Parametric design in MoI?
 1-6  …  107-126  127-146  147-166  167-186  187-206  …  907-912
7713.147
This is a quite interesting bit of work done by Max. It provides some very powerful capabilities, but at somewhat of a steep learning curve-- not Max's fault.
It reminds me of the function editor of Vue. The very first time I used it, I was pretty much overwhelmed. Over years I became fairly adept and could create dense cloud structures, hypertexture volumes and interesting fractal landscapes. In talking with the Vue programmers, they too recognized the challenge the function editor posed to most users and decided to provide an 'abstraction layer' for the interface.
What this meant is folks like my friend Dax Pandhi could now take his elaborate functions and distill them into a few custom named sliders, hide the rest and allow the rest of us to be able to use them without having to understand vectors, max/min, what different fractals did, etc.. I think it was a smart move by Vue and also helped the community (and Dax!) significantly.
I would think something along an 'abstracted' interface might be worth exploring. As always, I'd encourage Max to sell this significant technology in order to find a way to help support it.
7713.148
Hi Karsten,
attached is my attempt for a grid array with adjustable centres,columns and rows in the 'X' & 'Y'
and the ability to rotate the object. I'm not sure if it's the proper way to do it but it works.
Will you have a look and let me know if it's Ok.
It would be good if the Generative Array info could be accessed as I needed to reset one of the values
of the inputs after removing a connection.
Many Thanks.
Barry.
Tracks & nodes draw a gun! ;)
7713.150 In reply to 7713.148
Hi Barry,
I'm not an expert, so I can't decide if this is a proper way, but I think everything works fine. I'm playing with the @'Y'@ like some others, too. Remarked by chipp, the system is not easy to use at the moment, but playing with it, will help to find better solutions.(like your comments:-))
Max announced some changes in the core system that will help reduce wiring, but maybe some nodes have to be changed, alot will be obsolete. I'm not a programmer and time is limited, so I will have a look to a reset function or some better defaults, with the next version of max core system.
Keep on playing:-)
Have a nice day
Karsten
7713.151 In reply to 7713.150
Hi ,
being a beginner I'm posting this file hoping for some feed back on where I could
improve it or make it easier.
The attached node file as two arrays combined to allow nesting of objects.
In the picture the red and silver objects are the same. This was an exercise to maximise
a mould layout for a given shape with the ability to rotate and adjust and offset centres.
Barry
EDITED: 10 Mar 2023 by BARRY-H
Message 7713.152 deleted 16 Feb 2019 by JFH
Message 7713.153 deleted 15 Jun 2019 by JFH
7713.154 In reply to 7713.153
Hello Barry, Hello James,
It should be a bug if it isn't work. I will have a look tomorrow.
Very interesting to see the different application areas and different point of view to the same thing.
Sorry, if there are bugs in the nodes.
Happy new year to all
Karsten
7713.155 In reply to 7713.154
Hi James & Karsten,
I'm not sure if this may help but I replicated James problem and found you could
produce the sine wave in the X & Y or Y & X also X & Z but not Y & Z.
Happy new year
Barry.
7713.156 In reply to 7713.155
Hallo Barry,
Thank you for your investigations. The problem is that I check the input of x(n) and generate not an default array for that. So if you put an array with the same number of values, with start value 0 and step 0, it should work (all ports connected to avoid side effects). I am waiting till next alpha of the @'y'@ to find a better solution, because Max has announced big changes in value handling - maybe he will integrate some better solutions by himselve? I'm very curious:-)
Kind regards
Karsten
@ = Ear
' = Eye
Tusks missing
y = Trunk and Jaw?
http://pc.net/emoticons/smiley/elephant
EDITED: 5 Jan 2016 by BEMFARMER
7713.158
Hi everybody! :)
I'm back from vacations. New alpha/beta vesions will be soon :)
7713.159 In reply to 7713.158
Happy new year MAX!
Made with the incredible free Verve: we can now embed an image inside bristles Brush!
http://www.taron.de/forum/viewforum.php?f=4
7713.160 In reply to 7713.158
Hello Max,
Happy new year! I am very excited about the changes you have made:-) and I hope, I will understand them!
Kind regards
Karsten
7713.161 In reply to 7713.160
Hello,
I want to share my last investigations of subD for the elephant. I have simple wrapped Max SubD-Script in a node. Sorry about the videoformat. It's my first screenrecording and I have some problems with the upload.
Kind regards
Karsten
7713.162 In reply to 7713.161
You will not erase this one ? ;)
7713.163 In reply to 7713.162
Hello Pilou,
I have not deleted the other video. YT has deleted it, caused by a 95% problem. So I made a new one and converted it before upload - but I'm to stupid to get a correct aspect ratio:-). Maybe some day I will find the time for better results.
Have a nice day
Karsten
7713.164 In reply to 7713.163
No problem! :)
7713.165
Hi Max
Is it possible to have a node that outputs the X,Y & Z box dimensions of a selected object.
Unfortunately I don't have the ability to write it myself.
Barry
7713.166 In reply to 7713.158
Max
Any chance of an update on Project Elephant progress.
I have been checking the forum incessantly since your last posting:
"New alpha/beta vesions will be soon :)"
Please don't mistake my enthusiasm for impatience.
- James
Show messages:  1-6  …  87-106  107-126  127-146  147-166  167-186  187-206  207-226  …  907-912
