not going to be running all the created nodes because of such heavy development right now... Maybe Max should just keep "example" updated as needed with any major release... So I don't bug him about "an old node doesn't work...." stuff, when he already knows that, etc....
7713.305 In reply to 7713.304
Yes, I had also a look to that node, but I can't see any problems ... recreate it:-)
7713.306 In reply to 7713.304
Hello Burrman,
I had another look into the v.0.4 code: The problem is quiet simple - loft node in V0.4 hasn't the feature for closed:-)
Have a nice day
Karsten
7713.307 In reply to 7713.288
Hi Max,
>> added Style property in the Output node
Thank you very much for this new feature!
It's exactly what i wanted.
P.S.
I noticed that the "Circle" node only generates one single circle whatever the input "pointarray" is.
So i wrote a little modified version called "Circles" that generates as many as the points contained in the array.
Furthermore, it is possible to limit the total number of generated circle, to a specified amount.
This amount can be >=1 AND <= the number of points contained in the array.
And is also possible to specify a step amount for the for-loop.
Here's the code :
// Circles
function Circles()
	this.addInput("Center","pointarray");
	this.addInput("Radius","number");
	this.addInput("Elements","number");
	this.addInput("Step","number");
	this.properties = { radius:1, elements:1, step:1 };
Circles.title = "Circles";
Circles.desc = "Circles";
Circles.prototype.onExecute = function()
	var output = moi.geometryDatabase.createObjectList();
	var centers = this.getInputData(0, new pointArray());
	var len = centers.getLength();
	this.properties.radius = this.getInputData(1, this.properties.radius);
	this.properties.elements = this.getInputData(2, this.properties.elements);
	if (this.properties.elements <= 0) this.properties.elements = 1;
	this.properties.step = this.getInputData(3, this.properties.step);
	if (this.properties.step <= 0) this.properties.step = 1;
	if (this.properties.step > len) this.properties.step = len;
	for (i = 0; i < len && i < this.properties.elements; i += this.properties.step) {
		var cir = factory( 'circle', true, centers.getFrame(i), null, this.properties.radius );
		output.addObject(cir.item(0));
LiteGraph.registerNodeType("Curves/Circles", Circles);
I've also done the "GetBBoxes" node that follow the same logic.
Here's the code :
function GetBBoxes()
	this.addInput("In","objectlist");
	this.addOutput("BBox Center","pointarray");
	this.properties = { elements:0, step:1 };
GetBBoxes.title = "BoundingBoxes";
GetBBoxes.desc = "Get BoundingBoxes";
GetBBoxes.prototype.onExecute = function()
	var input = this.getInputData(0, moi.geometryDatabase.createObjectList());
	var len = input.length;
	var bbox = new pointArray();
	this.properties.elements = this.getInputData(1, this.properties.elements);
	if ((this.properties.elements <= 0) || (this.properties.elements > len)) this.properties.elements = len;
	this.properties.step = this.getInputData(2, this.properties.step);
	this.setOutputData(0, input);
		bbox.pushPoint(input.item(i).getBoundingBox().center);
	this.setOutputData(1, bbox);
LiteGraph.registerNodeType("Objects/GetBBoxes", GetBBoxes);
Have a nice day.
Marco.
EDITED: 13 May 2016 by MKDM
7713.308 In reply to 7713.285
Hi Karsten,
and thank you for code.
I was examining the code but i must admit that i can't figure out what are the data types that it accepts in input.
function PtArrayConcat()
	this.labels = "abcdef";
	this.size = [60,20];
	this.internal = {a:1, b:1};
	this.addOutput("Out", "pointarray");
Could you kindly explain ?
Anyway...thanks for your reply.
Nice day.
Marco.
7713.309 In reply to 7713.308
Hello Marco,
since yesterday the code is obsolete - Max has implemented the node also in his new version. Nevertheless, inputs are of type pointarray.
A nice weekend
Karsten
7713.310 In reply to 7713.309
Hi Karsten,
thanks anyway and, if you want, take a look at my "Circles" and "GetBBoxes" nodes
that i posted some minutes ago.
Ciao!
Marco.
P.S.
How funny can be playing with nodes !!
Here's my other 3 nodes that follow the same rules of my "Circles" and "GetBBoxes" :
// Cones
function Cones()
	this.addInput("Height","number");
	this.properties = { radius:1, height:1, elements:1, step:1 };
Cones.title = "Cones";
Cones.desc = "Cones";
Cones.prototype.onExecute = function()
	this.properties.height = this.getInputData(2, this.properties.height);
	this.properties.elements = this.getInputData(3, this.properties.elements);
	this.properties.step = this.getInputData(4, this.properties.step);
		var frame = centers.getFrame(i);
		var cone = factory('cone', true, frame, null, this.properties.radius, frame.evaluate(0,0,this.properties.height));
		output.addObject(cone.item(0));
LiteGraph.registerNodeType("Solids/Cones", Cones);
// Cylinders
function Cylinders()
Cylinders.title = "Cylinders";
Cylinders.desc = "Cylinders";
Cylinders.prototype.onExecute = function()
		var cylF = moi.command.createFactory( 'cylinder' );
		cylF.setInput(0, true);
		cylF.setInput(1, frame);
		cylF.setInput(3, this.properties.radius);
		cylF.setInput(4, frame.evaluate(0,0,this.properties.height));
		var cyl = cylF.calculate();
		output.addObject(cyl.item(0));
		cylF.cancel();
LiteGraph.registerNodeType("Solids/Cylinders", Cylinders);
// Spheres
function Spheres()
//	this.size = [60,20];
Spheres.title = "Spheres";
Spheres.desc = "Spheres";
Spheres.prototype.onExecute = function()
		var sphF = moi.command.createFactory( 'sphere' );
		sphF.setInput(0, true);
		sphF.setInput(1, frame);
		sphF.setInput(3, this.properties.radius);
		var sph = sphF.calculate();
		output.addObject(sph.item(0));
		sphF.cancel();
LiteGraph.registerNodeType("Solids/Spheres", Spheres);
7713.311 In reply to 7713.310
Hello Mauro,
Thanks for sharing ideas and nodes.
I like the idea more and more. Maybe it is also possible to use the mystic 7th value in the pointarry structure "scale" (radius * scale)?. I will definitively play with your nodes at the weekend :-)
Maybe you can make a Gif or some pictures, to give an impression of the functinallity!
Many thanks
Karsten
Show messages:  1-11  …  232-251  252-271  272-291  292-311  312-331  332-351  352-371  …  912
