Object Spatial Array COMMAND WISHLIST
 1  2-21  22-31
7574.22
boblog
Sorry, in the nearest future this script can't get even close to Zbrush performance.
The main problem which stops me - the lack of instancing engine in MoI. This script makes thousands copies of the object, instead of making instances of one object. It consumes a lot of processor resources and memory and dramatically lowers performance of the script.
AFAIK, Michael have plans to implement support of instances in future versions of MoI.
Yesterday I spent couple of hours to increase script performance.
v.0.5 used 4 factories:
1 x orient (to place an object to a new point and than orient it)
3 x scale1d (for X, Y, Z rescaling)
v.0.6 uses only 2 factores
I've found that I can adjust xaxis and yaxis parameters of the target CoordinateFrame to process move/orient/X-scale/Y-scale using only one factory. :)
Unfortunatelly, zaxis parameter is read only, so I need to use second factory (scale1d) to correct Z-size.
Michael, please make it writeable in the next version.
AlexPolo
>You deserve a Vodka or Beer after that effort.
Thank you ;) I'll buy a box of vodka! The next version of the script will generate even more twisted and scattered structures :))
chippwalters
BurrMan
Thank you! :)
7574.23
v.0.7 will be tomorrow ;)
[added] X/Y-mirror mode
EDITED: 7 Mar 2022 by SMIRNOV
Appetizing! :)
7574.25 In reply to 7574.24
Hi MAX,
The script is evolving at lightspeed - what about putting in an auto FIBONACCI sequencer.
Playing with the controls and an extra point for rotational control gets close to home anyway.
Awesome work!
EDITED: 3 Jul 2022 by ALEXPOLO
7574.26
v.0.7
Hi Alex,
In the next version I'll add "Align to path" function. I'll think about fibonacci spiral then.
7574.28 In reply to 7574.26
Hi Max,
The align to path is an excellent idea that will give huge functionality in controlling the array over a surface or another object - this will take it past Zbrush in that respect.
Keep moving at lightspeed!
Thanks for your great work - the mirror function is great also.
Alex.
7574.29 In reply to 7574.28
Hi Max,
Can see how busy you have been with so many of the scripts in the forum any further thoughts on the Align to Path function for this scrip
7574.30 In reply to 7574.29
Hi Alex
I have started to write next version of this script few weeks ago. But something went wrong :) I was not satisfied with the results. So I decided to take a break and switch to another script ( subd ).
Now I have rested enough, so I will continue developing of the script this weekend or maybe next week.
7574.31 In reply to 7574.30
Max, you are a machine!! Man, I was impressed just reading this post. What a great community MOI has.
Dave S
Show messages:  1  2-21  22-31
