Parametric design in MoI?
 1-9  …  150-169  170-189  190-209  210-229  230-249  …  910-912
7713.190 In reply to 7713.188
Hello Max,
after a quick test - excellent! Everything seems to work. Another Masterpiece!
Many thanks!
Karsten
7713.191
Amazing
7713.192 In reply to 7713.188
Hi Max,
I'm very pleased to know that your NodeEditor project is still under developing...
Thank you very much for your efforts and for the not ordinary quality of your plugin!
It's something like a very precious pearl, in moi's treasure chest.
I never seriously played with your plugin, so i decided to begin.
At the moment i have just a few questions.
For example, just to begin with some simple tests, i wondered what are the steps needed in order to create a "pointarray" object.
I mean...i see that the "Curve" object requires a "pointarray".
So, how generate this kind of object, starting, let's say, from a selection of point objects ?
Thanks again for your great work and have a nice day.
Marco.
7713.193 In reply to 7713.192
Hi Marco,
At the moment I wrote just a core engine of this node system. First beta version has been released, but most of the functions are still unavailable.
Now we need to write nodes. Karsten already wrote a lot of nodes which we can use with the new version. Wait for a while.
Right now only three nodes can create a pointarray objects: GenArray, Point and FRotate.
7713.194
Hi Max,
I notice that we can now zoom in and out which is excellent.
I'm running MoI on a Surface Pro 4 and the Node Editor UI is a bit to small for my old eyes.
Is it possible to enlarge the UI for high definition Monitors.
If not no problem can work with Windows 10 magnifier.
Many thanks for sharing your work it's keeping my old brain active.
Barry
7713.195 In reply to 7713.193
Hi Max,
Thank you for your prompt reply.
I will try to use some of Karsten'nodes while waiting of your upgrades.
From a software developer to another one, my congratulations for the results of your efforts.
Marco.
7713.196
Hi Barry,
Extract litegraph-editor-hd.zip file to nodeedit/css folder (overwrite the old css-file)
Also extract moi-litegraph.0.41.zip to nodeedit/core folder to enable >1 zoom levels.
EDITED: 7 Mar 2022 by SMIRNOV
7713.197
Hi Max,
many thanks it's great.
Barry
7713.198 In reply to 7713.190
Karsten,
""""""""""""after a quick test - excellent! Everything seems to work. Another Masterpiece!""""""""""""""""""
Apparently all your existing nodes need to be re-written?
They all error out for me on new node system. Just to be clear.
7713.199 In reply to 7713.198
Hello BurrMan,
that's correct. Most of the nodes has to be rewritten or need an update - so I started allready. And yes - everything in the new beta seems to work:-)
At the moment I study Max code - especially the pointarray and the frames. The changes here, are the most important at the moment, to get the nodes work.
Have a nice day
Karsten
7713.200
I've been gone a long while...so I'm a bit confused...is this the "official" path for parametric in Moi3d?
Waiting the complete rewriting for made the new French Version! ;)
7713.202 In reply to 7713.200
Hi TwinSnakes,
In the future I would like to implement history based parametrics in MoI, it would be a little different than this method. But Max's system is something you can use now if you want to build a procedural model. I'm not sure when a deeper history based system will get implemented for MoI, there is still a lot of work I want to do to improve other areas first.
7713.203
v.0.5
- added Get objects nodes (Get objects by name, Get objects by style, Get selected objects)
- added ObjBoolean nodes (thanks to Karsten)
- added few array/construct/transform nodes
- made some enhancements in the core code
I made new version of Karsten's Motor demo. Now it looks much simpler than before.
Elephant the big return!
7713.205
Hi Max,
I'm using the maths array to get a grid type array.
To get the desired centres I adjust the umax/vmax based on the Unum/vnum inputs.
Is it possible to have the umax/vmax accessible by inputs or is there another way to do
this type of array ?
Barry
7713.206 In reply to 7713.205
Hi Barry,
replace /nodes/arrays.js with attached file.
In fact I don't like nodes with large amount of inputs. Later I'll write a new version of this node. I need to find an optimal way to solve this problem.
7713.207 In reply to 7713.206
Hi Max;
Great Job! as usual. As a suggestion may be creating other nodes ( Domain nodes ) will eliminate cluttering the nodes with too many inputs (see attached example from Grasshopper).
-Sharif
Size: 49.1 KB, Downloaded: 149 times, Dimensions: 1158x584px
7713.208 In reply to 7713.207
Great suggestion Sharif.
A possibly simpler alternative would be to allow range fields to accept variables as shown.
-James
7713.209 In reply to 7713.203
Hello Max,
looks really great! The@'y'@ becomes more and more an powerful and easy to use tool. At the moment, I try to implement the pushFrame-function. Reverse/evaluate the Euler-Angles drives me crazy. RX, RY are working good (after a lot of failures) - and so, every time I think - I got it also with RZ - the axes flips or the angle turns the direction:-( I will post the code next time - maybe someone will have a good idea.
Have a nice day
Karsten
Show messages:  1-9  …  130-149  150-169  170-189  190-209  210-229  230-249  250-269  …  910-912
