Variable Width Line Offset Command - fatT Lines
1-9
10-29
30-49
50-51
stefano (LIGHTWAVE)
28 Nov 2024 (50 of 51)
7594.50
In reply to
7594.49
hi pilou can you set the line widths to a specific width? e.g. 2mm or anything else a user may decide?
edit:
i presume that is setting the "larguer" slider shown in your earlier posts?
kindest...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
28 Nov 2024 (51 of 51)
7594.51
In reply to
7594.50
Of course yes you can input any width !
Here 10 unities on 2 separated straigt lines
If you have several widths make several sets of lines (curves)
You will have a different result if you take connected lines! (here a polyline of 2 segments)
EDITED: 28 Nov 2024 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
10-29
30-49
50-51
