MoI V3 (Win) on USB stick?
All  1-3  4-9
7499.4 In reply to 7499.3
Hi Michael, working between a few machines here and before I work out what is going to be main machine , think moi on USB key is a great solution.
Does this method work on v4 beta / anything else I need to look out for?
Enjoy your weekend. (Low priority question)
- Stefano
7499.5 In reply to 7499.4
The only thing is that you must use Moi on only one device in the same time!
So not on computer, on a Latop, & on an USB stick on the same time !
But you can open any number sessions of Moi on this same device in the same time!
7499.6 In reply to 7499.4
Hi Stefano, yes running from a USB key works the same in the v4 beta as in previous versions, the instructions above are still valid.
If the USB key is pretty slow it can be a bit hiccupy when it needs to load a DLL or something from it if you run it directly off of the USB drive. But the hiccup will only happen once per DLL so after a couple of hiccups it will smooth out. If you run into that you might want to copy it over to anywhere on the hard drive and run it from there.
You can also just install the same MoI license on multiple machines just as long as only one of the installations is actively launched and running at a time. To do that use the same installer and same license key on each one and close MoI (exit the running program, not uninstall) on one machine before launching it on another.
7499.7 In reply to 7499.5
HI Pilou, For now just me here and one machine at a time is fine! I'm just trying to avoid taking laptop to workshop and checking I dont need to move hidden folders etc. ...
I was thinking v4 might put some things in slightly different folders compared to v3.
Hi Michael, Once out of beta and I've consolidated a few systems in the workshop..I'll likely do the 2nd option.
EDITED: 19 Sep 2020 by LIGHTWAVE
7499.8 In reply to 7499.7
Hi Michael just wondering can a mac version of moi also work on a USB key on Mac ?
Whilst I’m usually a total windows user
Might be given a MacBook m1 air and curious to consider using moi on it natively (or from the key)
7499.9 In reply to 7499.8
Hi stefano, yes you can also do that on the Mac version.
It's actually more of a normal thing on Mac that apps are self contained and can be "installed" by just dragging them into the /Applications folder.
Show messages: All  1-3  4-9
