Volume calculator
 1-6  7-26  27-46  47-66  67-76
7421.47 In reply to 7421.45
The equation to find combined centre of Gravity, is explained very well here:
https://www.youtube.com/watch?v=KMDY-hexpZ8
mass1 = vol1 * density1 , centered at point mass m1.
mass2 = vol2 * density2 , centered at point mass m2.
d = distance between (center of mass of m1) and (center of mass of m2).
x = distance from (center of mass of m1) to the point on the line between m1 and m2, which is the combined centre of Gravity.
m1 * x = m2(d-x)
x = (m2 * d ) / (m1 + m2)
They say is the "same" for torque. (No inverse square law needed.)
(x is not necessarily the x-axis), so x,y,z coordinates of the points may be used, or a cplane making d along the x axis...)
7421.48
CVolume v1.3
[added] enhanced surface mode. How you can use this script with faces and separate surfaces.
Marbleman
>>I think this is a big ask, but would it be possible for 2 or more solids of different densities to have its combined centre of Gravity worked out?
Hi James. Yes, this is possible, but I need to think about concept. Give me a week.
EDITED: 7 Mar 2022 by SMIRNOV
7421.49 In reply to 7421.48
Excellent Max,
thank you very much, you are King of Scripts :-)
Regarding centre of gravity ... it will be fine to have set of styles which represents certain material = density.
Kind regards,
Mik
7421.50 In reply to 7421.49
Mik
Yes, I have the same thoughts.
In fact the technical part don't bother me. There are pretty simple calculations. First I need to think about global internal structural changes. It is much more difficult task.
7421.51
Yes, of course, choosing the best concept is always big task and calculation of CoG will be very useful feature for modelling of complex assemblies.
Kind regards,
Mik
Do you confirm or not that Center of Mass can be calculated between 2, 3, or more volumes in the same time inside the present plugin? (same density)
7421.53 In reply to 7421.52
Yes, I confirm it. :-) 2, 3 and more.
7421.54 In reply to 7421.53
Terrific!
7421.55
Thanks Max,
I think you're the master!
James E
www.jameselliott.co.uk
7421.56
Thanks Dino and Max for this useful script.
I have a small improvement request: In the default MoI user interface some contents of the dialog window is too wide.
-Martin
7421.57 In reply to 7421.56
Hi Martin,
I didn't noticed any problem with the script interface. But it seems like you are using Windows UI scaling feature. I'll make some chаnges in the script to fix it. Wait for the next version.
7421.58 In reply to 7421.57
Hi Max,
it's on my Laptop and Desktop computer both running OS X. I'm not aware of any window scaling.
7421.59 In reply to 7421.58
It's the same for me on OS X.
7421.60
Hi Max,
Your script is amazing, I have wanted this feature since MoI's beta.
Concerning the display cutoff; I am experiencing this as well. I'm not scaling and my display is 1920 x 1080 in Windows 10.
Again though I am so happy to have the script, thanks for all your hard work in this area!
David W. (Aka: blend3d)
EDITED: 13 Sep 2015 by BLEND3D
7421.61
CVolume v2.0 beta 1
Completly rewritten :)
Added:
- Center of mass calculation for solids of different densities. ( style = material )
Fixed:
- Interface width
Hidden features:
- Double click on title to reset group volume
- Double click on group name to switch to the first group (All objects)
- You can use material name as style name (full or partial). The script will set density automatically. For example: "Copper", "Wooden box [Redwood]", "Golden ring"
To do:
- Interface tuning
- Volume/Mass changing for All objects group.
upd: bug fixed. reuploaded.
7421.62
more bugs fixed (and added)
added hotkeys (right arrow / left arrow)
EDITED: 23 Sep 2015 by SMIRNOV
7421.63 In reply to 7421.62
Hi Max,
it works perfectly.
Cпасибо.
Mik
7421.64
CVolume v2.0 beta 3
- some interface changes
- improved volume/mass/surface area ajustment (now in works with all objects)
- hidden: double click on Density title -> copies material name to style name
7421.65 In reply to 7421.64
Hi Max,
some error appears repeatedly during opening of ZIP file.
Mik
7421.66 In reply to 7421.65
Hi Mik,
I accidentally made 7z archive with .zip extension :)
Fixed. Download it again.
Show messages:  1-6  7-26  27-46  47-66  67-76
