Parametric design in MoI?
 1-13  …  234-253  254-273  274-293  294-313  314-333  …  894-912
7713.274 In reply to 7713.267
Hi Max and Karsten,
First of all, i wish to thank you for your efforts and for your constant developing!
Inside the NodeEditor, it would be possible to render the generated objects, using a particular style, just in order to better highlight them ?
The attached pictures show the actual Grasshopper's way...
And it would be possible to automatically select the generated objects, and eventually, assigning them to a particular style ?
Thanks for everything and have a nice day!
Marco.
Size: 652.7 KB, Downloaded: 101 times, Dimensions: 1340x964px
Size: 61.5 KB, Downloaded: 108 times, Dimensions: 630x541px
7713.275 In reply to 7713.274
You can yet put a color to a node
Right Click on a node!
7713.276 In reply to 7713.267
Hello Max,
let me make a last remark about the pushFrame before you release it. Your code works fine and I can't figure out any problems:-)
(little changes: clamp frame.zaxis.x to [-1;1] | ?90:-90; -> Math.PI/4;-Math.PI/4)
The function sets in gimbal lock ry to ?90:-90. Am I right, that we need in that situation at least a rx- or rz-calculation?
Something like (not tested):
rz = Math.atan2(frame.yaxis.z,frame.yaxis.y); or a direction dependent rz=Math.asin(frame.xaxis.y)??? with rx=0
As mentioned, in tests I didn't run in that situation:-)
Have a nice day
Karsten
7713.277 In reply to 7713.276
Have you a graphic example of the use of the function "PushFrame" ?
7713.278 In reply to 7713.277
Hello Pilou,
it's an internal function of the nodeeditor to push a frame in a pointarray. Caused by the switch to this united datatype I need it to e.g. evaluate the startpoint orientation of a curve and provide an orientated (point inculding frame )pointarray-type as an output. So you can make a curve, get the startframe and align a circle to it for a e.g. sweep.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.53
The only diffrence to this example is that I separated the function form the curve (old GeneralCurve) in a node. Advantage: you can use the node for various curves.
You will find a draft in getCurveStartFrame in Infonode.js posted here. Problem: the name is to long -> to much space wastage on @'y'@ surface - any ideas?
Have a nice day
Karsten
7713.279 In reply to 7713.278
p.s.: getPushFrame and showFrame are only nodes for test purposes:-)
7713.280 In reply to 7713.278
Thx for the infos!
7713.281
Hi All;
I am trying to understand the frame in the max's NodeEditor. Some nodes have frame input and output. Can someone please explain what is Frame? what kind of input requires for frame input. Is the frame in Max's nodeeditor is the same as frame in MOI.
sharif
7713.282 In reply to 7713.281
Hello Sharif,
the simplest explanation for a frame is local coordinate system. So the frame has a basepoint, a x-axis, a y-axis and a z-axis in Moi. Max has created a new combined datatype for points and frames called pointarray which has a high flexibility. Every element consists of 3 coordinates (x,y,z) and 3 Euler angles (Notation X,Y',Z'') and a seventh coordinate (maybe useful for homogenous proposes?). If you create a frame node, a pointarray with one element in it will be created. You can manipulate the angles to orientate this virtual frame. Typically nodes for objects, that needs a frame as an input in Moi, are labeled with center. Nevertheless you can also connect a point node to it, because the angle infos (point node has also pointarray output) and so the frame informations are present. Only limitation: The point node has no rotation inputs. The big advantage of Max design is the flexibility, reduction of wires and make uniformly arrays of points/frames possible. An good example for the flexibility is Max line node: You can connect a single frame or point as input or complete streams of points/frames -> pointarray. The node will do the rest!
I hope you get me, my english is not the best!
Karsten
@ Max
An Alert Message when we press "New" ?
"Do want to Save before New?" : "Yes / No" for have the Time to Save if not yet done! ;)
7713.284 In reply to 7713.255
Hi Max!
A short question about PontArray...
How would it be possible to collect a specified set of Point objects, into a PointArray ?
That is, starting from a given number of selected points present in scene, how to create a PointArray from them ?
And, what you say about my question at http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.274 ?
Thanks for everything and have a nice day.
Marco.
7713.285 In reply to 7713.284
Hello Marco,
my name isn't Max, but I can you give a node for that. It's a quick and untested hack of Max geniue concat node for Objects. I have changed only the input and output parameters. Please test it. Maybe Max can integrate something like that in his next release, maybe there is something like that already existing? Only Max know all the features:-)
Have a nice day
Karsten
7713.286 In reply to 7713.282
Hi Karsten;
Thank you for explaining. I need to do some examples to understand it better. I am thinking may be frame is similar to "plane Node" in grasshopper.
Regards,
sharif
7713.287 In reply to 7713.282
Hi Karsten;
I have created a Series and a Range Nodes from other example nodes. I like the math node under basic and I was wondering if we can use the math node to generate series and range numbers instead of having separate nodes.
Second question is how I could use these generated number from Series and Range to create points in MOI ( See Attached Image ).
sharif
Size: 37.2 KB, Downloaded: 116 times, Dimensions: 922x669px
7713.288
version 0.65
fixed several bugs
Karsten
It's a scale :)
I wrote this node already But I'll check your version, maybe I'll find something interesting in it. :)
Marco
added ObjtoArray node. At the moment it works with point objects only.
added Style property in the Output node
Maybe in the next beta release..
EDITED: 7 Mar 2022 by SMIRNOV
7713.289 In reply to 7713.287
@Sharif
Why not share your new nodes ?
EDITED: 12 May 2016 by PILOU
7713.290 In reply to 7713.288
Hello Max,
great news!
I don't think so! 99% is your own code - interesting could only be some bugs, that I placed in the rest;-)
Have a nice evening
Karsten
7713.291 In reply to 7713.289
Pilou, check the new version ;)
7713.292
Added properties fix for Output node for back compatibility with old .nod files.
7713.293 In reply to 7713.289
Hi Pilou
See attached, Includes:
Series
Range
DegToRad ( degree to Radian Conversion, You can use Math node for this )
RadToDeg ( Radian to Degree Conversion, You can use Math node for this )
sharif
Show messages:  1-13  …  214-233  234-253  254-273  274-293  294-313  314-333  334-353  …  894-912
