Organic shape modeling within MoI
All  1  2-8
7625.2 In reply to 7625.1
Hi loveart - organic shapes tend to be difficult, stuff like you show there may be better done in a polygon sub-d modeler rather than in a CAD program. CAD programs are strongest when working with shapes that can be created primarily from 2D profile curves, and often times organic shapes do not fit in that category.
But if the functionality in Fusion 360 works well for you for doing that type of thing I'd recommend using it to do them, you can then import your model into MoI if you want to do other things with it in MoI.
But really organic forms like you show there tend to be difficult in any program because they are warping and changing so much in 3D space and not easily simplified to a 2D design. It means you have to do the work more like a sculptor rather than drawing profile curves. MoI is based heavily on the drawing profile curves method for modeling, and for certain kinds of models it fits very well and for other types of models other types of modeling strategies can be better.
If you do want to get some tips from other people it would likely be helpful if you were to focus your question on one specific model rather than 4 different ones though.
EDITED: 20 Sep 2015 by MICHAEL GIBSON
7625.3 In reply to 7625.2
Hi
I had a go at making one of the objects using my laptop that has Moi1 installed. I got quite close using lofts and boolians but could not union the objects or filet some edges. I also misjudged a profile so that the lower parts flare where they should not. I think it would be possible to make given a bit more time and effort.
Keith
7625.4
Loft can make this.
7625.5 In reply to 7625.4
Loft is really strong tool for organic modelling in MoI.
Using 4 control curves ...
... it's possible to create - basic surface > offset / shell > solid
Mik
7625.6 In reply to 7625.5
...quick render in Octane
Mik
Size: 174.7 KB, Downloaded: 95 times, Dimensions: 1600x1200px
7625.7 In reply to 7625.6
Very cool.
7625.8 In reply to 7625.1
Hi
I had another go and made this. The filleting was tricky but that may be my lack of skill. At least it is a solid rather then joined surfaces.
Keith
Size: 88.4 KB, Downloaded: 84 times, Dimensions: 785x818px
Show messages: All  1  2-8
