Specific Grouping Use Case
All  1-6  7-14
7464.7 In reply to 7464.6
Hi Scott, yup that looks like it ought to do what you want!
7464.8 In reply to 7464.7
Hi Scott,
Thanks for that script. I just tried it, but I get the following error message:
What´s wrong?
It´s the first script I try to install. Just took the script text, put it into text editor, converted to plain text, and changed the fileformat to .js . Then I put it into the commands folder and assigned a shortcut to it.
Another very useful tutorial regarding groups I found is by Max Smirnov: https://www.youtube.com/watch?v=HGiZgl2Q6g8
Asked him for the script via PM. Or does anybody know where to find it in this forum?
-Philip
7464.9 In reply to 7464.8
Max Smirnov can send something to him I suppose! :)
7464.10 In reply to 7464.8
Hi Philip,
> What´s wrong?
Can you please post your _sameName.js file here as a file attachment so I can take a look at it?
7464.11 In reply to 7464.10
there you are. Attached the script.
-Philip
7464.12 In reply to 7464.11
Philip:
I think you're missing the ending brace.
var objects = moi.geometryDatabase.getSelectedObjects();
if (objects.length > 0) {
var name = objects.item(0).name;
moi.geometryDatabase.selectNamed(name);
Scott
7464.13 In reply to 7464.11
Hi Philip - your script is invalid JavaScript code because it's missing the closing bracket for the if statement.
You've got an open bracket here shown in bold red:
So to go along with that open bracket you need a close bracket to complete the if statement, like in the attached file.
Once you add the closing bracket your script should then work as you wanted it to.
EDIT: scott beat me to it! :)
7464.14 In reply to 7464.13
Thanks Scott and Michael!
Stupid small mistake. Works now.
Show messages: All  1-6  7-14
