Problem with creating geometry
All  1-2  3-5
7626.3 In reply to 7626.1
Hi Marqson - yes like wim writes above those might be Blend surfaces or could also possibly be fillet surfaces, maybe with a variable radius.
7626.4 In reply to 7626.1
Hi Marqus,
I had opportunity to look a bit closer to your issue.
But unfortunately I can't find way to create this geometry!!
It's look simple, but I the problem is much more complicated as I thought!
The most difficult is create shape between two different geomety: the cilinder (vertical) and outlet (horizontal).
I'm begginer as You Marq, but I'm positive that one of our masters of MOI will find solution.
Be patient!
BR
t
7626.5 In reply to 7626.1
Hello Marqson,
I've tried to create the upper connection with the blend-tool. First I created two circles and make a surface with loft. After that I have created the 2 sidefaces of the part where the water comes out(I will call it ???). Then i've connected this two sidewalls with blend G2. After splitting the cylinder and the new blendface, I cut away the gap for the blend between ??? and the cylinder. I have made a blend with the option G2 and "planar section" for close to the cylinders tangent. The other side of the model have a different cutout with a imperfect patch made with network. It has a little tangent/curvature problem.
I hope it helps!
Kind regards
Karsten
Size: 449.5 KB, Downloaded: 123 times, Dimensions: 1366x768px
Show messages: All  1-2  3-5
