Some probably dumb questions...
All  1-3  4-6
7618.4 In reply to 7618.2
something is not working, I have done as you said and still nothing is showing up
see attached please..
Is this a Mac PC problem?
I have actually tried this with 2 scripts now neither one even shows up although they are both inside the command folder as you instructed...
Please advise
D
Size: 185.4 KB, Downloaded: 32 times, Dimensions: 922x769px
Size: 376.1 KB, Downloaded: 23 times, Dimensions: 1867x1128px
7618.5 In reply to 7618.4
Hi D - it looks like you have copied the files into the correct spot, but I don't see that you've added in a shortcut key for launching the command.
On that Options > Shortcut keys dialog you need to push the "Add" button at the top to add in a new entry.
On the new entry on the left-hand column labeled "Key" type in the letter you want to use for triggering the command, for example put in S in there if you want to use the S key to run the subdivision command.
Then on the right-hand column of the new shortcut key put in the base name of the files you just copied, so for the sub-d one you would put in _Subdiv_beta6 so your new shortcut key would look like this:
Key   Command
S_Subdiv_beta6
After you have that set up, you can then push the S key to run the subdiv command on your selected objects. The object must be made up of 4-sided faces.
7618.6 In reply to 7618.5
Ah Ha!
Thanks again Michael you're the best!
D
Show messages: All  1-3  4-6
