Heightmap [script]
 1-17  18-37  38-57  58-67
7547.38 In reply to 7547.37
Just did :)
Thanks again Max.
Cheers!
7547.39
Hey Max:
Another Heightmap idea would be to include a clipping plan to remove the background (black) or to ignore an alpha channel.
Again thanks for all your terrific scripts.
Bravissimo!
7547.40
Will this script work with MOI V2?
7547.41 In reply to 7547.40
sorry. it works with v3 only.
7547.42 In reply to 7547.41
Okay Max that is okay, does it use a command that is not in V2?
7547.43 In reply to 7547.42
Yes, v3 based on different javascript engine, and my script uses specific v3 commands.
7547.44 In reply to 7547.43
I tried the delimiter format to "//" instead of "\\" but no luck as it still stops at the delimiter line 8 of the script.
Thanks Anyway Max!.
7547.45
I'm playing around with the heightmap plugin and I create the curves with an png file. so far so good.
When I try to copy or save or what ever... an error message pops up with the following error message in the attachment you can see.
strg+alt+ent. is the only possible solution.
Best regards
Jörg
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
7547.46 In reply to 7547.45
Hi pixelhouse, do you get that same error anytime you try to save like if you start up a fresh instance of MoI and create a sphere and then save it does that work ok?
Or does it only happen with that particular file? It looks like you've got a massively complex single surface there, maybe that's causing a problem. You could try generating a less dense surface to see if that would help.
7547.47 In reply to 7547.46
yes, it works with an instance of Moi. But in this case I can't copy objects (landscape) from one to another Moi.
A less density object can't be a solution for me. We need to print this model out to a millling machine. Its just a quick test to see
whats possible with Moi and Max Heightmap-script.
I think, its a "spontaneous" error. Maybe its just a dream to export my landscapes to an step-file :)
7547.48 In reply to 7547.47
Hi pixelhouse, in order to generate that kind of high density surface to a milling machine you'll probably need it to be generated in a polygon mesh modeling program rather than in a CAD modeling program like MoI.
I would guess that you're probably running out of memory and that's causing some side effects like the script processing not working.
The only way I could know for sure if that's the problem is if I could reproduce the error over here, which I can try if you send me the image file and instructions on how you're generating the object. If the image file is particularly large you may need to upload it to a file sharing service like Dropbox, etc... and then e-mail me the link at moi@moi3d.com
7547.49 In reply to 7547.47
Hi Pixelhouse,
Here's a bit of info since you mentioned "Maybe its just a dream to export my landscapes to an step-file :)"
High frequency detail as found in nature is poorly represented by nurbs. In fact, if you convert a polygon model or raster data to nurbs you are losing information if your goal is to represent the information as faithfully as possible. So I would ask you to evaluate your need to have a nurbs surface.
It is a common requirement to have nurbs model for milling steel to make an injection mold, particularly for best surface finish. Therefore, it seems to be a misconception that the nurbs model is the best format for everything, while for some applications it may not be.
Many CADCAM programs can accept facetted (triangulated) representations such as STL, so there is no need for a nurbs surface if the end use will be the machined model and/or you are not making tooling for injection molds.
EDITED: 22 Jun 2016 by CHRIS_DORDONI
7547.50 In reply to 7547.47
divide and conquer???
7547.51
step files are a lot smaller and easier to manipulate as the polygons. Another advantage is the editor sppeed. I'm using Cinema 4d for my workflow: Plane 1000x1000 subdivisions, convert to polys,
load the image in the displacement-deformer and divide the plane one more time. So I have a nice base to create the mountains.
I need to bool wholes in the surface to place parts of energy like wind, water and so on in to the surface. the bool-operations are strange to create in cinema, and it needs a lot of time.
So I thought the workflow with Moi and step-files are a lot easier and faster. I have learned the Software of the milling machine can't read the step-files.
I will send you the file via Dropbox in the next 2 days.
Thank you for your assessment, Michael!
Hi Chris,
I've learned a lot about milling machines in the last 2 days. The optical impression (hope thats correct) in Moi of my landscape was great, and I thought wow, thats it! Its a perfect way to generate the models we need.
For more detail I use world machine to add details like small stones and errosions and make an B and W image output for cinema 4d.
I go forward to optimize my polygon workflow with many different tools to create the best result for our clients. I've tested a part of the mountains (100x100x100 mm) out to the milling machine and the client are satisfied with the result.
Thanks for your help!
Hope my english is understandable :)
Kind regards
Jörg
7547.52
7547.53 In reply to 7547.52
Hi Max
have you change something because the mesh size is very tight
7547.54 In reply to 7547.53
Hi Finema,
no, I didn't change anything
7547.55
Today I wrote RasterImage script based on heightmap (inspired by Paper.js examples)
http://moi.maxsm.net/files/scripts/RasterImage.v.0.5.2018.02.25(MoI.v4).zip
EDITED: 7 Mar 2022 by SMIRNOV
7547.56 In reply to 7547.55
Amazing work Max!
By the way, if you squint your eyes while looking at Max's image above you'll be amazed how it comes to life!
Cool!
No possibility to put colors from image ?
My Moi French Site My Gallery
Show messages:  1-17  18-37  38-57  58-67
