Bolt (screw) threads
All  1-3  4-13
767.4 In reply to 767.3
Hi phlatt5th, those are looking great! The booleans will probably have difficulty if both things collapse down to a single point at the very tip. You'll probably need to stop the screw thread just a little bit before it collapses down to a final point to make that work better.
767.5
Thanks all, I will be having a busy day. I was doing something wrong with the turning adjustment of the triangle it seems.
767.6 In reply to 767.5
Hi Brian, probably you had the default Twist:Freeform active for the sweep. That will generally spin the triangle more than you want for this kind of controlled sweep. So setting the Twist:Flat option will solve that, it will only pivot around the world z axis when that is enabled. Make sure your helix runs up and down vertically along the z axis to make that work right.
767.7 In reply to 767.6
Thanks. Thats what I found out before seeing your response.
767.8 In reply to 767.7
Look great Brian!
767.9 In reply to 767.4
That worked! the booleans are now successful, could you point me to the tip for putting the images on the forum so that they visible. I cannot seem to find it. Thanks again Michael
767.10 In reply to 767.9
Hi Phlatt5th, cool, I'm glad it worked for you!
See here for some details about inline images: http://moi3d.com/forum/index.php?webtag=MOI&msg=68.118
Message 767.11 deleted 20 Jul 2007 by P5TH
767.12 In reply to 767.10
screws doodles after Michael's tutorial.
EDITED: 20 Jul 2007 by P5TH
767.13
lol brilliant made me lol ;-)
I Like this a lot will need some bolts to finish off my wheelchair project
EDITED: 21 Jul 2007 by SUHAIB
Show messages: All  1-3  4-13
