Parametric design in MoI?
 1-11  …  192-211  212-231  232-251  252-271  272-291  …  912
7713.232 In reply to 7713.231
<< Check all js files for another lang.set('EN') call
I have checked that: no such thing is existing! :)
7713.233 In reply to 7713.232
Pilou, could you send all nodeedit files to me?
7713.234 In reply to 7713.233
@Max: Sure!
Here the complete folder nodeeditor who is working! (so with 2 "French dictionnaries" as shown on my image above inside the file lang.js)
http://we.tl/TwsT35rm6z till 12 may 2016
Of course all translations of nodes and other things are not yet made! (All is in Wip building)
but with this yet made and this curious lang.js all works fine in French!
EDITED: 5 May 2016 by PILOU
7713.235
One more node added - TextArray
It converts text data to pointarray. For each point can be set upto six values: x, y, z, x-rotation angle, y-rotation angle, z-rotation angle.
EDITED: 7 Mar 2022 by SMIRNOV
7713.236 In reply to 7713.234
I just changed language to FR and deleted all translations in EN. Everything works great.
Try this.
7713.237 In reply to 7713.236
@Max
This last one with your file works fine!
Why when it's me that was making the same don't working stay a mystery!
I will now continue the translation more serenely! :)
Seems your new functions will delight lovers of Parametric forms!
Actuals nodes! All works fine except this!
Translation of "Clean" don't work! Where is it?
7713.239 In reply to 7713.238
basic.js has "Clean" on line 297.
Test change to Cleeen confirms:-)
nettoyer?
EDITED: 6 May 2016 by BEMFARMER
7713.241 In reply to 7713.240
Thank you for this French package. But I would like to give you a couple of advices for a future releases.
- I found few backup files and obsolete nodes in your package. It will be better if you will use my latest packages as is. Just add translation to lang.js. The next version will switch language automatically depending of the interface settings. So no need to change lang.set parameters.
- Don't translate strings like Basic/Constant, Factories/Circular Array etc. It's a waste of time, because it is just a debug info, which shouldn't be translated. I'll remove it in the future.
P.S. I'll fix that "Clean" bug in the next beta release. Don't fix it directly by changing the word in .js file.
7713.242
Just made a significant changes in translation engine to stop that translation hell. Now all labels and node titles are stored in .nod files with english names (with the exception of manually renamed nodes). The script will make all translations on the fly.
Waiting for a bug reports :)
7713.243 In reply to 7713.241
<< I found few backup files and obsolete nodes in your package.
Normal : I increase the dictionnary with the new names without erasing old ones (difficult to see what are they)! :)
<< - Don't translate strings like Basic/Constant ... I'll remove it in the future.
Cool to know!
7713.244 In reply to 7713.242
<< The script will make all translations on the fly.
<< Waiting for a bug reports :)
New version with that is not released ?
Yep!
7713.245
v.0.55 (it may be buggy)
- Changed translation engine
- Added timer features (double click on background to show node timers)
- Added Line node
- Added TextArray node.
Each line => point: [x] [y] [z] [xAngle] [yAngle] [zAngle]. Use space or ; as separator.
Example:
1 2
5 6
10 15
or
1 0 0 0 -90 180
-1 0 0 0 90 0
0 1 0 90 0 90
0 -1 0 -90 0 -90
0 0 1 0 0 0
0 0 -1 0 180 0
7713.246 In reply to 7713.245
Hello Max,
thank you for that great work. - your speed is incredible.
As mentioned, I am working on a pushFrame-function. Here is my first working code with some reworked nodes to test it. Please let me know if you want to improve and integrate it, or we should use an external way.
In a short test I can't run the circle-node?
By the way I made another cursor. The original crosshair has in my opinion not enough contrast. It is a simple PNG which can changed with a simple graphic prog. Activation for those who also need more contrast: open litegraph.css in the css directory and change cursor: crosshair; to cursor: url(./crosscursor.png) 16 16, crosshair; put the crosscursor.png in the same directory.
Have a nice day
Karsten
Size: 404 bytes, Downloaded: 129 times, Dimensions: 32x32px
As of version _NodeEditor0.55.2016.5.06, the language used by NodeEditor is the same as used in the users MoI program,
and is determined by the moi.ini file.
For example, to change from say English to another supported language, say French:
From the MoI screen, select Options, edit moi.ini, then under [UI],
change Language=English to Language=French. (Or Russian)
Currently supported by NodeEditor are Russian, English, and French thanks to Pilou.
(Except for "Clean" :-)
hmm, Russian works in NodeEditor, but does not work in my MoI, because I do not have RussianStrings.txt in MoI ui directory
A google search for "RussianStrings.txt MoI" located a download of the txt file, but I cannot read or understand Russian.
Cool!
EDITED: 7 May 2016 by PILOU
7713.249
Karsten
Thank you very much. I'll check all your code today.
My fault. Fixed.
curves.js, line 59
var output = factory( 'circle', true, center.getFrame(0), null, this.properties.radius );
It's looks good for me, but I'll add this line to css
bemfarmer
Could you explain, what's wrong with it? My english is far from good. Should I use "Clear" instead?
7713.250 In reply to 7713.249
It's Resolved!
PS I have not a,b inside the MathArray as shown on the "Line Video" above ?
No Multiple Clone ?
Edit : about the a,b :):): You can add them by Right Click on the Node MathArray then "Inputs" !
Last French Version! :)
By Max S
7713.251 In reply to 7713.250
There are a lot of words to translate.
Stop is not translated.
- B
Show messages:  1-11  …  172-191  192-211  212-231  232-251  252-271  272-291  292-311  …  912
