DXF Export - Split projection view
All  1  2-8
7607.2 In reply to 7607.1
Hi Mik, it's not possible for scripts to participate directly in the file export process, so the script would need to prepare a set of 2D projected curves all in MoI in the Top view first and then export all of that at once out to DXF format. It will probably be a fairly complex script and would take quite a bit of time to work on - if you want to attempt it you would want to look at scripting the Make2D command 4 times in sequence to generate the content. It will be fairly difficult for the script to do things like clip any overflowing content to only show the view rectangle and things like that.
7607.3 In reply to 7607.2
Thanks Michael, understand.
Mik
7607.4
... problem solved
using Make2D script I've done views adjusting including hidden lines before final DXF export.
Final drawing via free Solid Edge 2D drafting ST6
Peace of mind :-)
Mik
7607.5 In reply to 7607.4
Great result Mik! At some point I do want to make a multi-view export built in to all of PDF, AI, and DXF exports.
7607.6 In reply to 7607.5
Thanks Michael,
Make2D command is quite quick for achieving of multi-view layout, but it will be fine to have multi-view exports in future.
Different topic... I know that a lot of posts was sent regarding grouping and I don't want to start new thread, but I have only one quick question.
Photoshop has sufficient (IMHO) grouping concept of layers.
Is similar concept applicable in MoI?
Kind regards,
Mik
7607.7 In reply to 7607.6
Hi Mik,
Yes, I'd like to develop something very similar to that in MoI with being able to have folders to arrange things in the Scene Browser, both for the "Objects" and "Styles" sections.
I think that folder concept works somewhat better than a "parent layer" and "child layer" type of concept because if the parent is another layer instead of some generic container like a folder, it's not so clear about how properties like colors inherit down to children.
Then also with a concept of generic folders it would be easier to have just one similar mechanism to work in different areas of the scene browser as well.
7607.8 In reply to 7607.7
It will be great, Michael, thank you.
Mik
Show messages: All  1  2-8
