Heightmap [script]
 1-10  11-30  31-50  51-67
7547.11
Hi Max,
excellent script as usual!
Many thanks for sharing.
... Height map + flow + rendered in Octane :-)
Mik
EDITED: 17 Aug 2015 by MIKULAS
Size: 463.9 KB, Downloaded: 298 times, Dimensions: 1920x1080px
Size: 318.4 KB, Downloaded: 135 times, Dimensions: 2160x1080px
7547.12
So very Great Max!!
Just a possible suggestion:
Wonder if the script could be augmented to operate in both directions... It currently reads a bitmap to generate height... might it possible to analyze a surface and produce a height map.
That way, we could iterate between raster software and MOI to refine the surface iteratively in each, making adjustments each time.
For instance one might create a height map in say Photoshop, use your excellent script to bring it into MOI... use MOI to twist of otherwise modify the surface, and then have an auxiliary script write out the revised height map so it can be further tweaked back in Photoshop. With the various layer blending options in Photoshop, imagine the myriad of results that may not otherwise be practical or even discovered.
Just a thought... again great script.
I am sure that the entire community is equally as grateful as am I.
Thanks Max!!
Another magic one!
French version ;) http://moiscript.weebly.com/heightmap.html
PS I have not your problem of images path!
My image can be anywhere! :)
EDITED: 17 Aug 2015 by PILOU
7547.14 In reply to 7547.1
Oh! I shall enjoy this. Creating my own Lithopanes via MOI, this wonderful script and 3D printing.
Thanks, Max!
Mike.
7547.15 In reply to 7547.14
Administrator rights? How would I do this?
7547.16 In reply to 7547.15
In Windows system
Right Click on a programme : "Run as Administrator" ;)
@Max
Does it possible to have density of curves ? (number of curves)
don't shown here :)
Curves result from your rendered image! So fractal process! :)
7547.18 In reply to 7547.16
Wouldn't you know it, I am on a Mac!
7547.19 In reply to 7547.16
OK, in my Windows7 taskbar, right click on Moi lightbulb icon,
then again right click on the next icon and Moi 3.0, (lightbulb Moi 3.0), and select "run as administrator," works.
7547.20 In reply to 7547.1
Hi Max - so the reason it doesn't work right on Mac is that on Mac moi.filesystem.getOpenFileName() is not returning a Mac native path, it's returning the "virtualized" windows path which uses the z:\ drive (with Windows path delimiters). So for instance when the user selects a file really named /Users/michael/desktop/file.png , the path returned from moi.filesystem.getOpenFileName() will actually be z:\Users\michael\desktop\file.png
So for this particular case just treat it always the same as the windows version and it will then work.
I guess it's probably a bug though that moi.filesystem.getOpenFileName() does not return a Mac native path when some other functions do - right now it's kind of a mix with mainly things that are meant to be displayed in the UI end up with the Mac native path in them and others that don't map directly to some display in the UI use the virtualized Windows path instead which is basically the default in the current version. This will probably be different in v4 with more things returning Mac native paths because v4 won't have the whole virtualized Wineskin system in it anymore for the Mac version.
Anyway to get this working on mac right now edit _Heightmap.js and change line 7 to:
var dlm = '\\';
And that should then get it to work.
7547.21 In reply to 7547.1
Make my first 3D prints using Max's great script.
The image is of a child's hand. Cropped from a much larger photo. And then edited to remove any light coloured elements near the hand.
The blue image is a lithopane with light coming through the differing thickness of a translucent material.
The white one is more opaque to light and looks more like a carving.
Size: 247 KB, Downloaded: 128 times, Dimensions: 1414x1181px
Size: 642.1 KB, Downloaded: 115 times, Dimensions: 1459x1297px
7547.22
Is that code all that would be in line 7?
7547.23 In reply to 7547.22
Hi raytownmike,
Yup, the current code on line 7 in the file _Heightmap.js looks like this:
	var dlm = moi.filesystem.getPathDelimiter();
If you change that to be what I wrote above, like this:
	var dlm = '\\';
Then after that it should work on the Mac. You need to open the file _Heightmap.js in TextEdit.app and edit the 7th line from the top of the file.
7547.24 In reply to 7547.23
Got it I suppose I had a character off! Yours worked great and thank you.
7547.25
v.0.6
Increased points density
Increased scale speed
Added support of bmp-files
Changed path delimiter to "//" (seems it works good with windows version also)
Added image size info
EDITED: 7 Mar 2022 by SMIRNOV
7547.26
bemfarmer
>> Does this perform similarly to zsurf4?
I don't know. I never used it. :)
Mindset
Yes, it's possible. We can use PGM as output format. You can open it with photoshop.
Maybe later I'll write such a script.
Michael
Thanks for advice with delimiter
Frenchy Pilou
Right now it's not possible. But you can resize an image. If you want to get 60 curves, resize image to 60x60 pixels.
ed
Interesting work. Try to use the new version. It can produce much more detailed surface.
7547.27 In reply to 7547.25
Mas, I've tried twice to process an image that I successfully processed with the previous version of your excellent script. Moi crashed both time. The original image was 2761x2761 pixels.
It imports OK - I used a scale factor of 7.
I then scaled down to about 1/25 of size to give a 395 curves of xyz of 100 100 5.62.
Then loft OK but MOI locks up when I tried to extrude by -5mm.
I guess that it's run out of memory.
Had another go but reduced the original image to 1381x1381 before importing it.
Much the same, still couldn't extrude.
Any chance of making the point density adjustable?
Mike.
Tricky!
7547.29 In reply to 7547.28
Thanks, I can experiment. Any idea what number of curves the original script gave?
That would be my starting point
Message 7547.30 deleted 20 Aug 2015 by BURRMAN
Show messages:  1-10  11-30  31-50  51-67
