Parametric design in MoI?
 1-16  …  137-156  157-176  177-196  197-216  217-236  …  897-912
7713.177 In reply to 7713.176
A good mnemonic trick! :)
7713.178 In reply to 7713.174
Hello Ken,
for me it Looks like the Network command of Moi - with turned on control Points (3 and 4 sided examples). Am I right? The form finding is something else, what I didn't understand at the Moment:-(
By the way - I saw a lot of clicks!
Have a nice day
Karsten
7713.179 In reply to 7713.178
Hi Ken,
I had another look to these stuff. It seems to be a finite difference or a finite element analyse behind the algorithm!?!
7713.180
New nodes and features
Karsten,
Cool! I'm really impressed!
Ken,
Yes, it can be implemented to my subd script. I'll think about it later. Right now I need to finish this NodeEdit project.
7713.181 In reply to 7713.180
7713.182 In reply to 7713.181
Hi Guyver
There are two Scherk scripts on the forum. (Search for +Scherk)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6524.1
EDITED: 19 Apr 2016 by BEMFARMER
7713.183 In reply to 7713.182
After considerable manipulation a 4 hole Scherk2 surface was created from the basic uv curves.
Only one quadrant of open curves was used. The ends were connected with a through point curve, and then mirror and revolve to get 4 sets.
The through point curves were blended 4 times, and the 8 curves joined. Then network worked quickly. A 3 point circle trimmed the rounded ends.
Vertical copy and revolve of the surface enabled join to work.
EDITED: 20 Apr 2016 by BEMFARMER
Size: 140.2 KB, Downloaded: 127 times, Dimensions: 337x594px
7713.184
The work goes faster than estimated. A lot of bugs fixed. A lot of small improvements added.
First beta will be today evening.
7713.185 In reply to 7713.184
Suspense! :)
7713.186 In reply to 7713.185
It will be a long, long night ...
7713.187 In reply to 7713.184
Sounds great Max, thanks very much for sharing it!
7713.188
First beta of the nodeeditor :)
Main change:
- The Frame and Point types replaced with the PointArray type. This new type supports 3d arrays of points. For each point you can set x-y-z coordinates, three rotation angles, scale.
Other changes:
Added powerful Math nodes (Basic/Math and Arrays/GenArray)
Now you can add and remove optional input/output slots (right click on a node title to add slot, right click on a slot to remove it)
More intelligent selection tools
You can use shift+left mouse button or middle mouse button to select multiple nodes. Now you can easily move them around. Multiple delete doesn't work at the moment.
Slider and Knob nodes doesn't steal focus anymore when you use them.
You can use mouse wheel to zoom in and out
Added math support for property input fields. For example, you can set variables: a: -pi, radius: 2*pi+10 etc
Visual bugs fixed
EDITED: 7 Mar 2022 by SMIRNOV
7713.189 In reply to 7713.188
Thanks Max
Fantastic work!
- James
7713.190 In reply to 7713.188
Hello Max,
after a quick test - excellent! Everything seems to work. Another Masterpiece!
Many thanks!
Karsten
7713.191
Amazing
7713.192 In reply to 7713.188
Hi Max,
I'm very pleased to know that your NodeEditor project is still under developing...
Thank you very much for your efforts and for the not ordinary quality of your plugin!
It's something like a very precious pearl, in moi's treasure chest.
I never seriously played with your plugin, so i decided to begin.
At the moment i have just a few questions.
For example, just to begin with some simple tests, i wondered what are the steps needed in order to create a "pointarray" object.
I mean...i see that the "Curve" object requires a "pointarray".
So, how generate this kind of object, starting, let's say, from a selection of point objects ?
Thanks again for your great work and have a nice day.
Marco.
7713.193 In reply to 7713.192
Hi Marco,
At the moment I wrote just a core engine of this node system. First beta version has been released, but most of the functions are still unavailable.
Now we need to write nodes. Karsten already wrote a lot of nodes which we can use with the new version. Wait for a while.
Right now only three nodes can create a pointarray objects: GenArray, Point and FRotate.
7713.194
Hi Max,
I notice that we can now zoom in and out which is excellent.
I'm running MoI on a Surface Pro 4 and the Node Editor UI is a bit to small for my old eyes.
Is it possible to enlarge the UI for high definition Monitors.
If not no problem can work with Windows 10 magnifier.
Many thanks for sharing your work it's keeping my old brain active.
Barry
7713.195 In reply to 7713.193
Hi Max,
Thank you for your prompt reply.
I will try to use some of Karsten'nodes while waiting of your upgrades.
From a software developer to another one, my congratulations for the results of your efforts.
Marco.
7713.196
Hi Barry,
Extract litegraph-editor-hd.zip file to nodeedit/css folder (overwrite the old css-file)
Also extract moi-litegraph.0.41.zip to nodeedit/core folder to enable >1 zoom levels.
Show messages:  1-16  …  117-136  137-156  157-176  177-196  197-216  217-236  237-256  …  897-912
