Persistant guidlines.
All  1-8  9-12
77.9 In reply to 77.8
You have to sign up to download the Alias Studio PLE, then you can download the tutorial videos as well. Definitely check it out. It's some wickedly powerful software. Just waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay friggin' expensive. Full shebang runs about $65,000. o_O
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6866433
77.10 In reply to 77.9
Thx but seems ther are some animations here :)
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=6871498#section10
Hu 65 000 $ is not a little toy :D
77.11 In reply to 77.7
> Then put the "edit guidelines" button next to the "show points" button. Same basic idea.
That could work, I guess it is similar in effect to show points. But I hestitate to add a new button there for it, the Edit palette is already getting quite crowded. It seems like a more general purpose "Lock/Unlock" type mechanism that worked both on construction lines as well as other objects would be better than a button devoted just to editing construction lines alone.
77.12 In reply to 77.10
The cheapest version of Alias Studio clocks in at $7500. I guess if you really need ridiculously good NURBS then it's worth it.
Show messages: All  1-8  9-12
