Parametric design in MoI?
 1-2  …  243-262  263-282  283-302  303-322  323-342  …  903-912
@ Max
An Alert Message when we press "New" ?
"Do want to Save before New?" : "Yes / No" for have the Time to Save if not yet done! ;)
7713.284 In reply to 7713.255
Hi Max!
A short question about PontArray...
How would it be possible to collect a specified set of Point objects, into a PointArray ?
That is, starting from a given number of selected points present in scene, how to create a PointArray from them ?
And, what you say about my question at http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.274 ?
Thanks for everything and have a nice day.
Marco.
7713.285 In reply to 7713.284
Hello Marco,
my name isn't Max, but I can you give a node for that. It's a quick and untested hack of Max geniue concat node for Objects. I have changed only the input and output parameters. Please test it. Maybe Max can integrate something like that in his next release, maybe there is something like that already existing? Only Max know all the features:-)
Have a nice day
Karsten
7713.286 In reply to 7713.282
Hi Karsten;
Thank you for explaining. I need to do some examples to understand it better. I am thinking may be frame is similar to "plane Node" in grasshopper.
Regards,
sharif
7713.287 In reply to 7713.282
Hi Karsten;
I have created a Series and a Range Nodes from other example nodes. I like the math node under basic and I was wondering if we can use the math node to generate series and range numbers instead of having separate nodes.
Second question is how I could use these generated number from Series and Range to create points in MOI ( See Attached Image ).
sharif
Size: 37.2 KB, Downloaded: 116 times, Dimensions: 922x669px
7713.288
version 0.65
fixed several bugs
Karsten
>> and a seventh coordinate (maybe useful for homogenous proposes?)
It's a scale :)
I wrote this node already But I'll check your version, maybe I'll find something interesting in it. :)
Marco
added ObjtoArray node. At the moment it works with point objects only.
>>Inside the NodeEditor, it would be possible to render the generated objects, using a particular style, just in order to better highlight them ?
added Style property in the Output node
Maybe in the next beta release..
EDITED: 7 Mar 2022 by SMIRNOV
7713.289 In reply to 7713.287
@Sharif
Why not share your new nodes ?
EDITED: 12 May 2016 by PILOU
7713.290 In reply to 7713.288
Hello Max,
great news!
I don't think so! 99% is your own code - interesting could only be some bugs, that I placed in the rest;-)
Have a nice evening
Karsten
7713.291 In reply to 7713.289
Pilou, check the new version ;)
7713.292
Added properties fix for Output node for back compatibility with old .nod files.
7713.293 In reply to 7713.289
Hi Pilou
See attached, Includes:
Series
Range
DegToRad ( degree to Radian Conversion, You can use Math node for this )
RadToDeg ( Radian to Degree Conversion, You can use Math node for this )
sharif
7713.294 In reply to 7713.288
@Sharif: thx!
@Max
Any of previous nodes works with this new version ???
Result of expression "This properties style" [undefined] is not an object.
7713.295 In reply to 7713.294
Pilou, yes, I'm sure.
Replace original litegraph-editor.js with the attached file
Now you need to press New button longer to reset the editor.
7713.296 In reply to 7713.295
OK I have now several colors for the Style but not this "Draft" :)
but always all previous nodes loaded don't work with this version 6.5
Nodes saved with this version 6.5 work fine!
7713.297 In reply to 7713.292
Hello Max,
I'm not sure that the pushFrame works:
pointArray.prototype.pushFrame = function(frame)
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?90:-90; }
else
rx = Math.atan2(frame.zaxis.y, frame.zaxis.z);
ry = -Math.asin(frame.zaxis.x);
rz = Math.atan2(frame.xaxis.z*Math.sin(rx)-frame.xaxis.y*Math.cos(rx), frame.xaxis.x*Math.cos(ry)+(frame.xaxis.y*Math.sin(rx)+frame.xaxis.z*Math.cos(rx))*Math.sin(ry));
this.data.push(frame.origin.x); this.data.push(frame.origin.y); this.data.push(frame.origin.z);
this.data.push(rx); this.data.push(ry); this.data.push(rz);
this.data.push(1);
this.xlength++;
I'm missing the conversion to deg?
What works for me at the moment is something like:
pointArray.prototype.pushFrame = function (frame)
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?Math.PI/4:-Math.PI/4; }
else
ry = -Math.asin(Math.round(frame.zaxis.x*10000)/10000);
this.data.push(rx * 180 / Math.PI);
this.data.push(ry * 180 / Math.PI);
this.data.push(rz * 180 / Math.PI);
this.data.push(1);
// this.xlength++;
Although, for the gimbal lock is a calculation vor rx or rz is missing?? e.g. rz = Math.atan2(frame.yaxis.z,frame.yaxis.y); with rx=0;???
Nevertheless, tomorrow is a new day!
Karsten
7713.298 In reply to 7713.297
Hey Max,
If you try and set output style property "before" running the node it will produce an error. If you run node first, then style is applied great!
I ran old "jitter node"... But example node and others like motor error out. Hopefully you are just making those future changes now...
7713.299
Pilou, BurrMan
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.292
Karsten,
Yes, I forgot about rad-deg translation :)
Thank you
7713.300 In reply to 7713.299
Works now like a charm! :)
It's always no need to translate what is out of the lang.js file ?
(for the Info or some info node message like "(input locked)" when you Right Click on an input node point
7713.301 In reply to 7713.299
Hey Max,
Here's the workflow error with the new styles element:
And then a quick error on the old "example" node:
7713.302 In reply to 7713.301
Hello Burrman,
please try to replace the marked area with shown line in nodes\basic.js - and give a feedback:-)
MoIOutput.prototype.updateObjects = function()
this.onClear();
var changeStyle = (this.properties.style[0] !== this.properties.style[1] && this.sIndex !== -1);
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
if(inObj!==null){for ( var i = 0; i<inObj.length; i++) this.tempobjects.addObject(changeStyle?inObj.item(i).clone():inObj.item(i));};
for ( var i=this.tempobjects.length; i>0; i-- ) this.tempobjects.item(i-1).setHitTest(0);
if (changeStyle) this.tempobjects.setProperty( 'styleIndex', this.sIndex);
moi.geometryDatabase.addObjects(this.tempobjects);
Have a nice day
Karsten
Show messages:  1-2  …  223-242  243-262  263-282  283-302  303-322  323-342  343-362  …  903-912
