How to change moi3d UI font after Linux update?
All  1-2  3-4
7491.3 In reply to 7491.2
Thank you for the hint!
I case someone else runs into the same problem:
The fix can be found here: http://askubuntu.com/questions/219791/improve-gui-appearance-of-wine-applications
For the relevant commands, have a look at the attached picture.
S.
Size: 84.7 KB, Downloaded: 84 times, Dimensions: 728x602px
7491.4 In reply to 7491.3
Greetings All,
The best and quickest solution to the UI font problem is to set the UIfontName=Droid in the moi.ini file.
Just let the system use a native font that renders well by default, rather than trying to force Arial to display correctly.
You will be much more pleased using Droid on your linux machine!
Show messages: All  1-2  3-4
