Parametric design in MoI?
 1-20  …  201-220  221-240  241-260  261-280  281-300  …  901-912
7713.241 In reply to 7713.240
Thank you for this French package. But I would like to give you a couple of advices for a future releases.
- I found few backup files and obsolete nodes in your package. It will be better if you will use my latest packages as is. Just add translation to lang.js. The next version will switch language automatically depending of the interface settings. So no need to change lang.set parameters.
- Don't translate strings like Basic/Constant, Factories/Circular Array etc. It's a waste of time, because it is just a debug info, which shouldn't be translated. I'll remove it in the future.
P.S. I'll fix that "Clean" bug in the next beta release. Don't fix it directly by changing the word in .js file.
7713.242
Just made a significant changes in translation engine to stop that translation hell. Now all labels and node titles are stored in .nod files with english names (with the exception of manually renamed nodes). The script will make all translations on the fly.
Waiting for a bug reports :)
7713.243 In reply to 7713.241
<< I found few backup files and obsolete nodes in your package.
Normal : I increase the dictionnary with the new names without erasing old ones (difficult to see what are they)! :)
<< - Don't translate strings like Basic/Constant ... I'll remove it in the future.
Cool to know!
7713.244 In reply to 7713.242
<< The script will make all translations on the fly.
<< Waiting for a bug reports :)
New version with that is not released ?
Yep!
7713.245
v.0.55 (it may be buggy)
- Changed translation engine
- Added timer features (double click on background to show node timers)
- Added Line node
- Added TextArray node.
Each line => point: [x] [y] [z] [xAngle] [yAngle] [zAngle]. Use space or ; as separator.
Example:
1 2
5 6
10 15
or
1 0 0 0 -90 180
-1 0 0 0 90 0
0 1 0 90 0 90
0 -1 0 -90 0 -90
0 0 1 0 0 0
0 0 -1 0 180 0
EDITED: 7 Mar 2022 by SMIRNOV
7713.246 In reply to 7713.245
Hello Max,
thank you for that great work. - your speed is incredible.
As mentioned, I am working on a pushFrame-function. Here is my first working code with some reworked nodes to test it. Please let me know if you want to improve and integrate it, or we should use an external way.
In a short test I can't run the circle-node?
By the way I made another cursor. The original crosshair has in my opinion not enough contrast. It is a simple PNG which can changed with a simple graphic prog. Activation for those who also need more contrast: open litegraph.css in the css directory and change cursor: crosshair; to cursor: url(./crosscursor.png) 16 16, crosshair; put the crosscursor.png in the same directory.
Have a nice day
Karsten
Size: 404 bytes, Downloaded: 129 times, Dimensions: 32x32px
As of version _NodeEditor0.55.2016.5.06, the language used by NodeEditor is the same as used in the users MoI program,
and is determined by the moi.ini file.
For example, to change from say English to another supported language, say French:
From the MoI screen, select Options, edit moi.ini, then under [UI],
change Language=English to Language=French. (Or Russian)
Currently supported by NodeEditor are Russian, English, and French thanks to Pilou.
(Except for "Clean" :-)
hmm, Russian works in NodeEditor, but does not work in my MoI, because I do not have RussianStrings.txt in MoI ui directory
A google search for "RussianStrings.txt MoI" located a download of the txt file, but I cannot read or understand Russian.
EDITED: 6 May 2016 by BEMFARMER
Cool!
EDITED: 7 May 2016 by PILOU
7713.249
Karsten
Thank you very much. I'll check all your code today.
My fault. Fixed.
curves.js, line 59
var output = factory( 'circle', true, center.getFrame(0), null, this.properties.radius );
It's looks good for me, but I'll add this line to css
bemfarmer
Could you explain, what's wrong with it? My english is far from good. Should I use "Clear" instead?
7713.250 In reply to 7713.249
It's Resolved!
PS I have not a,b inside the MathArray as shown on the "Line Video" above ?
No Multiple Clone ?
Edit : about the a,b :):): You can add them by Right Click on the Node MathArray then "Inputs" !
Last French Version! :)
By Max S
7713.251 In reply to 7713.250
There are a lot of words to translate.
Stop is not translated.
- B
7713.252 In reply to 7713.251
<< There are a lot of words to translate.
like what ?
<< Stop is not translated
No need it's the same! ;)
Don't work ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/glitch01.nod
Edit: works! I don't must start from a & b but from others! :)
How made that ?
From left to right
7713.255
v0.6
added Jitter,Rotate,MoveArray nodes
added pushFrame function
added custom mouse cursor support (put cursor.png to /core/imgs directory)
7713.256 In reply to 7713.255
Crazzy speed of production!
French Version :)
7713.257 In reply to 7713.252
https://answers.yahoo.com/question/index?qid=20130909122044AAx7iew
http://www.wordhippo.com/what-is/the/french-word-for-stop.html
I was contemplating doing Spanish (ES), but after looking at all the French words, it would have to be proof read by
someone who knows Spanish, to avoid errors. :-)
7713.258 In reply to 7713.257
http://www.wordreference.com/fren/stop ;)
Look at the second line of the second column !
And don't forget that I am also French from my first day of birth! :)
And that we also have the small words possible for the UI!
EDITED: 8 May 2016 by PILOU
Hi Max,
Suggested spelling changes:
Under Add Node, Construct:
Differrence should be spelled Difference.
Substractors should be spelled Subtracters.
Intersectors should be spelled Intersecters.
(The ors endings do sound kind of mathematical.)
Clear (the Output) is more correct than Clean (the Output), in my opinion.
EDITED: 8 May 2016 by BEMFARMER
7713.260 In reply to 7713.258
Hi Pilou
Thank you for all of your hard work.
It would be impossible for myself to do it.
3 very minor observations:
OutPuts should be Outputs, (in my opinion), and would be a duplicate entry.
Center has a duplicate entry.
Loft has a duplicate entry.
I've entered the English words into Excel, and sorted.
EDITED: 24 Sep 2023 by BEMFARMER
Show messages:  1-20  …  181-200  201-220  221-240  241-260  261-280  281-300  301-320  …  901-912
