Complex shape to model.
All  1-4  5-7
7634.5
When lofting organic shapes it is usually best to use the loft>loose>exact method and reduce the amount of curves necessary to create the shape to as few as possible.
You also get the best surface if each curve used to create the loft has the same number of points on it.
Other lofting options quite often create tensions in the nurbs surface which create the distortions you are seeing.
7634.6 In reply to 7634.4
Hi Manu, yes I'd agree with kevjon above - try using the option for "Loft Style: Loose" which will be in the upper right command options area when you run the Loft command.
It will make a more relaxed surface that is just generally guided by the inside curves rather than forced to go through every single curve. When the loft is overly constrained by trying to be forced through every single curve that are close to each other it can easily lead to bumps and ripples in the surface.
7634.7 In reply to 7634.1
Hello Manu,
maybe You can make it also with a blend (red)- a big surface with a simple network (blue curves) and a helper surface (green) to control the curvature and direction of the blend!?
Kind regards
Karsten
EDITED: 8 Jan 2018 by KMRQUS
Show messages: All  1-4  5-7
