Bug Distortcurves ?
All  1-3  4-6
7492.4 In reply to 7492.3
> I want use the cursor from 200 to 0 !
That's just not how sliders work in MoI - editing a custom value does not change the slider range. That's normal behavior and not a bug.
But if you want you can edit the .htm file and change the range values for the slider to make it permamently go between 0 and 200.
Open the file in a text editor and find the <moi:Slider> element in there, the ranges are set by the values min="" mid="" and max="".
If you set them to min="0.0" mid="100.0" max="200.0" then your slider will go between 0 and 200.
7492.5 In reply to 7492.4
Hoppefuly we can make that! :)
Excellent! :)
Will be very cool with LineWeb for example! :)
EDITED: 10 Jul 2015 by PILOU
Show messages: All  1-3  4-6
