export obj
All  1  2-6
7444.2 In reply to 7444.1
Hello Marcel ! ;)
Alors on y revient ? :) Il est temps! :)
Maybe for complex objects triangles will me more adapted and more generic!
But Michael will have a more explicative answser than me! :)
For the 90° there is a dialog box Inside Options (bottom screen) Options / Import - Export OBJ / Orientation
PS Une petite image histoire de nous en mettre plein les mirettes et nous faire rêver dans ce monde de brutes! ;)
EDITED: 12 Jun 2015 by PILOU
7444.3 In reply to 7444.2
bonjour!! je vois que tu es toujours au poste, sur ces softs moins ... connus!! et oui, certaines tendances du soft m'éloignent un peu de rhino... cela dit, il faudrait que j'upgrade sur la derniere version de MOI...
( ps: ben je n'ai pas d'images faites avec moi, pour l'instant!)
EDITED: 12 Jun 2015 by CELMAR
7444.4 In reply to 7444.3
Même sans moi! ;)
7444.5
another problem: once the objects have been exported, the "volume", in n-gons, are handled without problems by uv mapper, to create quick uv map... But the cutted planes, exported in n gons, are impossible to read by UV Mapper.. It's necessary to export in quads and triangles, to get a planar uv map... But the export in n-gons is better to keep soft rounded shapes... any solution???
7444.6 In reply to 7444.5
Hi marcel,
Are you using the UV Mapper utility from here? : http://www.uvmapper.com/
If it doesn't support N-gons then I guess you can't use n-gons but you could ask the UV Mapper developer if they plan to support n-gons in the future or if they possibly support them in the "Pro" version of that software.
Cinema4D probably has its own UV unwrapping and assignment tools that you could use instead.
Show messages: All  1  2-6
