Parametric design in MoI?
 1-12  …  173-192  193-212  213-232  233-252  253-272  …  893-912
7713.213
Hi guys :)
Sharif
Good idea, I'll think about it later. Not now.
>>A possibly simpler alternative would be to allow range fields to accept variables as shown.
I thought about it. At first I need to check a performance of this node. If implementation of this feature will not lower an overall performance, I'll add it.
Karsten
>> At the moment, I try to implement the pushFrame-function
Yes, it's not as easy as it looks. :) I also wrote RX RY reverse transformation in the SphereArray node. Need to think about RZ.
>>I have changed the "EN" to "FR" and add the French dictionnary with good syntax, run Moi In French but...all stay in English!
change lang.set("EN") line in index.html file
Tom
>>a node based audio application has three interface states for nodes: "Collapsed" ... "Used Inputs" .. and "All"
I like this! It will not so easy to implement, but I'll try it.
7713.214 In reply to 7713.213
<< change lang.set("EN") line in index.html file
Seems not sufficient! "FR" same result! :)
7713.215 In reply to 7713.214
Just checked it. Works good. Send your translation file to me.
Animation is progessing!
@Max here the
File lang.js with "EN", but put "FR" change nothing even input "FR" inside the Index.html !
lang.set("FR");
https://we.tl/dNcE2OGmpu valuable till 10 / May / 2016
EDITED: 3 May 2016 by PILOU
7713.217 In reply to 7713.216
Hi Pilou
Everything works good. I haven't any idea what is wrong with your settings.
EDITED: 7 Mar 2022 by SMIRNOV
7713.218 In reply to 7713.217
I tried out the French language version of Pilou.
1. Placed Pilou's lang.js file in the core subdirectory, after renaming the older lang.js file to langOlder.js
2. Changed EN to FR in the index.html under function init(), (As per Max's initFR.PNG), with notepad++, in the nodeeditor directory.
Success
Then changed FR back to EN.
After re-opening MoI, pressing F5 does not seem to be necessary.
Switching languages by //Commenting will work.
function init()
//lang.set("EN");
lang.set("FR");
//lang.set("RU");
EDITED: 3 May 2016 by BEMFARMER
A big mystery!
Shortcut is this one ?
moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Can you give me the list of the \ui\nodeeditor\...
EDITED: 4 May 2016 by PILOU
7713.220 In reply to 7713.218
@Bemfarmer
<< 1. Placed Pilou's lang.js file in the core subdirectory, after renaming the older lang.js file to langOlder.js
<< 2. Changed EN to FR in the index.html under function init(), (As per Max's initFR.PNG), with notepad++, in the nodeeditor directory.
<< Success
Seems you don't change "EN" to "FR" inside my lang.js file posted : var lang = { LANGUAGE: "EN" } does this exact ?
7713.221 In reply to 7713.220
lang.set() command overrides any setting of the lang value in lang.js file
I have reloaded all the project and same result! :(
So a vicious glitch on my computer! :)
Surrely a little error syntax somewhere!
7713.223 In reply to 7713.222
Pilou's lang.js file is NOT modified.
I accessed nodeeditor using customui, not shortcut key.
RU also works fine.
EDITED: 31 May 2016 by BEMFARMER
Size: 30.6 KB, Downloaded: 96 times, Dimensions: 211x264px
7713.224 In reply to 7713.223
Shortcut key also works:
My shortcut key for nodeeditor:
Ctrl+Alt+N moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Also made a copy of index.html named indexFR.html, with FR instead of EN the only change, also placed in nodeeditor subdirectory.
My new test shortcut key for French is:
Ctrl+Alt+Z moi.ui.createDialog( 'nodeeditor/indexFR.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Hope some of this helps.
7713.225 In reply to 7713.224
Thx for all precision!
But alas mystery is more more curious! :)
Bride between French version don't want to work for me!
All was working fine for the Elephant 1 !
7713.226 In reply to 7713.225
I was able to re-create the failure of the French language to appear, by
using the WRONG lang.js file.
So I would say to triple check that the Pilou lang.js file (which includes French words :-)), is
contained in the \core subdirectory.
7713.227
Today I wrote a Line node. It's not so simple as it looks :)
7713.228 In reply to 7713.227
We are all aware of you're herculean efforts.
Be assured they do not go unappreciated.
Keep it up
- James
Seems solved but very curious!
I must add the French lines dictionnary inside the EN part !
Moi is in French
My index html is lang.set("FR");
My lang.js is var lang = { LANGUAGE: "FR" }
Does all that is normal ???
image of the lang.js
7713.230 In reply to 7713.229
"My index html is lang.set("FR");" <<This is correct.>>
"My lang.js is var lang = { LANGUAGE: "FR" } " <<<This is "incorrect." Leave it as: var lang = { LANGUAGE: "EN" }>>>
I temporarily went to MoI Options, and edited the moi.ini file to read, under [UI] as Language=French
With index html: lang.set("FR");, and leaving your lang.js as downloaded, with var lang = { LANGUAGE: "EN" }
no other modifications were needed to get French Node language.
There is no need to add the French words to the EN section, lines 159+ in your post.
(These are my personal observations and tests and opinions:-)
7713.231
Hi Pilou
Check all js files for another lang.set('EN') call. It seems like you accidentally inserted this line somewhere in the code.
7713.232 In reply to 7713.231
<< Check all js files for another lang.set('EN') call
I have checked that: no such thing is existing! :)
Show messages:  1-12  …  153-172  173-192  193-212  213-232  233-252  253-272  273-292  …  893-912
