Decimate - low poly?
All  1-6  7-11
7690.7 In reply to 7690.6
It's just the view, not the real volume! ;)
For a free decimate Meshlab is a good one: ;) (and for other things! :)
http://meshlab.sourceforge.net/
7690.8 In reply to 7690.1
Hi Stefan (Nicolinux) - yes like the other Stefan writes above probably your best bet would be to export to a polygon mesh format, and then bring that mesh data into a polygon decimation utility program.
7690.9 In reply to 7690.5
Wish they would update Balancer to 64 bit, and with some minimal retopology function, like converting to quads, ... would be nice
7690.10
Hello,
+1 for Atangeo, I like the tolerance based decimation that nPro has among other features. I'm pretty sure Atangeo comes in both 32 and 64 bit flavors.
7690.11
Thanks everybody.
I know about Meshlab (used it to create create the reduced bunny). I tried Atangeo and I like it. Since I have rather simple objects, I can get away with the free version. The importObj script works great too!
That's my source object:
Then I use Atangeo to reduce/simplify it (this messes it up pretty bad, but I want it that way :) )
Then I import it in MoI where I can even use the move command to snap the edges onto each other and together with the planar command and bool union to produce a solid!
Show messages: All  1-6  7-11
