Something to consider for v4
7658.1
Hi Michael, this is something I have raised with you away from the forum in the past but I thought it might be worthwhile mentioning here to see what other people think.
MoI uses a non-standard object selection system whereby multiple clicks can be used to select any number of items without having to hold down the shift key (the conventional method in most other applications). I recall reading somewhere that this was done to help those who choose to use a stylus / tablet instead of a mouse & keyboard. This is one of the many great features of MoI but, even after years of use, it’s still catching me out.
When I’m working with MoI, all too often I will select and modify, delete or duplicate an object only to find that something else, off screen, had been selected too and errors are made. Sometimes these errors go unoticed until the file has been saved and the application closed when it’s too late to undo the damage. Perhaps I am just being careless? I’m often working quickly and having to switch between a number of applications so I guess mistakes are inevitable.
What I’d like to see in v4 is an option to switch between the methods: either the system used by MoI or the one used by other applications (holding down the shift key to facilitate multiple item selection). A simple check box in the options panel (general section) would be perfect.
It would be interesting to read what others think.
Best wishes
Mark
7658.2 In reply to 7658.1
Just press the Shift key during your selection, even this make nothing for the multiple selection, but like this you have intact your reflex! ;)
7658.3
Mark,
I run into this issue all the time, even this morning, a large part of my design was selected, I zoomed in on another part to check some details, some moments of inspiration later I detected an unused contour, deleted it, and then kept working. after half an hour I noticed the missing part, searched in my hidden objects, could not find it. Fortunately MoI has unlimited undo's, so I saved my work, it took me more than a minute to undo everything until the deleted work appeared again.
so yes, an option to deselect whatever is selected without holding the shift key would be nice.
wim
7658.4 In reply to 7658.3
That would be the esc key.
7658.5
No Burrman, that is not what I mean.
An option in the preferences to choose wether selecting an object deselects all other objects if no extra keys are pressed, or leave the behaviour as it is today.
the esc key deselects everything, just like clicking next to objects deselect it, but that is an action again. and remembering every time to click somewhere or press the esc key is tiresome for people with "Alzheimer Light" like myself ;-) since the behaviour in 99% of the other software is different.
7658.6 In reply to 7658.5
Got it. For some reason i read yours as different from the first post. Just got a year older myself!
7658.7 In reply to 7658.1
Hi Mark & Wim - when v4 betas are underway please remind me about this again at that time and I'll see about adding in an option for it.
7658.8 In reply to 7658.7
Thanks Michael
best wishes
Mark
7658.9
It's funny because I just realize that I'm using my shift key for multi-selecting in MoI (for nothing) ... well at least when I'm just switching from an other 3d soft.
So strangely, I think I will appreciate that new option too ... even if it will break the ability to work with a single hand (very handy when eating something at the same time :))
I'm not really sure if it's the reason of user mistake. I often get this 'wtf' moment when I see something has been moved or deleted in a model, what even the software I use.
Grouping and locking mechanism is probably our best friend.
