Heightmap [script]
 1-8  9-28  29-48  49-67
7547.29 In reply to 7547.28
Thanks, I can experiment. Any idea what number of curves the original script gave?
That would be my starting point
Message 7547.30 deleted 20 Aug 2015 by BURRMAN
7547.31 In reply to 7547.27
Mike
>>Any chance of making the point density adjustable?
Maybe later. Right now you can adjust it by resizing a source image.
If you will load an image 60x60 pixels, you will get 60 curves with 60 points per curve. 500x500 -> 500 curves, 500 points per curve.
If image larger than 600px it will be downscaled automatically.
7547.32
Thanks Max
Awesome script!
7547.33 In reply to 7547.1
Hello Max,
it doesn't seem to work on a Mac.
When I start this script, the dialogbox to choose an image appears - but with a click on the OPEN button the scriptwindow (marked in red) is closed immediately and nothing else happens.
Can you help?
Andreas
some minutes later ......
Hi Max, forget about that.
Your script works great with the note from Michael (thanks):
code: var dlm = moi.filesystem.getPathDelimiter();
If you change that to be what I wrote above, like this:
code: var dlm = '\\';
EDITED: 23 Aug 2015 by MORITZ
7547.34 In reply to 7547.33
Hi Andreas,
This issue was fixed in the last version of the script. Download it.
7547.35 In reply to 7547.20
Hello Mac users, I made the change with Text Edit to line 7 of Max's script as per Michael's instructions and the script works beautifully on My Mac.
Many Thanks to Max and Michael.
Cheers.
7547.36
Works fine on mine too!
www.jameselliott.co.uk
7547.37
phlatt5th, Marbleman
update this script to v.0.6
7547.38 In reply to 7547.37
Just did :)
Thanks again Max.
Cheers!
7547.39
Hey Max:
Another Heightmap idea would be to include a clipping plan to remove the background (black) or to ignore an alpha channel.
Again thanks for all your terrific scripts.
Bravissimo!
7547.40
Will this script work with MOI V2?
7547.41 In reply to 7547.40
sorry. it works with v3 only.
7547.42 In reply to 7547.41
Okay Max that is okay, does it use a command that is not in V2?
7547.43 In reply to 7547.42
Yes, v3 based on different javascript engine, and my script uses specific v3 commands.
7547.44 In reply to 7547.43
I tried the delimiter format to "//" instead of "\\" but no luck as it still stops at the delimiter line 8 of the script.
Thanks Anyway Max!.
7547.45
I'm playing around with the heightmap plugin and I create the curves with an png file. so far so good.
When I try to copy or save or what ever... an error message pops up with the following error message in the attachment you can see.
strg+alt+ent. is the only possible solution.
Best regards
Jörg
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
7547.46 In reply to 7547.45
Hi pixelhouse, do you get that same error anytime you try to save like if you start up a fresh instance of MoI and create a sphere and then save it does that work ok?
Or does it only happen with that particular file? It looks like you've got a massively complex single surface there, maybe that's causing a problem. You could try generating a less dense surface to see if that would help.
7547.47 In reply to 7547.46
yes, it works with an instance of Moi. But in this case I can't copy objects (landscape) from one to another Moi.
A less density object can't be a solution for me. We need to print this model out to a millling machine. Its just a quick test to see
whats possible with Moi and Max Heightmap-script.
I think, its a "spontaneous" error. Maybe its just a dream to export my landscapes to an step-file :)
7547.48 In reply to 7547.47
Hi pixelhouse, in order to generate that kind of high density surface to a milling machine you'll probably need it to be generated in a polygon mesh modeling program rather than in a CAD modeling program like MoI.
I would guess that you're probably running out of memory and that's causing some side effects like the script processing not working.
The only way I could know for sure if that's the problem is if I could reproduce the error over here, which I can try if you send me the image file and instructions on how you're generating the object. If the image file is particularly large you may need to upload it to a file sharing service like Dropbox, etc... and then e-mail me the link at moi@moi3d.com
Show messages:  1-8  9-28  29-48  49-67
