Big trouble with little fillet...
All  1-2  3-8
7437.3 In reply to 7437.2
Hi, Mauro!
It is an object lesson, thank you! I will immediately learn to do as you are!
Great workflow, everything is clear and vividly!
You have very much helped out greatly!
EDITED: 7 Jun 2015 by KRASS
7437.4
Hello krass,
I think you can get everything filleted the way you want it, but I've found in cases where I might have filleting problems that I build surfaces past where I think I'll need them and then start changing the order where I fillet. Before I do that I try to think how I would carve the object out of a solid block of material, that helps the process a bit as well. If you have the raw model minus any fillets or just lines that works better sometimes than posting models that are half finished with detail.
7437.5
Hello everyone!
Thank you for your invaluable help and advice!
As a result, I redid the model again using your tips and recommendations.
In some places had deliberately change some nonessential radii to avoid creating bottlenecks to rounding.
In any case - thanks!
ps. that's what happened as a result of work.
Size: 111.5 KB, Downloaded: 82 times, Dimensions: 876x583px
7437.6
Krass..let me show you a simple example about fillet in a situation with-without seam
A simple polyline 20x20mm:CENTER= corner filleted 10mm,RIGHT= corner filleted 10mm then REBUILDED
extrude now both:rebuilded curve on the left don't have seams,right curve show origin of the seams
now put two cylinders in a particular position
select both edge loops
Fillet both
Now you know,before fillet always check the area,if you detect seams crossing each other and so,rebuild surfaces avoiding that.
For further advanced situations check this:
https://vimeo.com/63076359
M
Mauro - Interesting demo.
I would have thought the simpler polyline would give the least trouble.
Guess I have a lot to learn, especially regarding seams.
It would be helpful to know why seams get created in the first example, and not on the rebuilt curve. And why do seams interfere with fillet?
7437.8 In reply to 7437.7
Hi Ed,
The filleter basically follows edges when it constructs fillet surfaces. The more complex the edge structure, the larger number of fillet segments have to be created and one of the things that tends to be difficult is dealing with the juncture areas where fillet pieces meet each other.
Show messages: All  1-2  3-8
