Made With MoI
All  1-3  4-9
7595.4 In reply to 7595.1
Those are great pieces Alex, thanks for sharing the photos!
7595.5
Wow, very nice.
How did you ever cast those pieces from the print?
7595.6 In reply to 7595.5
The prints from the B9creator are UV set resin. Did a direct investment and burn from the 3d prints. I Burn to 850 degrees for a clean burnout. Good to cast after that.
https://www.b9c.com/
Hope that helps
7595.7 In reply to 7595.6
Thanks - i see. i have done similar with wax, but that melt at low temperatures (bigger parts though). But of cause the resin should burn as well.
7595.8
Classy designs Alex. Did you use Flow for the rounded shapes?
http://metinseven.com — 3D modeling • design • images
7595.9 In reply to 7595.8
Yep flat shapes generated to flow over basic 3d forms - great work flow.
Show messages: All  1-3  4-9
