Parametric design in MoI?
 1-8  …  209-228  229-248  249-268  269-288  289-308  …  909-912
7713.249
Karsten
Thank you very much. I'll check all your code today.
>>In a short test I can't run the circle-node?
My fault. Fixed.
curves.js, line 59
var output = factory( 'circle', true, center.getFrame(0), null, this.properties.radius );
>>The original crosshair has in my opinion not enough contrast.
It's looks good for me, but I'll add this line to css
bemfarmer
>>Except for "Clean" :-)
Could you explain, what's wrong with it? My english is far from good. Should I use "Clear" instead?
7713.250 In reply to 7713.249
It's Resolved!
PS I have not a,b inside the MathArray as shown on the "Line Video" above ?
No Multiple Clone ?
Edit : about the a,b :):): You can add them by Right Click on the Node MathArray then "Inputs" !
Last French Version! :)
By Max S
EDITED: 7 May 2016 by PILOU
7713.251 In reply to 7713.250
There are a lot of words to translate.
Stop is not translated.
- B
7713.252 In reply to 7713.251
<< There are a lot of words to translate.
like what ?
<< Stop is not translated
No need it's the same! ;)
Don't work ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/glitch01.nod
Edit: works! I don't must start from a & b but from others! :)
How made that ?
From left to right
7713.255
v0.6
added Jitter,Rotate,MoveArray nodes
added pushFrame function
added custom mouse cursor support (put cursor.png to /core/imgs directory)
EDITED: 7 Mar 2022 by SMIRNOV
7713.256 In reply to 7713.255
Crazzy speed of production!
French Version :)
7713.257 In reply to 7713.252
https://answers.yahoo.com/question/index?qid=20130909122044AAx7iew
http://www.wordhippo.com/what-is/the/french-word-for-stop.html
I was contemplating doing Spanish (ES), but after looking at all the French words, it would have to be proof read by
someone who knows Spanish, to avoid errors. :-)
7713.258 In reply to 7713.257
http://www.wordreference.com/fren/stop ;)
Look at the second line of the second column !
And don't forget that I am also French from my first day of birth! :)
And that we also have the small words possible for the UI!
EDITED: 8 May 2016 by PILOU
Hi Max,
Suggested spelling changes:
Under Add Node, Construct:
Differrence should be spelled Difference.
Substractors should be spelled Subtracters.
Intersectors should be spelled Intersecters.
(The ors endings do sound kind of mathematical.)
Clear (the Output) is more correct than Clean (the Output), in my opinion.
EDITED: 8 May 2016 by BEMFARMER
7713.260 In reply to 7713.258
Hi Pilou
Thank you for all of your hard work.
It would be impossible for myself to do it.
3 very minor observations:
OutPuts should be Outputs, (in my opinion), and would be a duplicate entry.
Center has a duplicate entry.
Loft has a duplicate entry.
I've entered the English words into Excel, and sorted.
EDITED: 24 Sep 2023 by BEMFARMER
7713.261 In reply to 7713.255
Hello Max,
I have tested the pushFrame function. Unfortunately the function gives confusing results and crashes in particular situations. After a look in the code I saw one thing that causes definitely a problem:
>>>> ry = -Math.asin(frame.zaxis.x);
The results range is limited:-( As mentioned by you, it's a hard peace of cake;-)
Have a nice day
and let fly @'y'@
Karsten
7713.262 In reply to 7713.260
I've found Microsofts Terminology Search to be rather helpful for UI translations.
https://www.microsoft.com/Language/en-US/Search.aspx
...shows you somewhat standardized terms used in various (localized) Microsoft products.
7713.263
bemfarmer
Thank you! I'll fix it. :)
Karsten
Which parameters could cause a crash?
What's wrong with this line? The frame.zaxis.x value is always in [-1...1]
7713.264 In reply to 7713.260
@Bemfarmer : Thx for the remarks and files' help!
I must update following each Max's versions (and some variable words) so possible to have some little differences.
I must also adapt with the actual French version of the Moi prog itself and Max Elephant.
Scale... was yet made on my site! http://moiscript.weebly.com/elephant-systegraveme-nodal.html ;)
About the dupplication words you right but as it's any consequence on the result I will erase them at the end.
It's because the list of Max is very short and I take on the fly words using the nodes on the screen! ;)
And sure for excellence i should use some sort's actions like your Excel method ...
About some words like "Widget" there is no satisfactory French translation! :)
A suivre...
EDITED: 9 May 2016 by PILOU
7713.265 In reply to 7713.263
Hello Max,
Yes, thats correct, but if frame.zaxis turns over ry>90deg (z-axis downwards) you will get the same result as between 0-90deg. Another problem:
>>> rx = Math.atan2(frame.zaxis.y, frame.zaxis.z); If frame.z-axis lying on or parallel x-axis -> frame.zaxis.y=0 && frame.zaxis.z=0 -> atan2 will get a bitch ... (NaN) If you catch the situation - you have to check also the orientation:-(
I hate Euler angles now, but I'm to stupid to understand Quaternions in that way, that I can solve the problem with it:-(
Have a nice day
Karsten
7713.266 In reply to 7713.263
p.s: The second described situation is our good old gimbal lock ...
7713.267
Pilou, Brian
I think it's not a good idea to put all words in one sorted list.
It would be better if we make five separate list (as in the russian translation):
1. Main window interface (Save, Load etc )
2. Context menu (Add Node, Colors, Clone, Red, Green ... )
3. Node class names (Arrays, Curves, Solids ..)
4. Node names ( Const, Loft, Extrude, Revolve ... )
5. Inputs/outputs ( Min, Max, Count ... )
Karsten
Yes. I forgot about this. The new version:
var rx=ry=rz=0;
if ( frame.zaxis.y === 0 && frame.zaxis.z === 0) { ry = ( frame.xaxis.z > 0 )?90:-90; }
else
   rz = Math.atan2(frame.xaxis.z*Math.sin(rx)-frame.xaxis.y*Math.cos(rx), frame.xaxis.x*Math.cos(ry)+(frame.xaxis.y*Math.sin(rx)+frame.xaxis.z*Math.cos(rx))*Math.sin(ry));
It's not a problem. For any frame we can get at least 2 sets of angles. It doesn't matter which one we choose.
7713.268 In reply to 7713.267
Hello Max,
thanks for the fast reply. I can't check the code at the moment, maybe in the evening.
Ok, I agree with you. My calculation strategy differs from yours a little bit so I was blind to see:-)
Karsten
Show messages:  1-8  …  189-208  209-228  229-248  249-268  269-288  289-308  309-328  …  909-912
