Persistant guidlines.
All  1-3  4-12
77.4 In reply to 77.3
> More clutter in the interface.
Yup, these are the kinds of things that I've got to be a bit careful of, every button that is added to the top level UI brings some complexity to the interface.
This might have to wait until there is a more general purpose object list / object organizer that would have general support for locking down objects to make them unselectable. Then at that point the persistent construction lines could be selectable like regular objects, and you could use that general purpose object organizer to lock them to prevent selecting them.
But that general purpose object organizer is a major piece of work, it will be a ways off.
It is easier to add more functionality when it is nested down one level in the UI, I mean when it only shows up when you click on something else first and then goes away after that. There is not quite a good socket for construction line related stuff like this yet though.
77.5 In reply to 77.4
You have a looooong way to go before the interface is anything remotely resembling cluttered. Have you SEEN Houdini? Or any compositing app, for that matter? ;)
I had an idea on how to fit them into the interface, as well as improve the way they work. Add them in as an option under the line tool. Click the button and you go into guideline edit mode. Add and remove guidelines as you wish. Click DONE to turn guideline mode off. If you want to edit the guidelines or add new ones, just go back into edit mode.
I didn't realize the power of guidelines until I saw a Studio Tools video the other day. Then the genius hit me. Having that kind of ability in MoI would be phenomenal.
77.6 In reply to 77.5
This sounds good for adding new ones, but not as good for the edit/remove part - that part just doesn't seem to quite fit into that area organizationally speaking. I mean that there isn't any other functionality under the "Draw curve" section that is currently about editing or deleting curves, just only about drawing new ones...
77.7 In reply to 77.6
Then put the "edit guidelines" button next to the "show points" button. Same basic idea.
77.8 In reply to 77.7
< until I saw a Studio Tools video the other day
Have some links for that?
77.9 In reply to 77.8
You have to sign up to download the Alias Studio PLE, then you can download the tutorial videos as well. Definitely check it out. It's some wickedly powerful software. Just waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay friggin' expensive. Full shebang runs about $65,000. o_O
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6866433
77.10 In reply to 77.9
Thx but seems ther are some animations here :)
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=6871498#section10
Hu 65 000 $ is not a little toy :D
77.11 In reply to 77.7
That could work, I guess it is similar in effect to show points. But I hestitate to add a new button there for it, the Edit palette is already getting quite crowded. It seems like a more general purpose "Lock/Unlock" type mechanism that worked both on construction lines as well as other objects would be better than a button devoted just to editing construction lines alone.
77.12 In reply to 77.10
The cheapest version of Alias Studio clocks in at $7500. I guess if you really need ridiculously good NURBS then it's worth it.
Show messages: All  1-3  4-12
