Plotting airfoil points form NACA coordinates
All  1-2  3-7
7628.3 In reply to 7628.1
Hi John, also there is a plug-in which you can install which can read in a text file with one x,y point per line and build a curve out of it. It can build either a polyline, an interpolated smooth curve which is forced to pass directly through the points or a control point curve which will use the point as the control polygon hull for the curve which will make for a kind of smoothing effect.
The plug-in is available here:
http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile
Message 7628.4 deleted 27 Nov 2016 by BEMFARMER
7628.5 In reply to 7628.4
Is ImportPointFile script compatible with V3?
Mik
7628.6 In reply to 7628.5
Hi Mik,
I'm pretty sure it is if you get the latest one which is here:
http://moi3d.com/forum/display.php?webtag=MOI&msg=5124.2
That one should work on either Mac or Windows MoI v3 I think. Please let me know if you have any problems with it.
7628.7 In reply to 7628.6
I had problem with script from http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile
Script from your post is OK.
Thank you very much.
Mik
Show messages: All  1-2  3-7
